piense
OpenVG & vgWritePixels
Wed Sep 13, 2017 11:15 pm
I'm trying to use OpenVG on a Pi3 to display some images. I get the image in a buffer in RAM and am using vgWritePixels to push that data to a window that's rendered to the screen. I'm using the hello_font example in raspberrypi/firmware as a starting point which defaults to using the VG_sARGB_8888 image format. That seems to work ok, but when I changed the image format to VG_sRGBA_8888 to better fit the format I have coming in, bad things happen. It's hard to describe but best as I can figure the image is a somewhat transparent version of the Red channel but certain rectangular areas of the image look normal. All I'm changing is the image format to the vgWritePixels call, and the corresponding mapping of the input channels in the source array. It's all very strange. Need be I can supply all the details and code but maybe those symptoms ring a bell for someone and can point me in the right direction to understanding what might be going on.
Paeryn
Re: OpenVG & vgWritePixels
Thu Sep 14, 2017 2:02 am
How are you mapping the channels? Assuming the data is an array of uint8_t then the first pixel is :-
for VG_sARGB, data[0] = blue, data[1] = green, data[2] = red, data[3] = alpha
for VG_sRGBA, data[0] = alpha, data[1] = blue, data[2] = green, data[3] = red
OpenVG defines the order as highest bits on the left when read as a word but the RPi is little-endian so the lowest byte is stored at the lowest address in memory (a 32-bit value of 0x01020304 is stored as 0x04, 0x03, 0x02, 0x01).
She who travels light — forgot something.
piense
Fri Sep 15, 2017 5:14 am
I figured that much out, admittedly more by trial and error than an intelligent understanding of the problem. But the problem I'm seeing isn't a simple channel mapping problem. I rendered the primary colors to the screen and there's just blocks of picture missing in certain channels.
Paeryn
Fri Sep 15, 2017 8:56 am
There shouldn't be bits missing in just some channels, the only thing which affects whether pixels are copied or not is scissoring. Any pixels that are updated get the values you pass in (unless you use the _pre formats which clamp a pixel's colour channels to its alpha value).
Can you give a short example of what you are doing?
blackshard83
Tue Sep 26, 2017 11:38 am
It looks weird to me too, you should "just" see the colors altered if you fail to match the channels from the source image to the OpenVG format. Nonetheless it could be tricky because if you map a color channel to the alpha channel you may actually miss some parts of the image because the color channel may express very low values in a region of the image and, as long as it is mismatched as alpha channel, OpenVG renders an almost fully transparent pixel there.
Have you considered to use the ABGR/BGRA formats? You should be able to render the source data without swapping the channels as it should be free of costs.
PS: maybe a couple of screenshots may be useful ;)
Gavinmc42
Wed Sep 27, 2017 1:44 am
You might want to check how Ultibo does it.
https://ultibo.org/forum/viewtopic.php?f=15&t=659
But it might not be of any use for you as it use the VC4 libraries.
Try Peter Lemon's VG stuff?
https://github.com/PeterLemon/Raspberry ... nate_Array
Or AJ's
https://github.com/ajstarks/openvg
I'm dancing on Rainbows.
piense
Tue Jan 23, 2018 7:24 pm
Got around to poking at this project some more. The ordering really isn't a bit issue but I'd be curious what's going on. Here's some pics of what's happening, ignore the moire effect, that's just the camera and LCD being weird.
https://imgur.com/a/OMGxC
I'm using graphics_userblt to copy the image to the screen. In that example the only thing I changed was line 787 in graphics.c from VG_sARGB_8888 to VG_sRGBA_8888. I'd expect the channels to be swapped of course but I don't understand the blocking on the right half of the screen.
Paeryn
Wed Jan 24, 2018 2:20 am
The imagery showing through looks like 7 columns of 9 rows of rectangles which are getting progressively smaller going right pretty much on the right half of the screen. It looks like there might be something drawn on the screen (desktop?) underneath the OpenVG window that could be showing through now that you have non-opaque alpha values on the OpenVG window perhaps?
vgWritePixels() should just be copying the source pixel data straight onto the destination with the only alteration being the format conversion, the difference between sARGB and sRGBA should just be a byte swizzle (not taking into account sRGB is non-linear and A is always linear - I don't think it matters here as you are copying data not blending it), not something that should have such an effect anyway.
piense
Wed Jan 24, 2018 2:26 am
The screen behind that window is just black. It's a custom buildroot distro with all the splash screens and login prompts disabled.
Paeryn
Wed Jan 24, 2018 2:37 am
If you draw the image at an offset (say 100 pixels to the right) do the rectangles move with the image or are they in the same place on the screen? Similarly if you use a different image do you see the exact same artefact?
piense
Wed Jan 24, 2018 5:09 am
Different images have the exact same artifact. If I move the image over at all with vgWritePixels dx the effect goes away entirely and it looks like what I'd expect with the channels out of order.
LdB
Thu Jan 25, 2018 4:49 am
It looks like line to line pitch is out .. which you will be using for datastride in vgWritePixels.
The worst is 1366x768 the Pi screen line to line pitch is 1376 so there is 10 whole pixel offset it you expect it to be 1366 * 4 bytes wide it isn't its 1376*4 bytes wide. Yours looks like 1 pixel or 1.5 pixels and so it's rolling in and out of synch.
It all revolves around wanting to keep neat alignment on the VC4 stride from line to line.
From memory ask it "bytesForImageScanline" in the vg utils for the surface you have.
piense
Thu Jan 25, 2018 5:20 am
The parameters work fine for a different color format though, that mostly eliminates things being wonky in the rest of the input parameters. It really should just be a difference in how it interprets the given channel data.
Paeryn
Thu Jan 25, 2018 9:22 am
The datastride parameter refers to the stride in the source data, if you get that wrong the whole image will be off, not just some channels on the right hand side, and the OP says the image is fine with the the different ordering of pixel data. The stride of the screen is of no concern as OpenVG knows what stride the screen is and doesn't give you any option to pass your own value.
The datastride only has to make sure that pixels are correctly aligned so for a 32bit pixel format data must be 4 byte aligned and datastride must be a multiple of 4, other than that there is no limitation. If you break the alignment then the call will not write to the screen and will return an error.
Return to “Graphics programming”
Who is online
