randomher0
Configure full-KMS for headless X11 access
Fri May 07, 2021 8:22 am
How can full-KMS/X11 be configured to start up with 1080p (or any other resolution than 720x480) in a headless configuration.
Setting hdmi_force_hotplug=1 in /boot/config.txt does not work - I've read the /boot/config.txt parameters do not
work for full-KMS. It is not possible to reconfigure with xrandr, the resolution change is not accepted - probably because
hdmi signals disconnected state.
Is there another way to make full-KMS think a hdmi device is connected?
Goal is to remote access desktop to X11 without an HDMI device connected.
[    12.326] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[    12.327] (**) modesetting(0): Depth 24, (--) framebuffer bpp 32
[    12.327] (==) modesetting(0): RGB weight 888
[    12.327] (==) modesetting(0): Default visual is TrueColor
[    12.327] (II) modesetting(0): ShadowFB: preferred NO, enabled NO
[    12.327] (II) modesetting(0): Output HDMI-0 using monitor section HDMI-1
[    12.327] (**) modesetting(0): Option "Primary" "true"
[    12.328] (II) modesetting(0): Output Composite-0 has no monitor section
[    12.328] (II) modesetting(0): EDID for output HDMI-0
[    12.328] (II) modesetting(0): EDID for output Composite-0
[    12.328] (II) modesetting(0): Printing probed modes for output Composite-0
[    12.328] (II) modesetting(0): Modeline "720x480"x31.3   13.50  720 734 798 858  480 483 486 502 interlace (15.7 kHz e)
[    12.328] (II) modesetting(0): Output HDMI-0 disconnected
[    12.328] (II) modesetting(0): Output Composite-0 disconnected
[    12.328] (WW) modesetting(0): No outputs definitely connected, trying again...
[    12.328] (II) modesetting(0): Output Composite-0 connected
[    12.329] (II) modesetting(0): Using sloppy heuristic for initial modes
[    12.329] (II) modesetting(0): Output Composite-0 using initial mode 720x480 +0+0
[    12.329] (==) modesetting(0): Using gamma correction (1.0, 1.0, 1.0)
[    12.329] (==) modesetting(0): DPI set to (96, 96)
cleverca22
Re: Configure full-KMS for headless X11 access
Fri May 07, 2021 9:51 am
i think hdmi_force_hotplug=1 only applies when the firmware is in control (fkms for example)
the real kms stack has a different option for that, but i'm not sure what it is
dom
Fri May 07, 2021 9:55 am
When using kms, firmware settings for controlling hdmi will have no effect (firmware is not in control of hdmi).
I think you can do this with cmdline.txt settings. e.g.
capture your edid when monitor is connected and booted with kms:
sudo cp /sys/devices/platform/gpu/drm/card0/card0-HDMI-A-1/edid /lib/firmware/edid/myedid.dat
Then add to start of cmdline.txt:
video=HDMI-A-1:1920x1080@60 drm.edid_firmware=edid/myedid.dat
You should then have the edid available on future boots without needing HDMI to be connected.
6by9
Fri May 07, 2021 10:39 am
Full KMS abides by the hotplug signal, so I suspect even with the overrides that dom has given it will still see HPD as disconnected and therefore not activate the HDMI interface.
dom
Fri May 07, 2021 11:18 am
That's annoying. I was under the impression that a being able to read the edid overrode the lack of hotpug.
And I hoped a custom edid would count.
But you are right, it doesn't work as hoped. Any idea how to override hotplug?
randomher0
Fri May 07, 2021 11:29 am
Thanks for your replies.
tried suggestion by @dom - unfortunately without success:
On raspberry pi 3+ sys/devices/gpu/... - is not there? - following command outputs a myedid.dat file (it contains some binary info and spotted the name of the screen "BenqXY", so this probably worked.)
/opt/vc/bin/tvservice -d edid.dat
kern.log says the following.
May  7 13:06:30 raspberrypi kernel: [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=3cbe32eb-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles video=HDMI-A-1:1920x1080@60 drm.edid_firmware=edid/myedid.dat
Substituting video=HDMI-0:1920x1080@60 drm.edid_firmware=edid/myedid.dat didn't work neither.
Maybe there is another way to fake the hotplug signal - preferably in user space? Do you have any suggestions where to look?
HiassofT
Fri May 07, 2021 11:32 am
You can override hotplug by adding "D" at the end of the video option, see https://www.kernel.org/doc/Documentation/fb/modedb.txt
eg video=HDMI-A-1:1920x1080@60D (this will work without edid) or video=HDMI-A-1:D if you have an edid override in place.
so long,
Hias
randomher0
Fri May 07, 2021 11:41 am
Thanks for that suggestion @HiassofT - can you tell if HDMI-A-1 is correct for RPi3 since it has only a single HDMI portCan this mode be triggered at some other place - through user command?
dom
Fri May 07, 2021 12:12 pm
Yes, I can confirm it works on Pi3. It still uses HDMI-A-1:
Added:
drm.edid_firmware=edid/myedid.dat video=HDMI-A-1:1920x1080@60D
with no hdmi connected and
sudo cat /sys/kernel/debug/dri/0/state
	mode: "1920x1080": 60 148500 1920 2008 2052 2200 1080 1084 1089 1125 0x60 0x5
randomher0
Fri May 07, 2021 2:31 pm
Thank you very much, this worked.
It didn't work without the edid.dat file for me - maybe the modes checked by X11 were all out of range for the "default monitor" - the most I could get was 1280x1024 - there were some messages "hsync out of range" or "vrefresh out of range".
(If anybody knows of a way to set this up without passing arguments to the kernel at bootup and creating an edid.dat please let me know.)
Return to “Graphics programming”
