BrendonShaw
RPi B+ BCM2835 lib
Thu Jul 31, 2014 8:41 am
I am using the new RPi B+ board and trying to access the addittional GPIO lines using the BCM2835 lib, but not getting any response or ability to use the new GPIO pins. I know they work as I am using the wiringPi lib, but just want to port over some older code and inculde the use of the new B+ GPIO pins.
I am using the latest BCM files - bcm2835-1.36.tar.gz and code the using reference to the previous & new GPIO pins
// Input on RPi pin GPIO 15 - 40 way idc header pin 20
#define PIN_15 RPI_GPIO_P1_15
// Input on RPi pin GPIO 05 - 40 way idc header pin 29
#define PIN_05 RPI_GPIO_P1_05            // Should this be reference to RPI_V2_GPIO_P5_04   ???
The only reference I can find to the GPIO 05 (Pin 29) is in inthe BCM2835.h lib and has the following references, but these do not tie up to the 40 way IDC header.
// RPi Version 2, new plug P5
RPI_V2_GPIO_P5_03     = 28,
RPI_V2_GPIO_P5_04     = 29,
RPI_V2_GPIO_P5_05     = 30,
RPI_V2_GPIO_P5_06     = 31,
Any ideas how to use the addittional B+ GPIO lines using the BCM lib?
Return to “Raspberry Pi OS”
