cyanarnofsky
NTP over USB 3G Modem PPP Connection
Thu Jun 19, 2014 12:39 am
Recently I have noticed that when I connect with Ethernet or Wifi Dongle my time keeps up well. I also have a 3G modem I have working great with Wvdial, but when I boot the Pi with only the 3G connected it seems like it cant pull current time through the modem as it is always way off by hours. Soon as I pull the 3G Modem and reboot on either Wifi or Ethernet again the time pops up correct. Possible I need to point the NPT to the PPP connection?
The 3G connection is established during boot as well.
sander2
Re: NTP over USB 3G Modem PPP Connection
Thu Jun 19, 2014 6:07 am
NTP uses port 123 (ntp 123/tcp) ... so: is that port open when 3G is up? Maybe your 3G has closed it?
Furthermore: anything in /var/log/* ?
What is the output of
ntpdate -d 0.europe.pool.ntp.org
while on normal Internet versus 3G?
cyanarnofsky
Fri Jun 20, 2014 5:44 pm
Returns command not found.
I may need to dig deeper, tried to Ping a few external sources from the Pi and they all fail. Sources ping fine from my PC so I know they are valid. Seems like either the PPP connection is restricting something or possible my ISP (although my ISP said no ports are blocked within that range :/)
I know LAN or Wifi the time stays correct. Odd part is I can ping my Pi modem and SSH into it remotely so it is network visible...kind of
Fri Jun 20, 2014 5:48 pm
cyanarnofsky wrote:Returns command not found.
Try ntpd -g -q
This is a doctor free zone.
cyanarnofsky
Fri Jun 20, 2014 5:57 pm
No output, or date change after command:
ntpd -g -q
Maybe default gateway? Whats the correct way to set that for PPP?
cyanarnofsky
Fri Jun 20, 2014 6:48 pm
Route -n shows no default
Raspberry Pi • View topic - NTP over USB 3G Modem PPP Connection - Google Chrome.jpg
Raspberry Pi • View topic - NTP over USB 3G Modem PPP Connection - Google Chrome.jpg (20.42 KiB) Viewed 3221 times
sander2
Fri Jun 20, 2014 7:20 pm
0.0.0.0 = default, so that's good.
Easy next step: check that IP is working:
mtr -nrc2 8.8.8.8
Example of good output:
$ mtr -nrc2 8.8.8.8
HOST: haring                      Loss%   Snt   Last   Avg  Best  Wrst StDev
  1.|-- 62.59.54.1                 0.0%     2    0.4   0.7   0.4   1.1   0.4
  2.|-- 62.59.30.129               0.0%     2    0.6   0.6   0.6   0.6   0.0
  3.|-- 62.59.254.162              0.0%     2    2.4   2.5   2.4   2.5   0.1
  4.|-- 72.14.219.174              0.0%     2    1.8   1.8   1.8   1.8   0.0
  5.|-- 209.85.254.90              0.0%     2   45.8  23.8   1.8  45.8  31.1
  6.|-- 72.14.238.153              0.0%     2    2.0   2.0   2.0   2.0   0.0
    |  `|-- 209.85.253.249
  7.|-- 209.85.254.231             0.0%     2    5.2   5.2   5.2   5.2   0.0
  8.|-- 216.239.49.30              0.0%     2    5.3   5.3   5.3   5.3   0.0
    |  `|-- 216.239.49.28
  9.|-- ???                       100.0     2    0.0   0.0   0.0   0.0   0.0
 10.|-- 8.8.8.8                    0.0%     2    5.4   5.4   5.4   5.4   0.0
Fri Jun 20, 2014 7:55 pm
sander2 wrote:
mtr -nrc2 8.8.8.8
You'll need to install that with apt-get.
sander2
Fri Jun 20, 2014 8:07 pm
DougieLawson wrote:
sander2 wrote:
mtr -nrc2 8.8.8.8
... so that could be a chicken-egg-situation? ;)
Is 'tracepath' installed by default? Less useful, but OK for a test:
$ tracepath -n 8.8.8.8
 1:  62.59.54.21                                           0.230ms pmtu 1500
 1:  62.59.54.1                                            0.448ms
 1:  62.59.54.1                                            0.380ms
 2:  62.45.30.129                                          0.621ms
 3:  62.45.254.162                                         2.067ms asymm  5
 4:  no reply
 5:  no reply
 6:  no reply
 7:  no reply
Fri Jun 20, 2014 8:21 pm
Nope. No tracepath nor traceroute.
I guess you could pull the DEBs on a Windows machine and install them on the RPi from a USB stick.
http://mirrordirector.raspbian.org/rasp ... _armhf.deb
sander2
Fri Jun 20, 2014 8:42 pm
... that leaves a manual hop measurement:
First hop, aka default gateway:
ping -t1 -n -c1  8.8.8.8 | grep -i from
Second hop, usually some public IP address:
ping -t2 -n -c1  8.8.8.8 | grep -i from
So the OP should be able to do that and see if there is first hop and a second hop. If not, there is Internet routing problem, and not a NTP problem.
Fri Jun 20, 2014 8:57 pm
 for i in `seq 1 30`; do ping -t$i -n -c1  8.8.8.8 | grep -i from; done
cyanarnofsky
Fri Jun 20, 2014 9:22 pm
Thanks for your help, this was my own ignorance.
My modem operates in a private pool, didn't realize this one had been added to the pool so it isn't publicly rout-able....derrr.
Going to pull modem sys time directly from the nearest tower via AT command after boot. Should solve this and also do away with needing handle time zones, a win/win :)
sander2
Sun Jun 22, 2014 9:55 pm
Wow ... beautiful!
Return to “Raspbian”
