bleepian
Crontab issues
Sun Nov 02, 2014 11:08 am
I've got problems with crontab entries. Everything looks alright, I think, so I'm stumped here.
Setting up a rsync backup for another machine over ssh but having problems with that I'm trying some more basic stuff to see what might be wrong.
This works, so crontab works:
47 10 * * * /bin/echo "hello world" > /home/pi/hello
This does not work. It gives an empty ls-test file in home/pi.
53 11 * * * bin/ls /home/pi > /home/pi/ls-test
What might be wrong? I can't see anything incorrect. Tried both user crontab and su crontab.
DirkS
Re: Crontab issues
Sun Nov 02, 2014 11:15 am
There's no '/' in front of the path to 'ls', so the command is probably bot found.
Gr.
Dirk.
bleepian
Re: Crontab issues
Sun Nov 02, 2014 1:37 pm
Duh! Of course...
Now that works. Thank you.
Next step, I can't get this to work. Same thing, empty file in /home/pi. It does work in terminal, not in cron:
21 14 * * * /usr/bin/ssh -p 55555 [email protected] "/bin/ls /mnt/WORK/" > /home/pi/ls-work-test
And while I'm at it, this is what I want to finally do, can't get it to work in cron (Does work in terminal, key pair and such is setup so no password login required)
30 14 * * * /usr/bin/rsync -ra --exclude-from=/home/pi/rsync-excludes -e '/usr/bin/ssh -p 55555' [email protected]:/mnt/WORK/* /mnt/WORK-BUP/
eltrasimaco
Re: Crontab issues
Sun Nov 02, 2014 6:19 pm
As it's running in background, use the -n swith (ssh -n xxxxxxxxxxxxxxxx)
bleepian
Re: Crontab issues
Thu Nov 19, 2015 11:01 am
The issue was that cron uses sh and not bash... telling it to us bash instead makes it work.
21 14 * * * bash -c "/usr/bin/ssh -p 55555 [email protected] "/bin/ls /mnt/WORK/" > /home/pi/ls-work-test"
Return to “Raspbian”
