Juel-dk
skill: "modprobe" is not support ?!?!
Sat Apr 12, 2014 9:31 pm
Hi Fellow RPi's :)
My RPi had a bad startup, so i ran a fsck, and it now boots Again, but it gives me some wierd errors now :(
The problem is that when the RPi at startup loads:
kernel module snd-bcm2835
kernel module w1_gpio
kernel module w1_therm
It gives me a
For more details see skill(1).
error :(
Ok i thought an update would help with that, so i ran a:
sudo apt-get update - ran with no errors.
then i ran a:
sudo apt-get dist-upgrade and is finishes with this error:
/var/lib/dpkg/info/libgtk-3-0:armhf.postrm: 15: /var/lib/dpkg/info/libgtk-3-0:armhf.postrm: rmdir: not found
dpkg: advarsel: underproces gammelt post-removal-script returnerede afslutningsstatus 127
dpkg: forsøger i stedet script fra ny pakke ...
/var/lib/dpkg/tmp.ci/postrm: 15: /var/lib/dpkg/tmp.ci/postrm: rmdir: not found
dpkg: fejl under behandling af /var/cache/apt/archives/libgtk-3-0_3.4.2-7_armhf.deb (--unpack):
 underproces nyt post-removal-script returnerede afslutningsstatus 127
dpkg: fejl under oprydning:
Der opstod fejl under behandlingen:
Then I ran a sudo rpi-update, but it also gives me an error :(
 *** Updating firmware
 *** Updating kernel modules
 *** depmod 3.10.36+
skill: "depmod" is not support
Why is this happening? and what is that: For more details see skill(1). <-- where and what is that, Google cant seem to help me :(
Can some of you?
Kind regards
Morten
Tarcas
Re: skill: "modprobe" is not support ?!?!
Sun Apr 13, 2014 3:24 am
Type "man skill" to view the manual page for skill. (As an aside, get to know the man pages. They'll save your butt from time to time.)
What do you mean by "had a bad startup?" I can't be entirely certain at this point, but it sounds like fsck made the drive readable, but you lost some data to corruption. If it was me, I'd back up my data and reinstall, since even if you were able to repair the packages you've seen to be affected, you can't be certain that everything was repaired.
Richard-TX
Sun Apr 13, 2014 5:36 am
I think that you lost some important files. Backup any data and re-image your sd card.
Richard
Doing Unix since 1985.
The 9-25-2013 image of Wheezy can be found at:
http://downloads.raspberrypi.org/raspbian/images/raspbian-2013-09-27/2013-09-25-wheezy-raspbian.zip
Juel-dk
Thu Apr 17, 2014 9:23 am
Thanks for your answers :)
I ended up reinstalling the Whole thing :D
I think you where right something important was misssing :(
Return to “Raspberry Pi OS”
