TwinyTwice
Need Help for a 2.8" USB TFT Display drivers
Mon Sep 15, 2014 7:44 am
Hi, i'm a French newbies in Raspberry Pi world and i've a big problem with my Robopeak 2.8" TFT USB Display.
I've already tried to run this tuts : http://www.dfrobot.com/community/robope ... ry-pi.html
But, I can't run my Robopeak TFT screen.
I also try to re-compile the kernel myself by following the instructions here:
https://github.com/robopeak/rpusbdisp
and here:
http://elinux.org/RPi_Kernel_Compilation
but I can't do it with my little skills!
I come here to get help or to find a kind soul who would be able to compile an img disk for me, that i can install to my RPi B+ and for my USB TFT screen Robopeak finally works!
My setup is:
- RPi B+
- NOOBS/Raspian (last release)
Re: Need Help for a 2.8" USB TFT Display drivers
Mon Sep 15, 2014 8:25 am
https://github.com/notro/fbtft/wiki appears to have support for your device
This is a doctor free zone.
TwinyTwice
Mon Sep 15, 2014 6:24 pm
Thanks a lot DougieLawson !
I will try to install these drivers, but being a newbies and French, it will be a little difficult i think!
I advise you to download an img disk already compiled or install only these drivers?
Knowing that I would like to have the latest version of Raspian.
Mon Sep 15, 2014 6:27 pm
http://raspberrypi.org/forums/viewtopic ... 68#p607768 I found it easy enough to add Notro's kernel & drivers to an existing copy of Raspbian.
TwinyTwice
Mon Sep 15, 2014 6:33 pm
Wow, thanks a lot again! Exactly what i need!
TwinyTwice
Tue Sep 16, 2014 12:30 am
Hi DougieLawson, just one question more ;-)
At step 7 : create /etc/modprobe.d/fbtft_device.conf create one line
options fbtft_device custom name=fb_ili9341 rotate=90 buswidth=8 bgr=1 speed=32000000 gpios=reset:25,dc:24,led:18
I guess my name of display is not the same and that i should put other things as settings? if so could you help me, i'm confused!
The name is "rp_usbdisplay" or "fb_rp_usbdisplay" ?
And for the settings , i suppose i don't need the rotate set...
Wed Sep 17, 2014 1:51 am
What controller chip does your display have?
Is using the custom driver to load the fb_ili9341 driver and pass a bunch of parms to it for an unsupported LCD. It's wired using sck, miso, mosi, ce0, gpio25 (reset), gpio24 (d/c) and gpio18 (lite)
If your LCD is on the supported list at: https://github.com/notro/fbtft/wiki/LCD-Modules
You'd use
options fbtft_device name=supporteddevicenamehere
My display will be supported in the next version of Notro's code
  .name = "adafruit28",
  .spi = &(struct spi_board_info) {
    .modalias = "fb_ili9341",
    .max_speed_hz = 32000000,
    .mode = SPI_MODE_0,
    .platform_data = &(struct fbtft_platform_data) {
      .display = {
        .buswidth = 8,
        .backlight = 1,
      .bgr = true,
      .gpios = (const struct fbtft_gpio []) {
        { "reset", 25 },
        { "dc", 24 },
        { "led", 18 },
So in future I'll use
options fbtft_device name=adafruit28
and the same wiring scheme I'm using today.
TwinyTwice
Wed Sep 17, 2014 2:28 pm
Ok Thanks, but, my screen is not supported and not listed !
I've contacted Robopeak and a new img is available to download, the TFT LCD work fine after install of the newest img !
Thanks for your help !
Actually, just one little problem, their new img boot directly on a X Window Login screen, and i wanted boot on console screen !
i've followed this step, as indicated here : http://www.robopeak.com/docs/doku.php?i ... sp_faq#q11
$ sudo nano /boot/cmdline.txt
and add this
fbcon=font:ProFont6x11 fbcon=map:1
$ sudo nano  /etc/init.d/launch_desktop.sh
and comment this
#su -c startx pi &
But actually, no boot on console, always on X Login window !
Return to “Raspbian”
