bob12603
Can I sudo startx but then run Chromium as not root?
Thu Nov 06, 2014 9:08 pm
I have Chromium and I'd like to use it via the desktop. But I use sudo startx to start the desktop because so many more things work that way. But when I then try to start Chromium it says that Chromium can't run as root. (I know that in fact it can but I also know that that's a really bad idea.) So ... is there some way to start Chromium via the desktop (started via sudo startx) but have it run under some user other than root?
Thanks, Bob
whoami
Re: Can I sudo startx but then run Chromium as not root?
Thu Nov 06, 2014 9:38 pm
Does this work:
su -c chrome -s /bin/sh username
ghans
Fri Nov 07, 2014 11:54 am
Can you elaborate on that ?
ghans
RaTTuS
Contact: Twitter YouTube
Fri Nov 07, 2014 11:57 am
running x as sudo is really not the way you want to go
Covfefe
ReBoot
Tue Nov 11, 2014 10:26 am
Suggestion: use raspi-config to tell the system to boot to desktop and start Chromium from there. Viola!
DirkS
Tue Nov 11, 2014 10:32 am
ReBoot wrote:Suggestion: use raspi-config to tell the system to boot to desktop and start Chromium from there. Viola!
I think you missed the point here...
Gr.
Dirk.
Return to “Raspberry Pi OS”
