gkreidl
Re: HOWTO: Install Kodi on Raspbian
Mon Sep 26, 2016 11:45 am
Why don't you simply install the version from the repository or one of the versions available here: viewtopic.php?f=66&t=109088 ?
Minimal Kiosk Browser (kweb)
spartanhooah
Sat Jan 07, 2017 8:02 pm
I installed kodi using apt-get, but when I ran kodi (either through the Raspbian menu or at the command line), nothing seemed to happen. I could use top to see that kodi.bin was running, but I saw no evidence of such. I found this thread and followed the instructions, but I see the same results. I've tried both kodi and kodi-standalone. What could I be doing wrong?
gkreidl
Sat Jan 07, 2017 10:59 pm
spartanhooah wrote:I installed kodi using apt-get, but when I ran kodi (either through the Raspbian menu or at the command line), nothing seemed to happen. I could use top to see that kodi.bin was running, but I saw no evidence of such. I found this thread and followed the instructions, but I see the same results. I've tried both kodi and kodi-standalone. What could I be doing wrong?
Are you connected via VNC?
spartanhooah
Sat Jan 07, 2017 11:34 pm
Yes.
gkreidl
Sun Jan 08, 2017 8:12 am
spartanhooah wrote:Yes.
Kodi uses an OenGL ES interface, which is not viśible on VNC. And you wouldn't be able to watch video across VNC anyway.
sconemad
Sun Jan 08, 2017 2:27 pm
The RealVNC service mode server (installed by default in Raspbian) actually does allow you to see kodi, so long as you have the "experimental direct capture mode" enabled in the vnc options dialog. This uses a lower level screen capture method, which can capture directly rendered graphics, as well as the text console.
It's still not great for watching video (since there's no sound over vnc), but it can be useful for control and setup purposes.
It also gets confused if you start kodi from the X desktop, so I'd recommend not running X and starting kodi directly from the command line.
spartanhooah
Sun Jan 08, 2017 4:50 pm
Ok, thanks for the info. Wasn't planning on watching video over VNC, just getting it set up so I can stream elsewhere. Toggling that setting worked, thank you! Of course, it made VNC a lot slower, but that's tolerable for just getting Kodi set up.
spartanhooah
Sun Jan 08, 2017 5:10 pm
Well, I spoke too soon. Kodi starts up, but it doesn't respond to anything. When I kill the process, the desktop doesn't show up again, and I have to restart the Pi to get it back. What's going on now?
If this would be better for the Kodi forums, let me know.
sconemad
Sun Jan 08, 2017 9:24 pm
spartanhooah wrote: Kodi starts up, but it doesn't respond to anything.
Are you starting Kodi from the desktop menu? If so, there is a known issue where VNC still sends the input to the X server, and Kodi never receives it. You can work around this by stopping the desktop (you can do this by making your Pi boot to the command line, or as a one-off, do "sudo systemctl stop lightdm"), and starting Kodi directly from the console.
spartanhooah wrote: When I kill the process, the desktop doesn't show up again, and I have to restart the Pi to get it back. What's going on now?
I think this is a known issue with Kodi. You can usually get it back by switching VT several times with e.g. Ctrl-Alt-F2 then Ctrl-Alt-F1. If you are running the viewer on a Linux machine, you will need to use the commands to enable Ctrl and Alt from the viewer's menu (accessible via F8) to avoid switching VT on the viewer machine itself.
spartanhooah
Mon Jan 09, 2017 12:37 am
I've tried starting Kodi both from the lightdm menu and through the terminal (over VNC).
I did just discover that I do have a cursor, it's just stuck to the left side of the screen and has very amplified movement. What might cause that?
spartanhooah
Wed Jan 11, 2017 1:00 am
Any ideas? This is pretty much a showstopper.
sconemad
Wed Jan 11, 2017 9:43 am
You could try using the viewer's "Relative pointer motion" option.
When you use VNC to connect to an X11 (or Windows or Mac) desktop, the server is able to set and retrieve the position of the mouse pointer, since there are standard ways of doing this for these platforms. So when you move the mouse pointer within the viewer window, it can tell the server to move the pointer to the corresponding place. However, Kodi isn't running within a window system, and handles the positioning of the mouse pointer itself, hence VNC has no way of setting or retrieving this.
The VNC Viewer has an option called "Relative pointer motion", which is designed for this sort of scenario - which you can enable via the F8 menu. It works by just sending pointer movements, without trying to map the position of the pointer on the viewer to the server. One effect of this is that the viewer "grabs" the pointer, and you can't move it out of the viewer window without disabling relative pointer mode.
spartanhooah
Thu Jan 12, 2017 1:09 am
That did the trick, thank you! I skimmed through those settings, but must have missed the RelativePtr one (and I didn't know about the f8 menu). Now it's time to configure...
spartanhooah
Thu Jan 12, 2017 2:39 am
Well, now I've hit another snag. I noticed that Kodi 16.1 is out, but isn't yet in the Raspbian repositories. I found a guide to install the newer version at https://mtantawy.com/quick-tip-how-to-u ... pberry-pi/, which I followed. I ended up getting a segmentation fault when I started Kodi, so I removed Kodi and the additional repository, but now I still get segmentation faults when I try to start Kodi. Here's a pastebin of the log: http://pastebin.com/bKU4mYHb
What can I do to fix this?
Rascas
Thu Jan 12, 2017 2:49 am
Kodi on Raspberry Pi doesn't support X11 (it uses OpenGLES nad there is no standard for that), at least if you want hardware acceleration. And VNC isn't a streaming protocl even using dispmanx.
spartanhooah
Thu Jan 12, 2017 2:54 am
Rascas wrote:Kodi on Raspberry Pi doesn't support X11 (it uses OpenGLES nad there is no standard for that), at least if you want hardware acceleration. And VNC isn't a streaming protocol even using dispmanx.
I don't understand. I'm not using X11 (as far as I'm aware), and I'm not trying to stream through VNC. I just want to get Kodi set up over VNC, then I'll use it to stream to whatever.
Rascas
Thu Jan 12, 2017 3:04 am
Kodi isn't made to stream. Kodi is meant to be used directy not with VNC. And Kodi in the RPi doesn't support X11. The end.
spartanhooah
Thu Jan 12, 2017 3:07 am
You're being quite dismissive. If you read my previous posts, I was able to get Kodi working fine over VNC (which in my understanding is not X11). Kodi may not be made for streaming out-of-the-box, but it certainly can be used for that (c.f. http://www.wirelesshack.org/a-guide-to- ... shows.html).
Rascas
Thu Jan 12, 2017 3:10 am
So what do you want then ?
Rascas
Thu Jan 12, 2017 3:12 am
So what do you want then ? We don't support illegal/blacklisted addond here
spartanhooah
Thu Jan 12, 2017 3:21 am
I would like help getting the base Kodi (without any addons) back to the state that I had it before - where I could do some setup over VNC. If you think the Kodi forums would be more appropriate for that discussion, then just say so.
Rascas
Thu Jan 12, 2017 3:33 am
VNC is dependent of X11. Kodi on the RPi uses OpenGLES and doesn't have support for X11. I any OS. Never had...
You can use the new VNC server to control it, or any dispmanx VNC server, but they aren't streaming protocls...
spartanhooah
Thu Jan 12, 2017 3:39 am
Again, if you read my previous posts, setting up Kodi with an experimental feature of VNC is exactly what I was doing. I then tried to install a newer version of Kodi and things went south. I'm merely trying to recover to where I was.
gkreidl
Thu Jan 12, 2017 8:50 am
spartanhooah wrote:Again, if you read my previous posts, setting up Kodi with an experimental feature of VNC is exactly what I was doing. I then tried to install a newer version of Kodi and things went south. I'm merely trying to recover to where I was.
You may have your special ideas about the use of kodi (which nobody seems to understand), but this is completely off topic in this thread. So start a new one with a matching title, please.
bleep42
Wed Jun 28, 2017 10:17 am
Kodi now installs and works very well with no further tweaking.
It will now even play h265 (HEVC) video at up to 1080p (1920x1080) at quite a reasonable quality, even on a Pi2!
simply do :-
sudo apt-get update
sudo apt-get install kodi
Thanks to everyone involved in making this possible.
Kevin.
Return to “Raspberry Pi OS”
