electronstate
raspbian hex editor
Tue Jul 29, 2014 8:33 pm
Can anyone recommend a hex editor for Raspbian ?
Re: raspbian hex editor
Tue Jul 29, 2014 8:36 pm
sudo apt-get install hexedit
This is a doctor free zone.
electronstate
Tue Jul 29, 2014 8:43 pm
Thanks Dougie ...
ccouteiro
Wed Aug 16, 2017 1:51 pm
In command line i just have to type "sudo apt-get install hexedit" to install it and run it?
MrMeowington
Fri Aug 24, 2018 3:56 pm
If I'm interpreting this correctly, you're asking if apt-get will run the program for you. In that case:
No, the apt-get command only performs the action specified.
For instance, "sudo apt-get install abc123" would install a package named abc123, and nothing more.
You'll need to type "hexedit" into the terminal to run it.
To code, or not to code...
That is the question.
n67
Fri Aug 24, 2018 4:00 pm
And yet, it is true that all he has to do is:
1) type "sudo apt-get install hexedit" to install it
(and)
2) run it
"L'enfer, c'est les autres"
Epmu Sn!
sid_snake
Wed Oct 16, 2019 8:12 am
As a noob, perhaps if I explain how I got it to work for me.
sudo apt-get install hexedit - my error was to have a blank between apt and -get: apt-get is correct, apt -get gives an error.
That should download the app (or whatever people call programs in linux)
Then open Terminal and type: hexedit
That should run the app with a request for filename. I'm new to linux way of doing things and getting the right path confused me, I'm on Rasp Pi with all the default settings.
My basic "root" is /home/pi and from then on are my files. I had a folder called "myfolder" in which I had a file called "lookat.mee"
I thought the path name was: /home/pi/myfolder/lookat.mee, but it ain't, this worked-> myfolder/lookat.mee
I now know, I am "pi" and all my path reference come from that, not to include the first / and not to have blank spaces in folders or names, it's the underscore trick. "my folder" = fails, "my_folder" = works.
Gavinmc42
Wed Oct 16, 2019 8:22 am
You can look in the GUI software menu choice and search to see what Raspbian suggests to install.
That will install it and add a menu/desktop Icon for it.
- Preferences/Recommended Software...
I'm dancing on Rainbows.
piglet
Wed Oct 16, 2019 9:58 am
I tend to use vi and xxd:
vi as hex editor:
`:%!xxd` to switch into hex mode (without the ` of course)
When you're done hit escape again and type:
`:%!xxd -r` to exit from hex mode.
bls
Wed Oct 16, 2019 6:09 pm
vi aficionados might also like bvi :lol:
Return to “Raspbian”
