frisbone
How to disable iptables?
Fri Feb 06, 2015 4:39 pm
Anyone know how to disable the firewall (iptables) on raspbian?
Using lsmod I know its in my kernal but it doesn't show up as a service and I can't seem to use chkconfig.
I want to rule out that it is interfering with something else but I don't know how to shut it off. Please advise.
Joe Schmoe
Re: How to disable iptables?
Fri Feb 06, 2015 4:41 pm
I didn't know that (current versions of) Raspbian have a firewall (installed by default). I've never had that problem with Raspbian.
Pidora does (last time I checked) - and I figured out how to kill off the various daemons to clip its wings.
Fri Feb 06, 2015 5:08 pm
There is no firewall by default. That's why I like to recommend ufw as an easy to use firewall configuration tool.
frisbone
Fri Feb 06, 2015 5:11 pm
Hmm, so when I type "iptables -L" and it returns something and I do lsmod and I see it, it doesn't mean its installed? Anyway to know for certain?
Fri Feb 06, 2015 5:27 pm
Post the output.
Fri Feb 06, 2015 5:28 pm
iptables is built into the kernel. The default settings are to do nothing.
root@raspi3:~# iptables -L
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
frisbone
Fri Feb 06, 2015 5:34 pm
This is what I get:
pi@raspbmc:~$ sudo iptables -L
ACCEPT     all  --  anywhere             anywhere             state RELATED,ESTABLISHED
ACCEPT     all  --  192.168.0.0/24       anywhere
DROP       all  --  anywhere             anywhere
I suppose it looks like it shouldn't be blocking anything but that isn't quite the same as being disabled. Can it be turned off?
Fri Feb 06, 2015 9:59 pm
What function creates those rules? What distro are you running?
My Raspbian Wheezy gets the same as rpdom, with no rules defined.
frisbone
Fri Feb 06, 2015 10:24 pm
Hard to say what the source is as it was part of RaspBmc - I've been assuming its been built on top of Raspbian but this is what uname gives me:
pi@raspbmc:~$ uname -a
Linux raspbmc 3.12.21 #2 PREEMPT Wed Jun 11 04:53:06 UTC 2014 armv6l GNU/Linux
Turns out I was able to solve my problem without turning off iptables but it sure would be nice to know how you disable it.
Fri Feb 06, 2015 10:34 pm
RaspBMC != Raspbian
There must be something in that dead media centre that is building the iptables. Try asking on the RaspBMC forum if is still open for new members.
Or switch to OpenELEC and enjoy running a supported version of Kodi.
SeeGreatness
Thu Feb 23, 2017 12:59 am
Why are we not giving out our answeres? I need help and pepole from the future will need it too
texy
Thu Feb 23, 2017 8:14 am
SeeGreatness wrote:Why are we not giving out our answeres? I need help and pepole from the future will need it too
if you have a problem with iptables then please give as much information as possible in order for others to help you, if they can. If people can't help then they don't reply.....
Texy
nischaya
Sat May 26, 2018 2:53 am
To see if it is actually enabled type in a console:
sudo iptables -L -nv
if the output is like this, then your firewall is already disabled:
root@debian:~# sudo iptables -L -nv
Chain INPUT (policy ACCEPT 0 packets, 0 bytes)
 pkts bytes target     prot opt in     out     source               destination
Chain FORWARD (policy ACCEPT 0 packets, 0 bytes)
Chain OUTPUT (policy ACCEPT 0 packets, 0 bytes)
To make sure it is off get root and run:
echo 0 > /proc/sys/net/ipv4/ip_forward
nikoff90
Sat May 26, 2018 2:00 pm
Flush All Chains
To flush all chains, which will delete all of the firewall rules, you may use the -F, or the equivalent --flush, option by itself:
sudo iptables -F
sudo iptables-save > /etc/iptables.conf
If that is where your rules are saved on that build you might do well to look. If you dont save it will revert back at reboot Generally some sort of firewall is a good thing. Arch has a good section on iptables and basic rules.
https://wiki.archlinux.org/index.php/si ... l_firewall
foss.prime
Mon Jan 21, 2019 10:09 pm
I got here because the Pi could connect to most of the local network, but not VPN users or other subnets.
The issue was that the subnet mask was wrong, it defaults to /8 in the gui, which meant it would only talk to the gateway if the destination IP is outside of /8, instead of /24 which is far more typical. Ping'ing and Netcat all appeared as if there was a firewall issue, at the end of the day it was an atypical routing misconfiguration, the subnet was too wide.
Return to “Raspberry Pi OS”
