Network-IT
USB, Ethernet doesn't work on Pi B+ when using image from B
Wed Jul 16, 2014 1:31 pm
Just bought the Pi B+ and very excited to hopefully resolve issues we have with USB power! :D
Im running Raspbian (I believe January release) and I have taken an image from the SD card of a working Pi B and transferred to micro SD to Pi B+ ... Raspbian boots as expected but Ethernet doesn't work and neither does USB. Im using the same mouse & keyboard peripherals that work on the B and the same image .... I'm a bit lost on what to do next to get USB & Ethernet port working on the B+?
Re: USB, Ethernet doesn't work on Pi B+ when using image fro
Wed Jul 16, 2014 1:36 pm
You need later firmware which (probably) isn't available via apt-get yet.
Put the card back into the B, run sudo rpi-update then put the card back into the B+
truehl
Wed Jul 16, 2014 1:38 pm
Network-IT wrote:Hello,
No, it does not work, same problem here. Do a firmware update with your old Pi before, than it will work!
truehl
http://www.squeezeplug.de
mikerr
Wed Jul 16, 2014 1:42 pm
Glad you posted, we needed a topic on this to remind people.
My relatively recent image didn't work (booted up - no USB or ethernet)
If in doubt, just download the latest NOOBS image - that's what I did.
http://www.raspberrypi.org/downloads/
Network-IT
Wed Jul 16, 2014 1:53 pm
Thanks Guys,
I've pugged back into B and running sudo rpi-update .... I did download noobs and try copying files over but must have done it incorrectly.
Just a note for anyone else reading, I don't know how important this is but after running sudo rpi-update i get the message
"*** A reboot is needed to activate the new firmware".
I've run the reboot command, instead of cycling the power ... just in case this makes a difference. Im sure we're all aware how arsey firmware updates can be if you don't reboot properly.
Plugged back into B+ and working as it should. I'm absolutely delighted my new Raspi can properly handle a handheld barcode scanner without issues the B had :D :D :D
Wed Jul 16, 2014 3:09 pm
rpdom wrote:You need later firmware which (probably) isn't available via apt-get yet.
Isn't it in the Wheezy sudo apt-get install libraspberrypi* stuff that pulls in the 3.12.22+ kernel and updates firmware.
sriks
Thu Jul 17, 2014 8:02 am
Hi Guys...
I just got a new raspberry pi B+ . i have the same issue of no ethernet and no usb on raspbmc.. this is my first raspberry pi. so i cannot update on an older one... can anyone suggest any workaround to this please..
RaTTuS
Contact: Twitter YouTube
Thu Jul 17, 2014 8:14 am
sriks wrote:Hi Guys...
where did you get the image from ?
just download the recent noobs image ?
Covfefe
sriks
Thu Jul 17, 2014 8:21 am
Downloaded from the raspbmc site.. another difficulty is that I do not have a usb keyboard or mouse... so I as just planning on using ssh and open vnc to control the pi from my laptop?
Edit : found this ..
https://www.youtube.com/watch?v=1pGSnPgYYrU
will try following and see how it goes
Liamthe1st
Sat Jul 19, 2014 1:51 am
Thank you it is now rip updating and I see it is updating the kernels modules so it should be ok now yes it worked on Pi+ 1 and now Pi+ 2
They should have had a piece of paper from the org before mass selling :lol:
Dit Dah Dit Dah Dit
Sat Jul 19, 2014 9:19 am
I presume the image from raspbmc is out of date. They will need to fix that up for the B+.
mikerr
Sat Jul 19, 2014 9:34 am
I've switched to pure raspian and seem to have lost the red power LED, though everything else works ok.
This is on an old raspbian image (not noobs) which has been upgraded via apt-get & rpi-update
I quite like the "stealth mode" - but is it a symptom of wrong firmware ?
USB ports work fine...
MrEngman
Sat Jul 19, 2014 9:38 am
mikerr wrote:I've switched to pure raspian and seem to have lost the red power LED, though everything else works ok.
It's been mentioned a few times. The power LED going out is an indication of low voltage.
MrEngman
mikerr
Sat Jul 19, 2014 9:53 am
I knew that, but thought that would be a flashing red led - the power LED never comes on, no flashes or anything (everything else ok)
[edit] swapped my noobs card back in and it the red LED was still off
it turns out I was inadvertently using a different usb socket for power than before :oops:
Red led is back now I'm using the original PSU !
tobias1109
Tue Dec 02, 2014 4:11 pm
Hello i just bought a raspberry pi b plus and it starts up normal but my usb keyboard and my usb mouse
dosent respond no matter what i do it want work i have a usb wifi nano adapter too
do anybody know what i should do to get it work
mouse: logitech B100
keyboard: Trust keyboard classicline :?: :?: :?: :?: :?: :?: :?: :?: :?:
diederik
Tue Dec 02, 2014 8:56 pm
tobias1109 wrote:do anybody know what i should do to get it work
A proper power supply
Tue Dec 02, 2014 9:08 pm
Are you using the latest software? If you have a B+ Pi and old software then the USB will not work.
valandil
Wed Dec 03, 2014 9:07 pm
Found another thing what might solve the issue for some of you.
I had my custom debian/raspbian (not original rapsbian) build.
Didnt manage to get ethernet to work but power led was ok, usb worked just fine.
Found out that in the network settings /etc/network/interfaces eth0 was defined (did this over a year ago).
So totally forgot about that...
While looking into what it really could be i used: route -n and found out my b+ was using eth1 instead of eth0 changed that in the interface rebooted the network: sudo /etc/init.d/networking restart
(didn't work for me but for most will do) rebooted the system and i was up and running!
Please note i have not a standart raspbian build but more like a very naked debian with some necessary stuff from raspbian.
So it might be a little bit different but hope this helps if you already updated the firmware and using a powerfull energy source.
Thu Dec 04, 2014 9:01 am
valandil wrote:While looking into what it really could be i used: route -n and found out my b+ was using eth1 instead of eth0
You'll find that you have an entry for eth0 and eth1 in /etc/udev/rules.d/70-persistent-net.rules.
This is the default in Debian, but the Raspbian distro uses a different /lib/udev/rules.d/75-persistent-net-generator.rules which doesn't create extra entries for eth or wlan interfaces - otherwise everytime you switched cards between Pis the interface name would change.
plugwash
Thu Dec 04, 2014 8:29 pm
rpdom wrote: This is the default in Debian, but the Raspbian distro uses a different /lib/udev/rules.d/75-persistent-net-generator.rules which doesn't create extra entries for eth or wlan interfaces - otherwise everytime you switched cards between Pis the interface name would change.
Note: this is a charactersitic of the raspberry pi foundation raspbian image. Not of raspbian in general.
Thu Dec 04, 2014 9:41 pm
plugwash wrote:Note: this is a charactersitic of the raspberry pi foundation raspbian image. Not of raspbian in general.
Thanks for the clarification :)
valandil
Fri Dec 05, 2014 3:56 pm
Ah didn't know that working with linux for less then a year now!
But at least there is a solution ;)
Im glad my B+ is up and running, the old one had issues with the sd-card after a reinsert (i do backup the sd card once a month)
eng.m.attia
Tue Dec 23, 2014 12:30 am
I have new rasberry pi B+ first time using rasspberry, i'm using latest rasbian, i have problem with Ethernet not working. Could you think this issue will solved when using noobs.???
exartemarte
Tue Dec 23, 2014 2:36 am
I realise this won't help those without Ethernet or usb but, for what it's worth, I replaced the B Rev 2 running my NAS server with a B+ a few weeks after the B+ came out, using the same OS (on HDD) and, apart from the minor problem described below, it's fine.
Before swapping the hardware I upgraded Raspbian with apt-get. The SD card, which is only needed for booting, was a micro-SD in a carrier and I just transferred it to the B+, plugged in the Ethernet cable, the mouse/keyboard combo and the (usb) hard drives, and booted it up. A little experimentation was needed to determine which drive came up as sda, which as sdb, etc, but once that was sorted it worked.
There is one minor problem: it won't boot with the keyboard/mouse combo and all three hard drives plugged in. If I remove the third hard drive it boots up ok, and I can then reconnect the third drive, mount it, and it all works. This would be irritating if it happened a lot, but it runs 24/7 and is only re-booted once in a blue moon, so I can live with it and, to be honest, I haven't put much effort into trying to fix it. For the record the hard drives - OS, data and data backup - are all self powered so I don't think this will be a power supply problem.
Tue Dec 23, 2014 7:24 am
exartemarte wrote:For the record the hard drives - OS, data and data backup - are all self powered so I don't think this will be a power supply problem.
Even so, have you tried setting the higher current option for the USB ports in config.txt?
max_usb_current=1
Return to “Raspberry Pi OS”
