wanted
Posted: Sat Nov 08, 2014 4:43 pm
by vectraboyv6
hi,
i need a raspbain image with the touchscreen drivers included please?
Re: wanted
Posted: Sat Nov 08, 2014 4:56 pm
by joan
vectraboyv6 wrote:hi,
Do you have any idea of how many different display/touchscreen combinations there are?
Re: wanted
Posted: Sat Nov 08, 2014 5:26 pm
by vectraboyv6
hi,
the display is via the hdmi port.
touch screen is via usb and requires usctouchscreen.c but there is no tutorial on how to intergate this.
any help would be great
Re: wanted
Posted: Sat Nov 08, 2014 6:59 pm
by DirkS
Not enough information. What is the output of lsusb?
Do you have a link to a datasheet or at least more info on the touchscreen?
Gr.
Dirk.
Re: wanted
Posted: Sat Nov 08, 2014 8:31 pm
by mikronauts
vectraboyv6
It would be best if you posted a link to his specific touch controller... or at least the lsusb output
Re: wanted
Posted: Sat Nov 08, 2014 9:11 pm
by vectraboyv6
login as: pi
pi@192.168.1.140's password:
Linux raspberrypi 3.6.11+ #538 PREEMPT Fri Aug 30 20:42:08 BST 2013 armv6l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Fri Nov 7 11:18:07 2014
lpi@raspberrypi ~ $ lsusb
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp.
Bus 001 Device 006: ID 0451:2046 Texas Instruments, Inc. TUSB2046 Hub
Bus 001 Device 007: ID 04b3:4670 IBM Corp.
Bus 001 Device 008: ID 0596:0001 MicroTouch Systems, Inc. Touchscreen
pi@raspberrypi ~ $ ^C
pi@raspberrypi ~ $
hi thanks for the replys, here is my lsusb. The monitor in question is a ibm 4820-48t. the touchscreen works on win7 , unbumtu 12.2 and the standard raspbmc install.
the touchscreen part is a 3m ex II and is listed in the usbtouchscreen.c file
thanks stuart
Re: wanted
Posted: Sat Nov 08, 2014 9:33 pm
by DougieLawson
I don't think you'll be able to get that screen running on a Raspberry Pi. The driver includes closed source programs that are only built for Intel X86 systems. If you can't find a driver specially built for ARMv6 systems then you have absolutely no hope of getting it running.
Re: wanted
Posted: Sat Nov 08, 2014 9:52 pm
by vectraboyv6
this is the start of the usbtouchscreen.c
* usbtouchscreen.c
* Driver for USB Touchscreens, supporting those devices:
* - eGalax Touchkit
* includes eTurboTouch CT-410/510/700
* - 3M/Microtouch EX II series
* - ITM
* - PanJit TouchSet
* - eTurboTouch
* - Gunze AHL61
* - DMC TSC-10/25
* - IRTOUCHSYSTEMS/UNITOP
* - IdealTEK URTC1000
* - General Touch
* - GoTop Super_Q2/GogoPen/PenPower tablets
* - JASTEC USB touch controller/DigiTech DTR-02U
* - Zytronic capacitive touchscreen
* - NEXIO/iNexio
* - Elo TouchSystems 2700 IntelliTouch
* - EasyTouch USB Dual/Multi touch controller from Data Modul
* Copyright (C) 2004-2007 by Daniel Ritz <daniel.ritz@gmx.ch>
* Copyright (C) by Todd E. Johnson (mtouchusb.c)
* This program is free software; you can redistribute it and/or
* modify it under the terms of the GNU General Public License as
* published by the Free Software Foundation; either version 2 of the
* License, or (at your option) any later version.
the screen is clearly listed ( * - 3M/Microtouch EX II series) so I need to interagte this into the raspbain image, as said it works with raspbmc. but want to to work in the startx and then python tkinter.
thanks stuart
Re: wanted
Posted: Sun Nov 09, 2014 8:43 am
by ame
DougieLawson wrote:I don't think you'll be able to get that screen running on a Raspberry Pi. The driver includes closed source programs that are only built for Intel X86 systems. If you can't find a driver specially built for ARMv6 systems then you have absolutely no hope of getting it running.
He said it works with Raspbmc, so the driver ought to exist in some form.
Re: wanted
Posted: Sun Nov 09, 2014 9:26 am
by DirkS
ame wrote:DougieLawson wrote:I don't think you'll be able to get that screen running on a Raspberry Pi. The driver includes closed source programs that are only built for Intel X86 systems. If you can't find a driver specially built for ARMv6 systems then you have absolutely no hope of getting it running.
Just had a look and Raspbmc comes with a whole bunch of touch drivers, including the one mentioned above.
Gr.
Dirk.
Re: wanted
Posted: Sun Nov 09, 2014 9:44 am
by vectraboyv6
any ideas on how to intergrate usbtouchscreen.c into raspbian then guys????
Re: wanted
Posted: Sun Nov 09, 2014 6:49 pm
by vectraboyv6
bump
Re: wanted
Posted: Mon Nov 10, 2014 3:40 pm
by topguy
You recompile the kernel with the "usbtouchscreen" module set to "enabled" I guess..
Edit 1:
( And if you feel the responses are a bit slow, its probably because of the really bad title on this thread. )
Edit 2:
And if you had put "usbtouchscreen.c" into the search field you would have found this thread:
http://www.raspberrypi.org/forums/viewt ... .c#p416765
Re: wanted
Posted: Thu Nov 13, 2014 9:40 am
by vectraboyv6
Thanks,
I now have the touchscreen working a calibrated correctly.
I shall endeavour to post a you tube video guide in the near future
