dzeko1236
Adding Xcb plugin and QtWayland
Wed Jul 21, 2021 8:35 pm
Hello ,
How can i install xcb plugin in raspbian .
and how to install Qtwayland .
thankyou
topguy
Re: Adding Xcb plugin and QtWayland
Wed Jul 21, 2021 9:07 pm
Maybe you want to mention which software this "xcb plugin" is supposed to "plug into" ?
dzeko1236
Wed Jul 21, 2021 9:40 pm
currently I cross compiled a Qt app on RPi3 .
I run it normally using eglfs platform but it misses some things like a title bar , can't move or resize window .
So I read in many documentation that I need :
1- a window manager
2- run the app with -platform xcb or run using wayland .
I am really new in cross compilation and linux .
So this problem seem very hard to me .
I will appreciate any suggestion .
thank you
topguy
Thu Jul 22, 2021 8:36 am
Then can I assume you also cross-compiled Qt yourself ?? ( that was the only way of getting eglfs to work earlier at least )
Because the XCB plugin is built during the build of Qt so you have to add it during the configuration step.
Yes, eglfs will always run in fullscreen but with hardware accellerated graphics.
Is you app a C++ application or QML ? ( or a mix )
dzeko1236
Thu Jul 22, 2021 8:49 am
My App is a mix between c++ and Qml .
So if i understand you , i should recompile Qt , and add the XCB plugin to my configuration ?
In this case can you suggest a tutorial or a documentation to help me .
thank you
topguy
Fri Jul 23, 2021 10:02 am
Did you follow a tutorial to start with ?
Return to “Graphics programming”
