Bobuscho
Apparmor on Raspbian?
Fri Jan 17, 2014 9:36 am
Good morning,
my pi arrived just a week ago and i've no got it up and running a small nginx webserver etc. This device is absolutely fabulous.
As it is configured as a server, i want to improve various security features.
I've managed to tighten the basic webserver security (sysctl, the nginx conf, the php.ini, iptables, ssl, ssh settings etc...), but my "last line of defense", apparmor, does not work.
It seems like apparmor is not compiled into the kernel because an "aa-status" just returns "module not available in kernel".
I tried to add "apparmor=1 security=apparmor" to /boot/cmdline.txt, as suggested somewhere else in these forums, but it does not work.
How can i add the apparmor module to my raspbian system?
Thank you!
counter
Re: Apparmor on Raspbian?
Mon May 12, 2014 10:06 pm
I would also like to use apparmor at the pi.
Does someone know a soloution for this problem yet?
algorithm
Tue May 13, 2014 9:00 am
I don't know this software but it is in the repository, see:
apt-cache search apparmor
Not sure which of those you need to install to get the functionality you want but I'd guess all whose names start with "apparmor". Install:
sudo apt-get update && sudo apt-get install '^apparmor.*'
That will also install a BOATload of perl dependencies...
evilkitty
Tue May 13, 2014 11:24 am
sudo apt-get install apparmor
should get you what comes stock on ubuntu as far as apparmor is concerned
My Pi Server: http://imgur.com/a/6xIUI | Thermostat: http://imgur.com/a/4LVnT
counter
Wed May 14, 2014 9:29 pm
I installed apparmor and apparmor-utils and set the kernel parameter
at /boot/cmdline.txt
$ sudo aa-status
AppArmor not available in kernel.
Found another thread about this issue:
http://www.raspberrypi.org/forums/viewt ... 28&t=56776
ghans
Thu May 15, 2014 9:18 am
You will not not get around recompiling your kernel (or at least the apparmor module).
ghans
counter
Sun May 25, 2014 7:50 am
ok, but I need a guide to do that for raspbian with cross-compile.
DeeJay
Sun May 25, 2014 9:17 am
counter wrote:I need a guide to do that for raspbian with cross-compile.
http://elinux.org/RPi_Kernel_Compilation
zfyseu
Tue Jul 05, 2016 7:00 am
Hello everyone!
Have you solved the problem?
I also want to enable apparmor on Raspbian.
Thanks!
Return to “Raspbian”
