ajstarks
Plans to support Vulkan?
Tue Mar 03, 2015 11:18 am
Are there plans to support the new graphics API, Vulkan?
See: https://www.khronos.org/vulkan
Re: Plans to support Vulkan?
Tue Mar 03, 2015 11:42 am
You're more likely to get an answer by posting on https://www.khronos.org/message_boards/ ... te-on-GPUs
This is a doctor free zone.
dave j
Tue Mar 03, 2015 5:15 pm
ajstarks wrote:Are there plans to support the new graphics API, Vulkan?
From the page you linked to:
Will work on any platform that supports OpenGL ES 3.1 and up
So it looks unlikely.
jdunson
Tue Mar 03, 2015 6:32 pm
I was wondering this as well. It looks like Vulkan should run easily on anything that supports OpenGL ES 3.1, and the Pi only does 2.0 IIRC. But there's a sliver of hope from a Broadcom logo on the bottom of the Vulkan page. Anyone knowledgeable want to comment on the odds that Broadcom or the Foundation will get Vulkan running on the BCM2836?
Tue Mar 03, 2015 6:56 pm
jdunson wrote: Anyone knowledgeable want to comment on the odds that Broadcom or the Foundation will get Vulkan running on the BCM2836?
These things usually work the other way round. The Vulkan developers get their stuff running on the RPi because they see it as a desirable platform for their software rather than the RPF (or Broadcom) doing it.
The RPF have much more important things to do like making sure my RPis run with the best possible "firmware" and kernel. I'd also like them to be developing their new hardware (DSI display, 2A, 2C, 3B, 3A, 3C, Compute Module2, Compute Module3 or other new shiny things, NOTE there's a huge amount of speculation in that list) with the next new SoC from Broadcom.
dave j
Tue Mar 03, 2015 8:13 pm
Given Vulkan is the next version of/replacement for OpenGL, supporting Vulkan would mean writing a driver for it - something that hardware manufacturers usually do. So it's no more a case of the Vulkan developers getting it working on the VideoCore 4 GPU as it was the responsibility of the developers of OpenGL to getting that working on it.
Looking at the intermediate language that Vulkan uses (SPIR V), it looks very unlikely that the VC4 GPU could support it. It supports things like tesselation which the VC4 doesn't. So even if someone took the VC4 documentation an tried to produce a Vulkan driver I don't think it will be possible. I suspect the Broadcom logo is due to them having more capable GPUs that can support it.
scidata
Wed Mar 04, 2015 5:26 pm
It would be nice if compute was a general fork of GPU/OpenGL/Vulkan. To be held up by stuff like tesselation is unfortunate. The same goes for integer/floating point.
"Self-education is, I firmly believe, the only kind of education there is" - Isaac Asimov
riklaunim
Wed Mar 04, 2015 6:33 pm
Usually the hardware also have to support it. You can notice on products specs which version of DirectX or OpenGL given GPU card supports. And on top of that most ARM GPU units supports only OpenGL ES and not the "desktop" OpenGL so it's even farther away from supporting Vulkan.
mimi123
Fri Mar 06, 2015 6:14 pm
riklaunim wrote:Usually the hardware also have to support it. You can notice on products specs which version of DirectX or OpenGL given GPU card supports. And on top of that most ARM GPU units supports only OpenGL ES and not the "desktop" OpenGL so it's even farther away from supporting Vulkan.
Vulkan will work on OpenGL ES 3.1 platforms.
riklaunim
Fri Mar 06, 2015 6:20 pm
VideoCore 4 docs state:
 Fully supports OpenGL-ES 1.1/2.0 and OpenVG 1.1
So there may be a problem with 3.1 - and there always will be a difference between OpenGL ES and OpenGL.
mimi123
Fri Mar 06, 2015 6:26 pm
riklaunim wrote:VideoCore 4 docs state:
There is too much things missing for OGLES3.1 and OCL2.1.
{the VC4 also supports OpenGL2.1, but that's a detail)
