Richard-TX
Wheezy 2014-01-07 PANIC
Tue Feb 04, 2014 3:17 am
This seems to be a left over issue from the 2013-12-20 release.
Conditions:
MPD playing fm radio stream
USB keyboard and mouse connected
wifi connection
I2C bus enabled
It takes several minutes of playing music for the kernel to panic.
[code]# lsusb
Bus 001 Device 004: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 001 Device 005: ID 04d9:1203 Holtek Semiconductor, Inc. Keyboard
Bus 001 Device 006: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless Adapter
Bus 001 Device 007: ID 045e:0039 Microsoft Corp. IntelliMouse Optical
[/code]
Picture of the panic details are at:
http://rocpi.ae-tool.com/tmp/panic.jpg
Richard
Doing Unix since 1985.
The 9-25-2013 image of Wheezy can be found at:
http://downloads.raspberrypi.org/raspbian/images/raspbian-2013-09-27/2013-09-25-wheezy-raspbian.zip
Richard-TX
Re: Wheezy 2014-01-07 PANIC
Tue Feb 04, 2014 3:37 am
Can anyone else duplicate this issue?
If you have:
-a wifi connection
-a usb keyboard
-a usb mouse
-can add mpd and mpc (sudo apt-get install mpd mpc)
-then play a music stream for about 45 minutes
you should see the same issue.
using mpc the command line to play a stream would be
mpc add  http://wttw.ic.llnwd.net/stream/wttw_wfmt_livebroadcast
mpc play
Richard
Richard-TX
Fri Feb 07, 2014 10:55 pm
This bug has been reported in a plurality of places. It seems to be in-work. The master bug report is at https://github.com/raspberrypi/linux/issues/499
Richard
Return to “Raspberry Pi OS”
