karpovski
Accessibility (Screen zoom)
Wed Jul 16, 2014 2:58 pm
I am starting to use a RaspberryPI ver. B, but i am half blind with some vision problems, so i need to use a screen zoom to utilize a machine.
Actually on windows i am using ZoomText which is a software that allow me to zoom any part of screen and i would like to know if is there an equivalent on Raspbian ?
Thanks.
Ciaran
Re: Accessibility (Screen zoom)
Mon Dec 29, 2014 5:07 pm
Hello karpovski
I'm a new Raspberry Pi user and by the sounds of it am in a similar situation to yourself. Though not completely blind, I'm visually impaired and require screen magnification. I was just wondering if you'd found any solutions for using the Pi?
Thanks,
Ciaran
ghans
Mon Dec 29, 2014 6:22 pm
Try this :
sudo apt-get update
sudo apt-get install xzoom
xzoom
ghans
ahino
Mon Nov 18, 2019 8:48 am
i used xzoom but is simple, fixed, not following mouse. I'm using gnome-mag in stretch with a lil lines of code to control the magnifier window, in size, making it like a stripe large like screen, and jumping top and bottom when mouse touching magnifier area, so u don't need to take care moving magnifier around. I think don't exist better solution. gnome-mag is in the stretch repositories, i'm going to buster, but i don't know if exist in buster repositories.
here my simple code controlling it:
#!/bin/sh
while :
do
eval $(xdotool getmouselocation --shell 2>/dev/null)
#	if [ "$Y" -ge "880" ]
#	if [ "$Y" -ge "493" ]
	if [ "$Y" -ge "708" ]
	then
#		wmctrl -F -r magnifier -e '0,0,0,1980,200'
#		wmctrl -F -r magnifier -e '0,912,0,912,492'
#		wmctrl -F -r magnifier -e '0,0,0,912,492'
		wmctrl -F -r magnifier -e '0,0,0,1824,276'
	fi
#	if [ "$Y" -le "200" ]
#	if [ "$Y" -le "491" ]
	if [ "$Y" -le "276" ]
	then
#		wmctrl -F -r magnifier -e '0,0,850,1980,200'
#		wmctrl -F -r magnifier -e '0,912,492,912,492'
		wmctrl -F -r magnifier -e '0,0,708,1824,276'
	fi
sleep 1
done
(you need to install wmctrl and xdotool)
Return to “Raspbian”
