Nathan Phillips
X starts at boot after upgrade to Jessie
Fri Nov 28, 2014 2:01 pm
After upgrading a new and minimally altered Raspbian Wheasy standard image to Raspbian Jessie, X starts at boot. I can't for the life of me see what's causing it to start up. I need all the memory I can get free so would like to prevent this.
sudo /etc/init.d/lightdm stop
does manually shut it down.
lightdm is disabled for all runlevels.
Any further clues?
plugwash
Re: X starts at boot after upgrade to Jessie
Sat Nov 29, 2014 4:15 pm
Currently upgrades from wheezy to jessie will by default switch to systemd (this is contravesial within Debian and may or may not be the case when jessie finally releases). This has the unfortunate side affect of re-enabling services that were disabled in sysvinit.
I think
service lightdm disable
Should solve your problem if this is the case.
Nathan Phillips
Wed Dec 03, 2014 12:31 am
Wonderful, thank you for your help.
mikerr
Wed Dec 03, 2014 2:38 pm
the above didn't work for me, but this did:
sudo systemctl disable lightdm.service
Nathan Phillips
Wed Dec 03, 2014 3:25 pm
The best command to use is probably:
sudo systemctl set-default multi-user.target
But the post above identifying that it's systemd rather than sysvinit in Jessie was the information I needed to realise this is what I needed to do.
itsmedoofer
Wed Dec 03, 2014 5:22 pm
Is this why the Raspi-config boot options don't work in Jessie ?
mikerr
Wed Dec 03, 2014 6:33 pm
raspi-config hasn't been updated to talk systemd, so many of its boot options won't work.
e.g. boot to desktop, ssh enable/disable
Options for overclocking / camera / memory split still work ok though.
itsmedoofer
Wed Dec 03, 2014 8:35 pm
Gotcha, thanks Mike apprecated.
sparticle
Wed Feb 11, 2015 6:29 pm
Just wanted to say many thanks for this post, as I had been banging my head trying to get Jessie to boot to the command prompt.
Do you happen to know the reverse command to get it to boot the desktop automatically after disabling it with:
Cheers
Spart
Wed Feb 11, 2015 7:16 pm
Cheers
Spart
sudo systemctl set-default graphical.target
There's some good docs I found here: http://fedoraproject.org/wiki/Systemd
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3B*3, 3B+
Please post ALL technical questions on the forum. Do not send private messages.
sparticle
Wed Feb 11, 2015 7:52 pm
That's great many thanks. Like black magic to me :)
Cheers
Spart
bullwinkle
Thu Feb 12, 2015 4:05 am
Hi
I think you just need to put a 3 in the cmdline.txt file to switch to run level 3
or
systemd.unit=multi-user.target in the cmdline.txt file should work also.
I've not tested this on the Pi, but it works on my BBB.
Return to “Raspbian”
Who is online
Users browsing this forum: No registered users and 9 guests
