marat569
Will the same hardware that works for "NOOB" work for ...
Sat Jul 19, 2014 10:28 pm
Will the same hardware that works for "NOOB" work for Resbian?
"noob" question here haha
KenT
Re: Will the same hardware that works for "NOOB" work for ..
Sun Jul 20, 2014 6:35 am
Yes
NOOBS is just Raspbian and a number of other versions of Linux (some with XBMC installed) on one card so you easily try them all out.
Pi Presents - A toolkit to produce multi-media interactive display applications for museums, visitor centres, and more
Download from http://pipresents.wordpress.com
Sun Jul 20, 2014 6:51 am
NOOBS is not an Operating System http://www.raspberrypi.org/introducing-noobs
Retired disgracefully.....
AndrewS
Thu Jul 24, 2014 3:34 pm
AFAIK every download listed on http://www.raspberrypi.org/downloads will work on every model of Raspberry Pi :D
(aaprt from the ComputeModule, which is a special-case)
If it doesn't, please let me know!
Fri Jul 25, 2014 10:23 am
AndrewS wrote:If it doesn't, please let me know!
So you're saying that they've all been updated with the B+ bootcode.bin and start.elf else they won't ALL run on a B+.
This is a doctor free zone.
FTrevorGowen
Fri Jul 25, 2014 8:10 pm
It's probably worth noting that NOOBS uses its own copy of bootcode.bin (and, I'm guessing, recovery.elf instead of start.elf). As a consequence of this (which was posted in another thread) if, for example, an rpi-update of Raspbian results in Raspbian getting an updated bootcode.bin (in /boot), that needs to be copied into the NOOBS recovery partition too.
However, I'm not sure whether we're discussing a bit of a "red-herring" here - I interpreted the O.P.'s reference to "hardware" as "other external devices" and suspected (like others) that NOOBS was being regarded as a "different O.S. to Raspbian" ie. hadn't understood that it is "only" an installer of O.S.'s (of which Raspbian is just one example).
Trev.
Still running Raspbian Jessie on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W) but Stretch on my 2xP3A+, P3B+, P3B, B+, A+ and a B2. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
AndrewS
Sun Jul 27, 2014 12:55 am
Yup, along with minor kernel changes too. You won't believe how much testing I had to do! ;)
Return to “Raspbian”
