Joe Schmoe
Kernel disabling interrupt #32
Tue Aug 26, 2014 1:38 pm
I was messing around (as root) with the commands found at:
http://g0kao.wordpress.com/2013/08/08/ ... berry-pi/
Specifically, I did:
udevadm info -a -p  $(udevadm info -q path -n /dev/ttyUSB0)
This worked a few times, then I got a "write(1)" style message from the kernel with the above message (paraphrased - don't have the exact text in front of me). And the machine (the Pi) completely froze and had to be power cycled.
Is this a known bug? I've never seen this message before.
It is related to the "udevadm" stuff, or is that just a coincidence?
Joe Schmoe
Re: Kernel disabling interrupt #32
Tue Aug 26, 2014 8:11 pm
No coincidence. Definitely related to udevadm. It has now happened a second time - running as user pi this time. If nothing else, makes a good denial-of-service attack.
See attached picture.
Once you get this message, the entire USB subsystem is messed up (though still [barely] functional - enough to shut system down).
Who else does this need to be reported to?
I can give more details (uname output, etc, if needed)
KernelMsg.zip
(11.25 KiB) Downloaded 58 times
AndrewS
Wed Aug 27, 2014 3:27 am
Joe Schmoe wrote:Who else does this need to be reported to?
https://github.com/raspberrypi/linux/issues
The more detail you can give in your bug-report, the better!
Return to “Raspberry Pi OS”
