df -hCode: Select all
Filesystem Size Used Avail Use% Mounted on
rootfs 15G 14G 457M 97% /
/dev/root 15G 14G 457M 97% /
devtmpfs 211M 0 211M 0% /dev
tmpfs 44M 204K 44M 1% /run
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 88M 0 88M 0% /run/shm
/dev/mmcblk0p1 56M 19M 38M 34% /boot
tmpfs 88M 0 88M 0% /tmp
while this command, which is supposed to output every directory and its size
sudo du -hsx * | sort -rhCode: Select all
du: cannot access `proc/2331/task/2331/fd/4': No such file or directory
du: cannot access `proc/2331/task/2331/fdinfo/4': No such file or directory
du: cannot access `proc/2331/fd/4': No such file or directory
du: cannot access `proc/2331/fdinfo/4': No such file or directory
1.4G usr
239M var
53M lib
37M opt
19M boot
7.3M home
6.7M sbin
5.9M bin
4.4M etc
216K run
20K media
16K root
16K lost+found
4.0K srv
4.0K selinux
4.0K mnt
0 tmp
0 sys
0 proc
0 devIt's a Raspberry Pi Model B with pure Raspbian and only one little python-tool installed (pyLoad), nothing else really.
