Liber
Contact: ICQ
Is Raspbian compatible with other ARM single-board computers
Sat Jan 18, 2014 7:29 pm
I already own a Raspberry Pi model B and I am looking for a more powerful alternative. I want it to be able to run as a NAS and also as XBMC media center. I am used to use Raspbian with XBMC and that is why I am looking for Raspbian compatible single-board computer. Could anybody recommend me any suitable and cheap type ?
redhawk
Re: Is Raspbian compatible with other ARM single-board compu
Sat Jan 18, 2014 7:44 pm
Well you could go for Android TV Box although you need to be careful with chipsets since some running XBMC don't have native or limited hardware decoding and thus require software render.
I believe the Rockchip RK3066 (dual core) and RK3188 (quad core), All Winner A20 (dual core) all appear to have XBMC support but you'll need to check the XBMC forums.
I saw this on eBay the other day http://www.ebay.co.uk/itm/AndroidBoxTVT ... 1240845651 for 50 quid it's not bad considering what you're getting: AV + HDMI + TOSLINK, Wifi, Ethernet LAN, USB hub and remote control.
If you still want Linux then you're probably better off getting a Beagle Board - http://beagleboard.org/
Richard S.
Liber
Contact: ICQ
Sun Jan 19, 2014 5:53 pm
Thank you for your advice ;)
Return to “Raspberry Pi OS”
