aristosv
command execution issue
Fri Dec 12, 2014 11:48 am
I am running a script on boot (on boot.sh) that performs 2 commands.
/usr/bin/mpg123 -Z -q /root/music/*
cp test.sh /root
My problem is that the file is not getting copied because the first command will not let the second command get executed.
How can I fix this?
DirkS
Re: command execution issue
Fri Dec 12, 2014 12:12 pm
You can make the first command run in the background by putting an '&' at the end of the command.
/usr/bin/mpg123 -Z -q /root/music/* &
cp test.sh /root
Alternatively you could run the copy *before* starting the player...
Gr
Dirk.
Fri Dec 12, 2014 12:16 pm
aristosv wrote:I am running a script on boot (on boot.sh) that performs 2 commands.
cp test.sh /root
cp test.sh /root
add an & to force mpg123 to run in the background.
Return to “Raspberry Pi OS”
