Add user silently
Posted: Mon Dec 08, 2014 7:54 pm
by aristosv
I am using Raspbian Wheezy Version: September 2014. I would like to create a script or a one-liner if possible, to add a new user silently/unattendedly. I want this user to have root privileges. Is this possible to do?
From what I could gather, I need one command to add the user, one command to add the user to the root group, and I also need to modify a file. Can all this be done automatically/silently?
Re: Add user silently
Posted: Mon Dec 08, 2014 8:18 pm
by rpdom
man adduser ?
Posted: Mon Dec 08, 2014 9:01 pm
by beta-tester
aristosv wrote:Hello,
sudo adduser mrX && sudo adduser mrX sudo
or with quiet
sudo adduser --quiet mrX && sudo adduser --quiet mrX sudo
or direct output to null
sudo adduser mrX 1>/dev/null 2>/dev/null && sudo adduser mrX sudo 1>/dev/null 2>/dev/null
... mrX will be member of sudo or do you really want root?
Posted: Tue Dec 09, 2014 9:10 am
by aristosv
Thanks for the info. I really want the user to be a member of root, not sudo.
Will the commands you provided prompt for password?
Posted: Tue Dec 09, 2014 9:28 am
by beta-tester
aristosv wrote:Thanks for the info. I really want the user to be a member of root, not sudo.
don't be so shy or lazy... try it out yourself!
(not, if you are logged in and am a sudoer)
btw: you also may generate an account and its membership offline if you edit /etc/password, password-, group, group-, shadow, shadow- files ;)
Posted: Tue Dec 09, 2014 9:39 am
by DougieLawson
man adduser
use adduser with --uid 0 --gid 0 to add a root user.
