deleenheir
Running long term of an SD card/USB-stick
Mon Nov 10, 2014 11:39 am
I have a raspberry pi that runs raspbmc + mysql + web server + some other stuf.
I have it installed on a USB stick.
Now after 6 months the system is getting unstable.
The mysql db might be doing a lot of disc work. It executes +/- 20 querries every minute
Could it be the USB stick is already wearing out?
i'm getting errors in dmesg:
EXT4-fs error (device sda1): ext4_ext_check_inode:481: inode #788007: comm ls: pblk 0 bad header/extent: invalid extent entries - magic f30a, entries 1, max 4(4), depth 128(128)
ReBoot
Re: Running long term of an SD card/USB-stick
Tue Nov 11, 2014 2:27 pm
This is indeed entirely possible. A friend of mine killed his SD card this way a while ago.
Tue Nov 11, 2014 2:42 pm
deleenheir wrote:I have a raspberry pi that runs raspbmc + mysql + web server + some other stuf.
Install the Operating System on a Standard Hard Drive, leaving the Boot Partition on the SD Card, Flash Media has a I/O life span and will eventually fail
RPi 4B 4GB (SSD Boot)..
RaTTuS
Contact: Twitter YouTube
Tue Nov 11, 2014 2:46 pm
you can get 1.8" real hard disk drives if you want to keep the package really small
Covfefe
deleenheir
Wed Nov 12, 2014 7:14 pm
just to confirm:
I reinstalled raspbian completely... 2 days later i got the same message...
So it seems I managed to kill a kingston dt rubber 3.0 16gb in about 1 year.
I find it curious there aren't more people having these problems...
Will an ssd be as susceptible?
ReBoot
Wed Nov 12, 2014 7:56 pm
Use a RAM-disk. That's what the co-worker of mine is doing.
DirkS
Wed Nov 12, 2014 9:14 pm
ReBoot wrote:Use a RAM-disk. That's what the co-worker of mine is doing.
For what?
ReBoot
Wed Nov 12, 2014 9:32 pm
For not killing the card with frequent writes.
Wed Nov 12, 2014 9:42 pm
Is there enough free RAM to make a big enough RAM disk?
DirkS
Wed Nov 12, 2014 9:47 pm
ReBoot wrote:For not killing the card with frequent writes.
Yes, that's obvious. But what are you going to store on it specifically in the OPs scenario?
And RAM is going to be a squeeze anyway and you're suggesting to take some (or a lot) away.
Gr.
Dirk.
Lob0426
Thu Nov 13, 2014 5:26 am
I recommend you disable the swap file that is in Raspbian (100mb swap). I use a separate USB stick that I created a swap partition on. The USB stick is an old 512mb. More than enough for swap. If it is killed it is easy and cheap to replace. Raspbian finds it and uses it with no settings necessary.
This will remove some of the writes to your OS card so it should last longer for you!
Motorola Lapdock with Pi2B
http://rich1.dyndns.tv/
Marty
3600 writes per hour when idle
Sun Nov 30, 2014 9:06 pm
Does an idle Raspbian system performs 3600 writes per hour?
The green led on my Raspberry Pi B+ faintly flashes about 60 times a minute when the system is idle.
(When I trigger activity like logging in, then the green led flashes brightly.)
If these faint flashes represent a write action to the microSD card, that would mean that the card is written to about 3600 times per hour. When using the Pi as an always on home server, write wearing on the SD card would become an issue rather quickly.
I'm running on a freshly installed Raspbian Linux 3.12.28+ #709 PREEMPT Mon Sep 8 15:28:00 BST 2014 armv6l GNU/Linux (downloaded from: http://downloads.raspberrypi.org/raspbian_latest).
Do the faint flashes indicate microSD writes?
What causes the frequent writes during idle time?
How can they be decreased?
Return to “Raspberry Pi OS”
