marian42
wiringpi with another user
Sat Jan 03, 2015 7:57 pm
I set up wiringPi like described here.
It works with the user pi.
Now I run
sudo -u user1 /usr/local/bin/gpio export 17 out
and log in as user1 and try to run the python script. It runs without errors but commands to the GPIO pins are ignored.
What did I do wrong?
Re: wiringpi with another user
Sun Jan 04, 2015 12:46 am
Try using the gpio utility. It looks after all security problems for you, gpio runs as a setuid root program.
http://wiringpi.com/the-gpio-utility/
This is a doctor free zone.
marian42
Sun Jan 04, 2015 11:46 pm
I just tested this tool and I can write to pins with this as both users.
Still no success with the python script (only as user pi).
joan
Sun Jan 04, 2015 11:53 pm
marian42 wrote:I just tested this tool and I can write to pins with this as both users.
Does the other user need to be added to /etc/sudoers ?
iinnovations
Mon Jan 05, 2015 12:12 am
What is your python script? I use the gpio utility with subprocess.call() with no problems.
Look here for the commands preceded with 'wp' like wptogglegpiopin():
https://github.com/iinnovations/iicontr ... actions.py
Demonstration here:
http://www.cupidcontrols.com/2014/09/di ... -wiringpi/
C
CuPID Controls :: Open Source browser-based sensor and device control
interfaceinnovations.org/cupidcontrols.html
cupidcontrols.com
marian42
Tue Jan 06, 2015 4:09 pm
Just added the user, still the same problem.
The script is linked in the first post. The script works fine, it just only works with user pi and not with the user user1.
iinnovations
Tue Jan 06, 2015 6:24 pm
Login as user user1 and run gpio. Are you piping call into a file? It should produce error output.
This must be a perms issue with user1. Some googling around 'wiringpi permissions gpio' should get you what you need. Or a 'which gpio' and perms listing of it.
cupidcontrols.com
marian42
Tue Jan 06, 2015 7:10 pm
How do I do that?
There is no error output.
jamiesk
Tue Jan 06, 2015 10:28 pm
How do I do that?
sudo -u user1 /usr/local/bin/gpio export 17 out > error.file
then
more error.file
to see the output
Pi1 (Nov 2012 loft)= 1KW immersion controller for Solar panel
Pi2 (Jan 2013 living room)=Play thing
Pi3 (Feb 2013 mobile)= Play thing with Tandy Ladder board,breakout board,Nokia display
http://www.raspberrypi.org/phpBB3/viewtopic.php?f=26&t=28193
marian42
Tue Jan 06, 2015 11:01 pm
The more command doesn't output anything.
jamiesk
Tue Jan 06, 2015 11:13 pm
marian42 wrote:The more command doesn't output anything.
Guess that means this command worked ok. And a "ls -al" will show the file is zero length too
Tue Jan 06, 2015 11:23 pm
Try the less command or the cat command.
Or take a look at whether the file has any data with ls -la filename or wc filename.
marian42
Tue Jan 06, 2015 11:24 pm
Yes
Tue Jan 06, 2015 11:50 pm
Try
sudo -u user1 /usr/local/bin/gpio export 17 out 2> error.file
marian42
Wed Jan 07, 2015 10:47 am
Same result. I'm wondering how there could be permission problems with this command since it's executed with superuser rights so it can do anything it wants anyway. I'd expect problems to occur with the commands that don't have superuser rights (the python script).
Return to “Raspbian”
