sander2
"RuntimeError: Conflicting edge detection events already"
Fri Oct 10, 2014 1:06 pm
I get "RuntimeError: Conflicting edge detection events already exists for this GPIO channel" with an easy piece of GPIO code (based on the code on http://makezine.com/projects/tutorial-r ... nd-python/ )
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
GPIO.setup(23, GPIO.IN, pull_up_down = GPIO.PUD_DOWN)
while True:
	GPIO.wait_for_edge(23, GPIO.RISING)
	print("Button 1 Pressed")
	GPIO.wait_for_edge(23, GPIO.FALLING)
	print("Button 1 Released")
GPIO.cleanup()
Problem occurs as soon as I disconnect wire GPIO23 from 3V3. And it happens every time.
Python GPIO version is RPi.GPIO-0.5.7
$ sudo python pin23-flank.py
Button 1 Pressed
  File "pin23-flank.py", line 7, in <module>
Seems related to:
http://sourceforge.net/p/raspberry-gpio ... ickets/72/
http://blog.scribblechunks.com/raspberry-pi-gpio-issue/
Tips how to solve this or how to proceed?
croston
Re: "RuntimeError: Conflicting edge detection events already
Fri Oct 10, 2014 1:25 pm
I have developed the fix for this - it will be in the next release. In the meantime, you can install a development version that contains the fix:
http://sourceforge.net/p/raspberry-gpio ... age=1#ccfb
Let me know if it solves your problem!
sander2
Fri Oct 10, 2014 2:15 pm
EDIT:
Even after the "sudo apt-get remove python-rpi.gpio python3-rpi.gpio" followed by the pip / pip-3.2 install, the program goes into a loop.
I will rerun the whole procedure just to be sure
Older message:
Thanks. I did that; from my history:
sudo python pin23-follow-based-on-polling.py
sudo apt-get install python-dev python3-dev
sudo apt-get install mercurial
sudo apt-get install python-pip python3-pip
sudo pip install -e hg+http://hg.code.sf.net/p/raspberry-gpio-python/code#egg=RPi.GPIO
sudo pip-3.2 install -e hg+http://hg.code.sf.net/p/raspberry-gpio-python/code#egg=RPi.GPIO
The code now runs without errors, but just one "button press" (+release) results in an endless automatic list of
Button 1 Released
Button 1 Pressed
Button 1 Released
Button 1 Pressed
Button 1 Released
Button 1 Pressed
Button 1 Released
Button 1 Pressed
Button 1 Released
Button 1 Pressed
Button 1 Released
Button 1 Pressed
Button 1 Released
Button 1 Pressed
Button 1 Released
Button 1 Pressed
Button 1 Released
Button 1 Pressed
Button 1 Released
... until I press Control C
That's not good, is it?
sander2
Fri Oct 10, 2014 2:27 pm
Uninstall RPi.GPIO:
pi@raspberrypi ~/pinnetje $ sudo pip uninstall RPi.GPIO
Uninstalling RPi.GPIO:
Proceed (y/n)? y
  Successfully uninstalled RPi.GPIO
You have new mail in /var/mail/pi
pi@raspberrypi ~/pinnetje $ sudo pip-3.2 uninstall RPi.GPIO
Proceed (y/n)? y
and then:
pi@raspberrypi ~/pinnetje $ python
Python 2.7.3 (default, Mar 18 2014, 05:13:23)
[GCC 4.6.3] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import RPi.GPIO
How is that possible? Uninstalled, but still there?
:shock:
croston
Sat Oct 11, 2014 8:10 pm
Sorry - it turns out that my instructions were wrong. To get out of the weird problem where it doesn't uninstall properly:
sudo nano /usr/local/lib/python2.7/dist-packages/easy-install.pth
Delete the line containing rpi.gpio
sudo nano /usr/local/lib/python3.2/dist-packages/easy-install.pth
I have fixed your latest problem of the repeating edges (https://sourceforge.net/p/raspberry-gpi ... s/78/#82b0).
To test the fix:
sudo pip install hg+http://hg.code.sf.net/p/raspberry-gpio-python/code#egg=RPi.GPIO
sudo pip-3.2 install hg+http://hg.code.sf.net/p/raspberry-gpio-python/code#egg=RPi.GPIO
Note the lack of the '-e' in the pip install commands that was there before - this is what was causing the problems uninstalling.
To uninstall and return back to the standard version in Raspbian:
sudo apt-get install python-rpi.gpio python3-rpi.gpio
It should work properly this time. I'm sure you'll let me know if it doesn't!
sander2
Sun Oct 12, 2014 7:03 pm
Trying to install, I get:
pi@raspberrypi ~/pinnetje $ sudo pip install hg+http://hg.code.sf.net/p/raspberry-gpio-python/code#egg=RPi.GPIO
Requirement already satisfied (use --upgrade to upgrade): RPi.GPIO from hg+http://hg.code.sf.net/p/raspberry-gpio-python/code in ./src/rpi.gpio
Cleaning up...
pi@raspberrypi ~/pinnetje $ sudo pip-3.2 install hg+http://hg.code.sf.net/p/raspberry-gpio-python/code#egg=RPi.GPIO
Cleaning up...
So I tried:
pi@raspberrypi ~/pinnetje $ sudo pip install --upgrade hg+http://hg.code.sf.net/p/raspberry-gpio-python/code#egg=RPi.GPIO
Requirement already up-to-date: RPi.GPIO from hg+http://hg.code.sf.net/p/raspberry-gpio-python/code in ./src/rpi.gpio
Cleaning up...
pi@raspberrypi ~/pinnetje $ sudo pip-3.2 install --upgrade hg+http://hg.code.sf.net/p/raspberry-gpio-python/code#egg=RPi.GPIO
Cleaning up...
No error message, but:
>>> import RPi.GPIO
  File "<stdin>", line 1, in <module>
ImportError: No module named RPi.GPIO
So not good. :(
Tips how to proceed?
sander2
Sun Oct 12, 2014 7:16 pm
Ah ... got it working!
There was a 'src' directory owned by root in the working directory. It seemed to contain RPi.GPIO stuff.
I removed it, and to be sure, created a dummy working directory:
sudo rm -rf src
mkdir dummy
cd dummy/
sudo pip install 'hg+http://hg.code.sf.net/p/raspberry-gpio-python/code#egg=RPi.GPIO'
Bingo! The code below is now working and report power consumption ... :)
while True:
GPIO.cleanup()
Thank you for your help and your code.
sander2
Mon Oct 13, 2014 7:37 pm
Question: why is waiting for GPIO.RISING only (as in the second code snippet) not enough? Only waiting for GPIO.RISING will print an endless of "up" after the first GPIO.RISING trigger. I would expect that print only to happen once at the GPIO.RISING trigger, and then not until the following GPIO.RISING trigger?
In other words: why do I need to explicitly wait for the GPIO.FALLING?
Working if waiting for GPIO.RISING and then waiting for GPIO.FALLING:
#!/usr/bin/env python
########## Main Loop
while True:
	# wait for pin going up
	print "up"
	# and wait for pin going down
	print "down"
Not working if only waiting for GPIO.RISING:
while True:
	print "up"
croston
Mon Oct 13, 2014 7:39 pm
I'll take a look when I get back from the pub!
sander2
Mon Oct 13, 2014 7:53 pm
croston wrote:I'll take a look when I get back from the pub!
In the pub? Good for you! But ... no 'phone stacking' in place, I guess? ;)
sander2
Wed Oct 15, 2014 12:13 pm
Hi Croston, any news on this?
FWIW: I'm just suprised, and I have it working with the extra FALLING, so no big deal if it must stay that way.
jbebel
Sat Oct 18, 2014 3:29 am
Same thing here. I'm just calling GPIO.wait_for_edge(state_change, GPIO.FALLING), without having a corresponding GPIO.RISING wait, and it gets stuck in a loop as soon as it sees the first falling edge. Is this a bug, or an inappropriate way to use the library?
sander2
Sat Oct 18, 2014 1:18 pm
I have put my code on github: https://github.com/sanderjo/GPIO-counter
Full description: https://github.com/sanderjo/GPIO-counte ... /README.md
$ sudo ./gpio-counter.py
./gpio-counter.py <gpio-pin-number> <filename> [debug]
Example usage:
./gpio-counter.py 23 /path/to/mylogfile
./gpio-counter.py 23 /path/to/mylogfile debug
If you use it, I would like to hear feedback.
GeofP
Tue Nov 18, 2014 1:18 pm
There is still a problem with RPi.GPIO 0.5.8. Please see my comments at: http://www.raspberrypi.org/forums/viewt ... 19#p642319.
After detecting the falling edge,
while True:
the following code loops without any further edge changes.
Return to “Raspberry Pi OS”
