matthewh
CRONTAB
Wed Dec 31, 2014 7:33 pm
I added this to /etc/crontab
*/5 * * * * root cd / && run-parts --report /etc/cron.fiveminute
Then restarted cron. Why won't any of my scripts in /etc/cronfiveminute run?
jamiesk
Re: CRONTAB
Fri Jan 02, 2015 3:14 pm
You might need to specify something else too. I have a script which run every 5 minutes between two hours...
*/5 9-16 * * * /home/pi/sma.cron
Have a go with the hours, even 0-23 and it might work for you.
Pi1 (Nov 2012 loft)= 1KW immersion controller for Solar panel
Pi2 (Jan 2013 living room)=Play thing
Pi3 (Feb 2013 mobile)= Play thing with Tandy Ladder board,breakout board,Nokia display
http://www.raspberrypi.org/phpBB3/viewtopic.php?f=26&t=28193
emgi
Re: CRONTAB
Fri Jan 02, 2015 3:49 pm
I'm a bit unsure about the syntax of your ctrontab entry. :|
As far as my experience goes, they look like the one from the previous poster.
Special care must be taken to set all file paths correctly. To be safe, you should even consider to do this for system files.
At least things should be tested thoroughly and file paths are to be the first suspects when things are failing.
Always begin with running the script from the command line. Only put it in crontab when cli execution works.
One of the many explanations on the web: http://v1.corenominal.org/howto-setup-a-crontab-file/
/emgi
Re: CRONTAB
Fri Jan 02, 2015 4:05 pm
A line like
*/5 * * * *   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.fiveminute )
should run every five minutes. Did you reload cron with /etc/init.d/cron reload after updating /etc/crontab? Are all of the scripts in /etc/cron.fiveminute owned by root and executable?
This is a doctor free zone.
matthewh
Re: CRONTAB
Fri Jan 02, 2015 5:49 pm
Here is default /etc/crontab on raspberry pi.
17 * * * * root cd / && run-parts --report /etc/cron.hourly
25 6 * * * root test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )
47 6 * * 7 root test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.weekly )
52 6 1 * * root test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.monthly )
I simply created /etc/cron.fiveminute with sudo mkdir then added:
Pretty much copying the default cron.hourly
Then I rebooted.
ghans
Re: CRONTAB
Another caveat : run-parts disallows scripts with "file extensions"
like .sh or .old or .bak (this is by design).
ghans
matthewh
Re: CRONTAB
Fri Jan 02, 2015 5:54 pm
ghans wrote:Another caveat : run-parts disallows scripts with "file extensions"
ghans
That would be the issue. Why is this? Can I change it?
Re: CRONTAB
Fri Jan 02, 2015 6:00 pm
run-parts --regex="^.*sh" --report /etc/cron.fiveminutes # run anything named *.sh
matthewh
Re: CRONTAB
Tue Jan 13, 2015 10:53 pm
What is strange is I have a Centos 5.x server with exact same line in crontab using run-parts and it will execute anything in that directory regardless of extension or no extension.
ghans
Re: CRONTAB
Wed Jan 14, 2015 7:36 am
It's Debian specific.
man run-parts
has more info.
ghans
Return to “Raspbian”
