ktb
Re: ASUS USB-AC56 (RTL8812AU/RTL8821AU) Driver compile fails
Mon Mar 06, 2017 3:40 pm
ktb wrote:
rusli wrote:Ktb
How do I compile those Drivers in Ubuntu-mate 16.04???
I don't know. I don't use Ubuntu MATE 16.04. I'd probably get the kernel headers somehow and compile as usual.
If you are patient, maybe I'll post the steps for you later. However, they will not be specific to Ubuntu MATE.
OK. This is how I just built it on Raspbian Stretch with kernel 4.9.9-v7+
Get the kernel headers, configure GCC to match the version which was used to build the currently running kernel, clone the 8812au driver source:
sudo wget https://raw.githubusercontent.com/notro/rpi-source/master/rpi-source -O /usr/bin/rpi-source && sudo chmod +x /usr/bin/rpi-source && /usr/bin/rpi-source -q --tag-update
sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-6 20
sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-4.9 50
sudo update-alternatives --install /usr/bin/g++ g++ /usr/bin/g++-6 20
sudo update-alternatives --install /usr/bin/g++ g++ /usr/bin/g++-4.9 50
rpi-source
mkdir -p ~/software/source && cd ~/software/source
git clone https://github.com/astsam/rtl8812au.git
cd rtl8812au
git checkout v4.3.21
nano Makefile
Then I edited the Makefile to add a config option for building the driver on a Pi
CONFIG_PLATFORM_I386_PC = n
CONFIG_PLATFORM_ARM_RPI = y
ifeq ($(CONFIG_PLATFORM_ARM_RPI), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN
EXTRA_CFLAGS += -DCONFIG_IOCTL_CFG80211 -DRTW_USE_CFG80211_STA_EVENT
ARCH ?= arm
CROSS_COMPILE ?=
KVER ?= $(shell uname -r)
KSRC := /lib/modules/$(KVER)/build
MODDESTDIR := /lib/modules/$(KVER)/kernel/drivers/net/wireless/
INSTALL_PREFIX :=
endif
This is my edited Makefile content:
EXTRA_CFLAGS += $(USER_EXTRA_CFLAGS)
#EXTRA_CFLAGS += -O1
#EXTRA_CFLAGS += -O3
#EXTRA_CFLAGS += -Wall
#EXTRA_CFLAGS += -Wextra
#EXTRA_CFLAGS += -Werror
#EXTRA_CFLAGS += -pedantic
#EXTRA_CFLAGS += -Wshadow -Wpointer-arith -Wcast-qual -Wstrict-prototypes -Wmissing-prototypes
EXTRA_CFLAGS += -Wno-unused-variable
EXTRA_CFLAGS += -Wno-unused-value
EXTRA_CFLAGS += -Wno-unused-label
EXTRA_CFLAGS += -Wno-unused-parameter
EXTRA_CFLAGS += -Wno-unused-function
#EXTRA_CFLAGS += -Wno-uninitialized
EXTRA_CFLAGS += -Wno-error=date-time	# Fix compile error on gcc 4.9 and later
EXTRA_CFLAGS += -I$(src)/include
EXTRA_CFLAGS += -I$(src)/hal/phydm
EXTRA_LDFLAGS += --strip-debug
CONFIG_AUTOCFG_CP = n
########################## WIFI IC ############################
CONFIG_MULTIDRV = n
CONFIG_RTL8188E = n
CONFIG_RTL8812A = y
CONFIG_RTL8821A = y
CONFIG_RTL8192E = n
CONFIG_RTL8723B = n
CONFIG_RTL8814A = n
CONFIG_RTL8723C = n
CONFIG_RTL8188F = n
######################### Interface ###########################
CONFIG_USB_HCI = y
CONFIG_PCI_HCI = n
CONFIG_SDIO_HCI = n
CONFIG_GSPI_HCI = n
########################## Features ###########################
CONFIG_MP_INCLUDED = y
CONFIG_POWER_SAVING = n
CONFIG_USB_AUTOSUSPEND = n
CONFIG_HW_PWRP_DETECTION = n
CONFIG_WIFI_TEST = n
CONFIG_BT_COEXIST = n
CONFIG_INTEL_WIDI = n
CONFIG_WAPI_SUPPORT = n
CONFIG_EFUSE_CONFIG_FILE = n
CONFIG_EXT_CLK = n
CONFIG_TRAFFIC_PROTECT = y
CONFIG_LOAD_PHY_PARA_FROM_FILE = y
CONFIG_CALIBRATE_TX_POWER_BY_REGULATORY = n
CONFIG_CALIBRATE_TX_POWER_TO_MAX = n
CONFIG_RTW_ADAPTIVITY_EN = disable
CONFIG_RTW_ADAPTIVITY_MODE = normal
CONFIG_SIGNAL_SCALE_MAPPING = n
CONFIG_80211W = n
CONFIG_REDUCE_TX_CPU_LOADING = n
CONFIG_BR_EXT = y
CONFIG_ANTENNA_DIVERSITY = n
CONFIG_TDLS = n
CONFIG_WIFI_MONITOR = y
CONFIG_APPEND_VENDOR_IE_ENABLE = n
######################## Wake On Lan ##########################
CONFIG_WOWLAN = n
CONFIG_GPIO_WAKEUP = n
CONFIG_WAKEUP_GPIO_IDX = default
CONFIG_HIGH_ACTIVE = n
CONFIG_PNO_SUPPORT = n
CONFIG_PNO_SET_DEBUG = n
CONFIG_AP_WOWLAN = n
######### Notify SDIO Host Keep Power During Syspend ##########
CONFIG_RTW_SDIO_PM_KEEP_POWER = y
###################### MP HW TX MODE FOR VHT #######################
CONFIG_MP_VHT_HW_TX_MODE = n
###################### Platform Related #######################
CONFIG_PLATFORM_ANDROID_X86 = n
CONFIG_PLATFORM_ANDROID_INTEL_X86 = n
CONFIG_PLATFORM_JB_X86 = n
CONFIG_PLATFORM_ARM_S3C2K4 = n
CONFIG_PLATFORM_ARM_PXA2XX = n
CONFIG_PLATFORM_ARM_S3C6K4 = n
CONFIG_PLATFORM_MIPS_RMI = n
CONFIG_PLATFORM_RTD2880B = n
CONFIG_PLATFORM_MIPS_AR9132 = n
CONFIG_PLATFORM_RTK_DMP = n
CONFIG_PLATFORM_MIPS_PLM = n
CONFIG_PLATFORM_MSTAR389 = n
CONFIG_PLATFORM_MT53XX = n
CONFIG_PLATFORM_ARM_MX51_241H = n
CONFIG_PLATFORM_FS_MX61 = n
CONFIG_PLATFORM_ACTIONS_ATJ227X = n
CONFIG_PLATFORM_TEGRA3_CARDHU = n
CONFIG_PLATFORM_TEGRA4_DALMORE = n
CONFIG_PLATFORM_ARM_TCC8900 = n
CONFIG_PLATFORM_ARM_TCC8920 = n
CONFIG_PLATFORM_ARM_TCC8920_JB42 = n
CONFIG_PLATFORM_ARM_TCC8930_JB42 = n
CONFIG_PLATFORM_ARM_RK2818 = n
CONFIG_PLATFORM_ARM_RK3066 = n
CONFIG_PLATFORM_ARM_RK3188 = n
CONFIG_PLATFORM_ARM_URBETTER = n
CONFIG_PLATFORM_ARM_TI_PANDA = n
CONFIG_PLATFORM_MIPS_JZ4760 = n
CONFIG_PLATFORM_DMP_PHILIPS = n
CONFIG_PLATFORM_MSTAR_TITANIA12 = n
CONFIG_PLATFORM_MSTAR = n
CONFIG_PLATFORM_SZEBOOK = n
CONFIG_PLATFORM_ARM_SUNxI = n
CONFIG_PLATFORM_ARM_SUN6I = n
CONFIG_PLATFORM_ARM_SUN7I = n
CONFIG_PLATFORM_ARM_SUN8I_W3P1 = n
CONFIG_PLATFORM_ARM_SUN8I_W5P1 = n
CONFIG_PLATFORM_ACTIONS_ATM702X = n
CONFIG_PLATFORM_ACTIONS_ATV5201 = n
CONFIG_PLATFORM_ACTIONS_ATM705X = n
CONFIG_PLATFORM_ARM_SUN50IW1P1 = n
CONFIG_PLATFORM_ARM_RTD299X = n
CONFIG_PLATFORM_ARM_SPREADTRUM_6820 = n
CONFIG_PLATFORM_ARM_SPREADTRUM_8810 = n
CONFIG_PLATFORM_ARM_WMT = n
CONFIG_PLATFORM_TI_DM365 = n
CONFIG_PLATFORM_MOZART = n
CONFIG_PLATFORM_RTK119X = n
CONFIG_PLATFORM_NOVATEK_NT72668 = n
CONFIG_PLATFORM_HISILICON = n
CONFIG_DRVEXT_MODULE = n
export TopDIR ?= $(shell pwd)
########### COMMON  #################################
ifeq ($(CONFIG_GSPI_HCI), y)
HCI_NAME = gspi
endif
ifeq ($(CONFIG_SDIO_HCI), y)
HCI_NAME = sdio
endif
ifeq ($(CONFIG_USB_HCI), y)
HCI_NAME = usb
endif
ifeq ($(CONFIG_PCI_HCI), y)
HCI_NAME = pci
endif
ifeq ($(DEBUG), 1)
EXTRA_CFLAGS += -DDBG=1 -DCONFIG_DEBUG -DCONFIG_DBG_COUNTER
else
EXTRA_CFLAGS += -DDBG=0
endif
_OS_INTFS_FILES :=	os_dep/osdep_service.o \
			os_dep/linux/os_intfs.o \
			os_dep/linux/$(HCI_NAME)_intf.o \
			os_dep/linux/$(HCI_NAME)_ops_linux.o \
			os_dep/linux/ioctl_linux.o \
			os_dep/linux/xmit_linux.o \
			os_dep/linux/mlme_linux.o \
			os_dep/linux/recv_linux.o \
			os_dep/linux/ioctl_cfg80211.o \
			os_dep/linux/rtw_cfgvendor.o \
			os_dep/linux/wifi_regd.o \
			os_dep/linux/rtw_android.o \
			os_dep/linux/rtw_radiotap.o \
			os_dep/linux/rtw_proc.o
ifeq ($(CONFIG_MP_INCLUDED), y)
_OS_INTFS_FILES += os_dep/linux/ioctl_mp.o
endif
_OS_INTFS_FILES += os_dep/linux/custom_gpio_linux.o
_OS_INTFS_FILES += os_dep/linux/$(HCI_NAME)_ops_linux.o
endif
endif
_HAL_INTFS_FILES :=	hal/hal_intf.o \
			hal/hal_com.o \
			hal/hal_com_phycfg.o \
			hal/hal_phy.o \
			hal/hal_dm.o \
			hal/hal_btcoex.o \
			hal/hal_mp.o \
			hal/hal_hci/hal_$(HCI_NAME).o \
			hal/led/hal_$(HCI_NAME)_led.o
_OUTSRC_FILES := hal/phydm/phydm_debug.o	\
		hal/phydm/phydm_antdiv.o\
		hal/phydm/phydm_antdect.o\
		hal/phydm/phydm_interface.o\
		hal/phydm/phydm_hwconfig.o\
		hal/phydm/phydm.o\
		hal/phydm/halphyrf_ce.o\
		hal/phydm/phydm_edcaturbocheck.o\
		hal/phydm/phydm_dig.o\
		hal/phydm/phydm_pathdiv.o\
		hal/phydm/phydm_rainfo.o\
		hal/phydm/phydm_dynamicbbpowersaving.o\
		hal/phydm/phydm_powertracking_ce.o\
		hal/phydm/phydm_dynamictxpower.o\
		hal/phydm/phydm_adaptivity.o\
		hal/phydm/phydm_cfotracking.o\
		hal/phydm/phydm_noisemonitor.o\
		hal/phydm/phydm_acs.o\
		hal/phydm/phydm_beamforming.o\
		hal/phydm/txbf/halcomtxbf.o\
		hal/phydm/txbf/haltxbfinterface.o
EXTRA_CFLAGS += -I$(src)/platform
_PLATFORM_FILES := platform/platform_ops.o
ifeq ($(CONFIG_BT_COEXIST), y)
EXTRA_CFLAGS += -I$(src)/hal/btc
_OUTSRC_FILES += hal/btc/HalBtc8192e1Ant.o \
				hal/btc/HalBtc8192e2Ant.o \
				hal/btc/HalBtc8723b1Ant.o \
				hal/btc/HalBtc8723b2Ant.o \
				hal/btc/HalBtc8812a1Ant.o \
				hal/btc/HalBtc8812a2Ant.o \
				hal/btc/HalBtc8821a1Ant.o \
				hal/btc/HalBtc8821a2Ant.o \
				hal/btc/HalBtc8821aCsr2Ant.o \
				hal/btc/HalBtc8703b1Ant.o \
				hal/btc/HalBtc8703b2Ant.o
endif
########### HAL_RTL8188E #################################
ifeq ($(CONFIG_RTL8188E), y)
RTL871X = rtl8188e
MODULE_NAME = 8189es
endif
endif
MODULE_NAME = 8188eu
endif
MODULE_NAME = 8188ee
endif
EXTRA_CFLAGS += -DCONFIG_RTL8188E
_HAL_INTFS_FILES +=	hal/HalPwrSeqCmd.o \
					hal/$(RTL871X)/Hal8188EPwrSeq.o\
 					hal/$(RTL871X)/$(RTL871X)_xmit.o\
					hal/$(RTL871X)/$(RTL871X)_sreset.o
_HAL_INTFS_FILES +=	hal/$(RTL871X)/$(RTL871X)_hal_init.o \
			hal/$(RTL871X)/$(RTL871X)_phycfg.o \
			hal/$(RTL871X)/$(RTL871X)_rf6052.o \
			hal/$(RTL871X)/$(RTL871X)_dm.o \
			hal/$(RTL871X)/$(RTL871X)_rxdesc.o \
			hal/$(RTL871X)/$(RTL871X)_cmd.o \
			hal/$(RTL871X)/$(HCI_NAME)/$(HCI_NAME)_halinit.o \
			hal/$(RTL871X)/$(HCI_NAME)/rtl$(MODULE_NAME)_led.o \
			hal/$(RTL871X)/$(HCI_NAME)/rtl$(MODULE_NAME)_xmit.o \
			hal/$(RTL871X)/$(HCI_NAME)/rtl$(MODULE_NAME)_recv.o
_HAL_INTFS_FILES += hal/$(RTL871X)/$(HCI_NAME)/$(HCI_NAME)_ops.o
else
else
_HAL_INTFS_FILES += hal/$(RTL871X)/$(HCI_NAME)/$(HCI_NAME)_ops_linux.o
endif
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8188E_USB.o
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8188E_PCIE.o
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8188E_SDIO.o
endif
#hal/OUTSRC/$(RTL871X)/Hal8188EFWImg_CE.o
_OUTSRC_FILES += hal/phydm/$(RTL871X)/halhwimg8188e_mac.o\
		hal/phydm/$(RTL871X)/halhwimg8188e_bb.o\
		hal/phydm/$(RTL871X)/halhwimg8188e_rf.o\
		hal/phydm/$(RTL871X)/halhwimg8188e_t_fw.o\
		hal/phydm/$(RTL871X)/halhwimg8188e_s_fw.o\
		hal/phydm/$(RTL871X)/halphyrf_8188e_ce.o\
		hal/phydm/$(RTL871X)/phydm_regconfig8188e.o\
		hal/phydm/$(RTL871X)/hal8188erateadaptive.o\
		hal/phydm/$(RTL871X)/phydm_rtl8188e.o
endif
########### HAL_RTL8192E #################################
ifeq ($(CONFIG_RTL8192E), y)
RTL871X = rtl8192e
MODULE_NAME = 8192es
endif
MODULE_NAME = 8192eu
endif
MODULE_NAME = 8192ee
endif
EXTRA_CFLAGS += -DCONFIG_RTL8192E
					hal/$(RTL871X)/Hal8192EPwrSeq.o\
else
else
endif
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8192E_USB.o
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8192E_PCIE.o
endif
#hal/OUTSRC/$(RTL871X)/HalHWImg8188E_FW.o
_OUTSRC_FILES += hal/phydm/$(RTL871X)/halhwimg8192e_mac.o\
		hal/phydm/$(RTL871X)/halhwimg8192e_bb.o\
		hal/phydm/$(RTL871X)/halhwimg8192e_rf.o\
		hal/phydm/$(RTL871X)/halhwimg8192e_fw.o\
		hal/phydm/$(RTL871X)/halphyrf_8192e_ce.o\
		hal/phydm/$(RTL871X)/phydm_regconfig8192e.o\
		hal/phydm/$(RTL871X)/phydm_rtl8192e.o
endif
########### HAL_RTL8812A_RTL8821A #################################
ifneq ($(CONFIG_RTL8812A)_$(CONFIG_RTL8821A), n_n)
RTL871X = rtl8812a
MODULE_NAME = 8812au
endif
MODULE_NAME = 8812ae
endif
MODULE_NAME = 8812as
endif
					hal/$(RTL871X)/Hal8812PwrSeq.o \
					hal/$(RTL871X)/Hal8821APwrSeq.o\
else
else
endif
endif
ifeq ($(CONFIG_RTL8812A), y)
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8812A_USB.o
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8812A_PCIE.o
endif
endif
ifeq ($(CONFIG_RTL8821A), y)
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8821A_USB.o
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8821A_PCIE.o
endif
endif
EXTRA_CFLAGS += -DCONFIG_RTL8812A
_OUTSRC_FILES += hal/phydm/$(RTL871X)/halhwimg8812a_fw.o\
		hal/phydm/$(RTL871X)/halhwimg8812a_mac.o\
		hal/phydm/$(RTL871X)/halhwimg8812a_bb.o\
		hal/phydm/$(RTL871X)/halhwimg8812a_rf.o\
		hal/phydm/$(RTL871X)/halphyrf_8812a_ce.o\
		hal/phydm/$(RTL871X)/phydm_regconfig8812a.o\
		hal/phydm/$(RTL871X)/phydm_rtl8812a.o\
		hal/phydm/txbf/haltxbfjaguar.o
endif
ifeq ($(CONFIG_RTL8812A), n)
RTL871X = rtl8821a
MODULE_NAME := 8821au
endif
MODULE_NAME := 8821ae
endif
MODULE_NAME := 8821as
endif
endif
EXTRA_CFLAGS += -DCONFIG_RTL8821A
_OUTSRC_FILES += hal/phydm/rtl8821a/halhwimg8821a_fw.o\
		hal/phydm/rtl8821a/halhwimg8821a_mac.o\
		hal/phydm/rtl8821a/halhwimg8821a_bb.o\
		hal/phydm/rtl8821a/halhwimg8821a_rf.o\
		hal/phydm/rtl8812a/halphyrf_8812a_ce.o\
		hal/phydm/rtl8821a/halphyrf_8821a_ce.o\
		hal/phydm/rtl8821a/phydm_regconfig8821a.o\
		hal/phydm/rtl8821a/phydm_rtl8821a.o\
		hal/phydm/rtl8821a/phydm_iqk_8821a_ce.o\
endif
endif
########### HAL_RTL8723B #################################
ifeq ($(CONFIG_RTL8723B), y)
RTL871X = rtl8723b
MODULE_NAME = 8723bu
endif
MODULE_NAME = 8723be
endif
MODULE_NAME = 8723bs
endif
EXTRA_CFLAGS += -DCONFIG_RTL8723B
					hal/$(RTL871X)/Hal8723BPwrSeq.o\
_HAL_INTFS_FILES +=	\
else
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8723B_USB.o
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8723B_PCIE.o
endif
_OUTSRC_FILES += hal/phydm/$(RTL871X)/halhwimg8723b_bb.o\
								hal/phydm/$(RTL871X)/halhwimg8723b_mac.o\
								hal/phydm/$(RTL871X)/halhwimg8723b_rf.o\
								hal/phydm/$(RTL871X)/halhwimg8723b_fw.o\
								hal/phydm/$(RTL871X)/halhwimg8723b_mp.o\
								hal/phydm/$(RTL871X)/phydm_regconfig8723b.o\
								hal/phydm/$(RTL871X)/halphyrf_8723b_ce.o\
								hal/phydm/$(RTL871X)/phydm_rtl8723b.o
endif
########### HAL_RTL8814A #################################
ifeq ($(CONFIG_RTL8814A), y)
## ADD NEW VHT MP HW TX MODE ##
#EXTRA_CFLAGS += -DCONFIG_MP_VHT_HW_TX_MODE
#CONFIG_MP_VHT_HW_TX_MODE = y
RTL871X = rtl8814a
MODULE_NAME = 8814au
endif
MODULE_NAME = 8814ae
endif
MODULE_NAME = 8814as
endif
EXTRA_CFLAGS += -DCONFIG_RTL8814A
					hal/$(RTL871X)/Hal8814PwrSeq.o \
else
else
endif
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8814A_USB.o
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8814A_PCIE.o
endif
_OUTSRC_FILES += hal/phydm/$(RTL871X)/halhwimg8814a_bb.o\
								hal/phydm/$(RTL871X)/halhwimg8814a_mac.o\
								hal/phydm/$(RTL871X)/halhwimg8814a_rf.o\
								hal/phydm/$(RTL871X)/halhwimg8814a_fw.o\
								hal/phydm/$(RTL871X)/phydm_iqk_8814a.o\
								hal/phydm/$(RTL871X)/phydm_regconfig8814a.o\
								hal/phydm/$(RTL871X)/halphyrf_8814a_ce.o\
								hal/phydm/$(RTL871X)/phydm_rtl8814a.o\
								hal/phydm/txbf/haltxbf8814a.o
endif
########### HAL_RTL8723C #################################
ifeq ($(CONFIG_RTL8723C), y)
RTL871X = rtl8703b
MODULE_NAME = 8723cu
MODULE_SUB_NAME = 8703bu
endif
MODULE_NAME = 8723ce
MODULE_SUB_NAME = 8703be
endif
MODULE_NAME = 8723cs
MODULE_SUB_NAME = 8703bs
endif
EXTRA_CFLAGS += -DCONFIG_RTL8703B
					hal/$(RTL871X)/Hal8703BPwrSeq.o\
			hal/$(RTL871X)/$(HCI_NAME)/rtl$(MODULE_SUB_NAME)_led.o \
			hal/$(RTL871X)/$(HCI_NAME)/rtl$(MODULE_SUB_NAME)_xmit.o \
			hal/$(RTL871X)/$(HCI_NAME)/rtl$(MODULE_SUB_NAME)_recv.o
else
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8703B_USB.o
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8703B_PCIE.o
endif
_OUTSRC_FILES += hal/phydm/$(RTL871X)/halhwimg8703b_bb.o\
								hal/phydm/$(RTL871X)/halhwimg8703b_mac.o\
								hal/phydm/$(RTL871X)/halhwimg8703b_rf.o\
								hal/phydm/$(RTL871X)/halhwimg8703b_fw.o\
								hal/phydm/$(RTL871X)/phydm_regconfig8703b.o\
								hal/phydm/$(RTL871X)/halphyrf_8703b.o
endif
########### HAL_RTL8188F #################################
ifeq ($(CONFIG_RTL8188F), y)
RTL871X = rtl8188f
MODULE_NAME = 8188fu
endif
MODULE_NAME = 8188fe
endif
MODULE_NAME = 8189fs
endif
EXTRA_CFLAGS += -DCONFIG_RTL8188F
					hal/$(RTL871X)/Hal8188FPwrSeq.o\
else
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8188F_USB.o
endif
_HAL_INTFS_FILES +=hal/efuse/$(RTL871X)/HalEfuseMask8188F_SDIO.o
endif
_OUTSRC_FILES += hal/phydm/$(RTL871X)/halhwimg8188f_bb.o\
								hal/phydm/$(RTL871X)/halhwimg8188f_mac.o\
								hal/phydm/$(RTL871X)/halhwimg8188f_rf.o\
								hal/phydm/$(RTL871X)/halhwimg8188f_fw.o\
								hal/phydm/$(RTL871X)/phydm_regconfig8188f.o\
								hal/phydm/$(RTL871X)/halphyrf_8188f.o \
								hal/phydm/$(RTL871X)/phydm_rtl8188f.o
endif
########### AUTO_CFG  #################################
ifeq ($(CONFIG_AUTOCFG_CP), y)
ifeq ($(CONFIG_MULTIDRV), y)
$(shell cp $(TopDIR)/autoconf_multidrv_$(HCI_NAME)_linux.h $(TopDIR)/include/autoconf.h)
else
ifeq ($(CONFIG_RTL8188E)$(CONFIG_SDIO_HCI),yy)
$(shell cp $(TopDIR)/autoconf_rtl8189e_$(HCI_NAME)_linux.h $(TopDIR)/include/autoconf.h)
else ifeq ($(CONFIG_RTL8188F)$(CONFIG_SDIO_HCI),yy)
$(shell cp $(TopDIR)/autoconf_rtl8189f_$(HCI_NAME)_linux.h $(TopDIR)/include/autoconf.h)
else ifeq ($(CONFIG_RTL8723C),y)
$(shell cp $(TopDIR)/autoconf_rtl8723c_$(HCI_NAME)_linux.h $(TopDIR)/include/autoconf.h)
else
$(shell cp $(TopDIR)/autoconf_$(RTL871X)_$(HCI_NAME)_linux.h $(TopDIR)/include/autoconf.h)
endif
endif
endif
########### END OF PATH  #################################
ifeq ($(CONFIG_USB_AUTOSUSPEND), y)
EXTRA_CFLAGS += -DCONFIG_USB_AUTOSUSPEND
endif
endif
#MODULE_NAME := $(MODULE_NAME)_mp
EXTRA_CFLAGS += -DCONFIG_MP_INCLUDED
endif
ifeq ($(CONFIG_POWER_SAVING), y)
EXTRA_CFLAGS += -DCONFIG_POWER_SAVING
endif
ifeq ($(CONFIG_HW_PWRP_DETECTION), y)
EXTRA_CFLAGS += -DCONFIG_HW_PWRP_DETECTION
endif
ifeq ($(CONFIG_WIFI_TEST), y)
EXTRA_CFLAGS += -DCONFIG_WIFI_TEST
endif
EXTRA_CFLAGS += -DCONFIG_BT_COEXIST
endif
ifeq ($(CONFIG_INTEL_WIDI), y)
EXTRA_CFLAGS += -DCONFIG_INTEL_WIDI
endif
ifeq ($(CONFIG_WAPI_SUPPORT), y)
EXTRA_CFLAGS += -DCONFIG_WAPI_SUPPORT
endif
ifeq ($(CONFIG_EFUSE_CONFIG_FILE), y)
EXTRA_CFLAGS += -DCONFIG_EFUSE_CONFIG_FILE
#EFUSE_MAP_PATH
USER_EFUSE_MAP_PATH ?=
ifneq ($(USER_EFUSE_MAP_PATH),)
EXTRA_CFLAGS += -DEFUSE_MAP_PATH=\"$(USER_EFUSE_MAP_PATH)\"
else ifeq ($(MODULE_NAME), 8189es)
EXTRA_CFLAGS += -DEFUSE_MAP_PATH=\"/system/etc/wifi/wifi_efuse_8189e.map\"
else ifeq ($(MODULE_NAME), 8723bs)
EXTRA_CFLAGS += -DEFUSE_MAP_PATH=\"/system/etc/wifi/wifi_efuse_8723bs.map\"
else
EXTRA_CFLAGS += -DEFUSE_MAP_PATH=\"/system/etc/wifi/wifi_efuse_$(MODULE_NAME).map\"
endif
#WIFIMAC_PATH
USER_WIFIMAC_PATH ?=
ifneq ($(USER_WIFIMAC_PATH),)
EXTRA_CFLAGS += -DWIFIMAC_PATH=\"$(USER_WIFIMAC_PATH)\"
else
EXTRA_CFLAGS += -DWIFIMAC_PATH=\"/data/wifimac.txt\"
endif
endif
ifeq ($(CONFIG_EXT_CLK), y)
EXTRA_CFLAGS += -DCONFIG_EXT_CLK
endif
ifeq ($(CONFIG_TRAFFIC_PROTECT), y)
EXTRA_CFLAGS += -DCONFIG_TRAFFIC_PROTECT
endif
ifeq ($(CONFIG_LOAD_PHY_PARA_FROM_FILE), y)
EXTRA_CFLAGS += -DCONFIG_LOAD_PHY_PARA_FROM_FILE
#EXTRA_CFLAGS += -DREALTEK_CONFIG_PATH=\"/lib/firmware/\"
EXTRA_CFLAGS += -DREALTEK_CONFIG_PATH=\"\"
endif
ifeq ($(CONFIG_CALIBRATE_TX_POWER_BY_REGULATORY), y)
EXTRA_CFLAGS += -DCONFIG_CALIBRATE_TX_POWER_BY_REGULATORY
endif
ifeq ($(CONFIG_CALIBRATE_TX_POWER_TO_MAX), y)
EXTRA_CFLAGS += -DCONFIG_CALIBRATE_TX_POWER_TO_MAX
endif
ifeq ($(CONFIG_RTW_ADAPTIVITY_EN), disable)
EXTRA_CFLAGS += -DCONFIG_RTW_ADAPTIVITY_EN=0
else ifeq ($(CONFIG_RTW_ADAPTIVITY_EN), enable)
EXTRA_CFLAGS += -DCONFIG_RTW_ADAPTIVITY_EN=1
endif
ifeq ($(CONFIG_RTW_ADAPTIVITY_MODE), normal)
EXTRA_CFLAGS += -DCONFIG_RTW_ADAPTIVITY_MODE=0
else ifeq ($(CONFIG_RTW_ADAPTIVITY_MODE), carrier_sense)
EXTRA_CFLAGS += -DCONFIG_RTW_ADAPTIVITY_MODE=1
endif
ifeq ($(CONFIG_SIGNAL_SCALE_MAPPING), y)
EXTRA_CFLAGS += -DCONFIG_SIGNAL_SCALE_MAPPING
endif
ifeq ($(CONFIG_80211W), y)
EXTRA_CFLAGS += -DCONFIG_IEEE80211W
endif
ifeq ($(CONFIG_WOWLAN), y)
EXTRA_CFLAGS += -DCONFIG_WOWLAN
EXTRA_CFLAGS += -DCONFIG_RTW_SDIO_PM_KEEP_POWER
endif
endif
ifeq ($(CONFIG_AP_WOWLAN), y)
EXTRA_CFLAGS += -DCONFIG_AP_WOWLAN
endif
endif
ifeq ($(CONFIG_PNO_SUPPORT), y)
EXTRA_CFLAGS += -DCONFIG_PNO_SUPPORT
ifeq ($(CONFIG_PNO_SET_DEBUG), y)
EXTRA_CFLAGS += -DCONFIG_PNO_SET_DEBUG
endif
endif
ifeq ($(CONFIG_GPIO_WAKEUP), y)
EXTRA_CFLAGS += -DCONFIG_GPIO_WAKEUP
ifeq ($(CONFIG_HIGH_ACTIVE), y)
EXTRA_CFLAGS += -DHIGH_ACTIVE=1
else
EXTRA_CFLAGS += -DHIGH_ACTIVE=0
endif
endif
ifneq ($(CONFIG_WAKEUP_GPIO_IDX), default)
EXTRA_CFLAGS += -DWAKEUP_GPIO_IDX=$(CONFIG_WAKEUP_GPIO_IDX)
endif
ifeq ($(CONFIG_RTW_SDIO_PM_KEEP_POWER), y)
endif
endif
ifeq ($(CONFIG_REDUCE_TX_CPU_LOADING), y)
EXTRA_CFLAGS += -DCONFIG_REDUCE_TX_CPU_LOADING
endif
ifeq ($(CONFIG_BR_EXT), y)
BR_NAME = br0
EXTRA_CFLAGS += -DCONFIG_BR_EXT
EXTRA_CFLAGS += '-DCONFIG_BR_EXT_BRNAME="'$(BR_NAME)'"'
endif
ifeq ($(CONFIG_ANTENNA_DIVERSITY), y)
EXTRA_CFLAGS += -DCONFIG_ANTENNA_DIVERSITY
endif
ifeq ($(CONFIG_TDLS), y)
EXTRA_CFLAGS += -DCONFIG_TDLS
endif
ifeq ($(CONFIG_WIFI_MONITOR), y)
EXTRA_CFLAGS += -DCONFIG_WIFI_MONITOR
endif
ifeq ($(CONFIG_MP_VHT_HW_TX_MODE), y)
ifeq ($(CONFIG_PLATFORM_I386_PC), y)
## For I386 X86 ToolChain use Hardware FLOATING
EXTRA_CFLAGS += -mhard-float
else
## For ARM ToolChain use Hardware FLOATING
EXTRA_CFLAGS += -mfloat-abi=hard
endif
endif
ifeq ($(CONFIG_APPEND_VENDOR_IE_ENABLE), y)
EXTRA_CFLAGS += -DCONFIG_APPEND_VENDOR_IE_ENABLE
endif
EXTRA_CFLAGS += -DDM_ODM_SUPPORT_TYPE=0x04
SUBARCH := $(shell uname -m | sed -e s/i.86/i386/)
ARCH ?= $(SUBARCH)
CROSS_COMPILE ?=
KVER  := $(shell uname -r)
INSTALL_PREFIX :=
endif
ARCH ?= arm
CROSS_COMPILE ?=
INSTALL_PREFIX :=
endif
ifeq ($(CONFIG_PLATFORM_ACTIONS_ATM702X), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DCONFIG_PLATFORM_ANDROID -DCONFIG_PLATFORM_ACTIONS_ATM702X
#ARCH := arm
ARCH := $(R_ARCH)
#CROSS_COMPILE := arm-none-linux-gnueabi-
CROSS_COMPILE := $(R_CROSS_COMPILE)
KVER:= 3.4.0
#KSRC := ../../../../build/out/kernel
KSRC := $(KERNEL_BUILD_PATH)
MODULE_NAME :=wlan
endif
ifeq ($(CONFIG_PLATFORM_ACTIONS_ATM705X), y)
#EXTRA_CFLAGS += -DRTW_ENABLE_WIFI_CONTROL_FUNC
# default setting for Android 4.1, 4.2, 4.3, 4.4
EXTRA_CFLAGS += -DCONFIG_PLATFORM_ACTIONS_ATM705X
EXTRA_CFLAGS += -DCONFIG_CONCURRENT_MODE
EXTRA_CFLAGS += -DCONFIG_P2P_IPS
# Enable this for Android 5.0
EXTRA_CFLAGS += -DCONFIG_RADIO_WORK
EXTRA_CFLAGS += -DCONFIG_PLATFORM_OPS
_PLATFORM_FILES += platform/platform_arm_act_sdio.o
endif
ARCH := arm
CROSS_COMPILE := /opt/arm-2011.09/bin/arm-none-linux-gnueabi-
KSRC := /home/android_sdk/Action-semi/705a_android_L/android/kernel
endif
ifeq ($(CONFIG_PLATFORM_ARM_SUN50IW1P1), y)
EXTRA_CFLAGS += -DCONFIG_PLATFORM_ARM_SUN50IW1P1
EXTRA_CFLAGS += -DCONFIG_RESUME_IN_WORKQUEUE
EXTRA_CFLAGS += -DCONFIG_USE_USB_BUFFER_ALLOC_TX
_PLATFORM_FILES += platform/platform_ARM_SUNxI_usb.o
endif
_PLATFORM_FILES += platform/platform_ARM_SUN50IW1P1_sdio.o
endif
ARCH := arm64
# ===Cross compile setting for Android 5.1(64) SDK ===
CROSS_COMPILE := /home/android_sdk/Allwinner/a64/android-51/lichee/out/sun50iw1p1/android/common/buildroot/external-toolchain/bin/aarch64-linux-gnu-
KSRC :=/home/android_sdk/Allwinner/a64/android-51/lichee/linux-3.10/
endif
ifeq ($(CONFIG_PLATFORM_TI_AM3517), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DCONFIG_PLATFORM_ANDROID -DCONFIG_PLATFORM_SHUTTLE
CROSS_COMPILE := arm-eabi-
KSRC := $(shell pwd)/../../../Android/kernel
ARCH := arm
endif
ifeq ($(CONFIG_PLATFORM_MSTAR_TITANIA12), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DCONFIG_PLATFORM_MSTAR -DCONFIG_PLATFORM_MSTAR_TITANIA12
ARCH:=mips
CROSS_COMPILE:= /usr/src/Mstar_kernel/mips-4.3/bin/mips-linux-gnu-
KVER:= 2.6.28.9
KSRC:= /usr/src/Mstar_kernel/2.6.28.9/
endif
ifeq ($(CONFIG_PLATFORM_MSTAR), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DCONFIG_PLATFORM_MSTAR -DCONFIG_USE_USB_BUFFER_ALLOC_TX -DCONFIG_FIX_NR_BULKIN_BUFFER -DCONFIG_PREALLOC_RX_SKB_BUFFER
EXTRA_CFLAGS += -DCONFIG_PLATFORM_MSTAR_HIGH
ARCH:=arm
CROSS_COMPILE:= /usr/src/bin/arm-none-linux-gnueabi-
KVER:= 3.1.10
KSRC:= /usr/src/Mstar_kernel/3.1.10/
endif
ifeq ($(CONFIG_PLATFORM_ANDROID_X86), y)
ARCH := $(SUBARCH)
CROSS_COMPILE := /media/DATA-2/android-x86/ics-x86_20120130/prebuilt/linux-x86/toolchain/i686-unknown-linux-gnu-4.2.1/bin/i686-unknown-linux-gnu-
KSRC := /media/DATA-2/android-x86/ics-x86_20120130/out/target/product/generic_x86/obj/kernel
MODULE_NAME :=wlan
endif
ifeq ($(CONFIG_PLATFORM_ANDROID_INTEL_X86), y)
EXTRA_CFLAGS += -DCONFIG_PLATFORM_ANDROID_INTEL_X86
EXTRA_CFLAGS += -DCONFIG_PLATFORM_INTEL_BYT
EXTRA_CFLAGS += -DCONFIG_SKIP_SIGNAL_SCALE_MAPPING
endif
endif
ifeq ($(CONFIG_PLATFORM_JB_X86), y)
ARCH := $(SUBARCH)
CROSS_COMPILE := /home/android_sdk/android-x86_JB/prebuilts/gcc/linux-x86/x86/i686-linux-android-4.7/bin/i686-linux-android-
KSRC := /home/android_sdk/android-x86_JB/out/target/product/x86/obj/kernel/
MODULE_NAME :=wlan
endif
ifeq ($(CONFIG_PLATFORM_ARM_PXA2XX), y)
ARCH := arm
KVER  := 2.6.34.1
KSRC ?= /usr/src/linux-2.6.34.1
endif
ifeq ($(CONFIG_PLATFORM_ARM_S3C2K4), y)
ARCH := arm
CROSS_COMPILE := arm-linux-
KVER  := 2.6.24.7_$(ARCH)
KSRC := /usr/src/kernels/linux-$(KVER)
endif
ifeq ($(CONFIG_PLATFORM_ARM_S3C6K4), y)
ARCH := arm
KVER  := 2.6.34.1
endif
ifeq ($(CONFIG_PLATFORM_RTD2880B), y)
EXTRA_CFLAGS += -DCONFIG_BIG_ENDIAN -DCONFIG_PLATFORM_RTD2880B
ARCH:=
CROSS_COMPILE:=
KVER:=
KSRC:=
endif
ifeq ($(CONFIG_PLATFORM_MIPS_RMI), y)
ARCH:=mips
CROSS_COMPILE:=mipsisa32r2-uclibc-
KVER:=
KSRC:= /root/work/kernel_realtek
endif
ifeq ($(CONFIG_PLATFORM_MIPS_PLM), y)
ARCH:=mips
KVER:=
endif
ifeq ($(CONFIG_PLATFORM_MSTAR389), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DCONFIG_PLATFORM_MSTAR389
ARCH:=mips
CROSS_COMPILE:= mips-linux-gnu-
KVER:= 2.6.28.10
KSRC:= /home/mstar/mstar_linux/2.6.28.9/
endif
ifeq ($(CONFIG_PLATFORM_MIPS_AR9132), y)
ARCH := mips
CROSS_COMPILE := mips-openwrt-linux-
KSRC := /home/alex/test_openwrt/tmp/linux-2.6.30.9
endif
ifeq ($(CONFIG_PLATFORM_DMP_PHILIPS), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DRTK_DMP_PLATFORM
ARCH := mips
#CROSS_COMPILE:=/usr/local/msdk-4.3.6-mips-EL-2.6.12.6-0.9.30.3/bin/mipsel-linux-
CROSS_COMPILE:=/usr/local/toolchain_mipsel/bin/mipsel-linux-
KSRC ?=/usr/local/Jupiter/linux-2.6.12
endif
ifeq ($(CONFIG_PLATFORM_RTK_DMP), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DRTK_DMP_PLATFORM  -DCONFIG_WIRELESS_EXT
_PLATFORM_FILES += platform/platform_RTK_DMP_usb.o
endif
ARCH:=mips
CROSS_COMPILE:=mipsel-linux-
KVER:=
KSRC ?= /usr/src/DMP_Kernel/jupiter/linux-2.6.12
endif
ifeq ($(CONFIG_PLATFORM_MT53XX), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DCONFIG_PLATFORM_MT53XX
ARCH:= arm
CROSS_COMPILE:= arm11_mtk_le-
KVER:= 2.6.27
KSRC?= /proj/mtk00802/BD_Compare/BDP/Dev/BDP_V301/BDP_Linux/linux-2.6.27
endif
ifeq ($(CONFIG_PLATFORM_ARM_MX51_241H), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DCONFIG_WISTRON_PLATFORM
ARCH := arm
CROSS_COMPILE := /opt/freescale/usr/local/gcc-4.1.2-glibc-2.5-nptl-3/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-
KVER  := 2.6.31
KSRC ?= /lib/modules/2.6.31-770-g0e46b52/source
endif
ifeq ($(CONFIG_PLATFORM_FS_MX61), y)
ARCH := arm
CROSS_COMPILE := /home/share/CusEnv/FreeScale/arm-eabi-4.4.3/bin/arm-eabi-
KSRC ?= /home/share/CusEnv/FreeScale/FS_kernel_env
endif
ifeq ($(CONFIG_PLATFORM_ACTIONS_ATJ227X), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DCONFIG_PLATFORM_ACTIONS_ATJ227X
ARCH := mips
CROSS_COMPILE := /home/cnsd4/project/actions/tools-2.6.27/bin/mipsel-linux-gnu-
KVER  := 2.6.27
KSRC := /home/cnsd4/project/actions/linux-2.6.27.28
endif
ifeq ($(CONFIG_PLATFORM_TI_DM365), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DCONFIG_PLATFORM_TI_DM365
EXTRA_CFLAGS += -DCONFIG_USE_USB_BUFFER_ALLOC_RX
EXTRA_CFLAGS += -DCONFIG_SINGLE_XMIT_BUF -DCONFIG_SINGLE_RECV_BUF
ARCH := arm
#CROSS_COMPILE := /home/cnsd4/Appro/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-
#KSRC := /home/cnsd4/Appro/mv_pro_5.0/montavista/pro/devkit/lsp/ti-davinci/linux-dm365
CROSS_COMPILE := /opt/montavista/pro5.0/devkit/arm/v5t_le/bin/arm-linux-
KSRC:= /home/vivotek/lsp/DM365/kernel_platform/kernel/linux-2.6.18
KERNELOUTPUT := ${PRODUCTDIR}/tmp
KVER  := 2.6.18
endif
ifeq ($(CONFIG_PLATFORM_MOZART), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DCONFIG_PLATFORM_MOZART
ARCH := arm
CROSS_COMPILE := /home/vivotek/lsp/mozart3v2/Mozart3e_Toolchain/build_arm_nofpu/usr/bin/arm-linux-
KSRC:= /opt/Vivotek/lsp/mozart3v2/kernel_platform/kernel/mozart_kernel-1.17
KERNELOUTPUT := /home/pink/sample/ODM/IP8136W-VINT/tmp/kernel
endif
ifeq ($(CONFIG_PLATFORM_TEGRA3_CARDHU), y)
ARCH := arm
CROSS_COMPILE := /home/android_sdk/nvidia/tegra-16r3-partner-android-4.1_20120723/prebuilt/linux-x86/toolchain/arm-eabi-4.4.3/bin/arm-eabi-
KSRC := /home/android_sdk/nvidia/tegra-16r3-partner-android-4.1_20120723/out/target/product/cardhu/obj/KERNEL
MODULE_NAME := wlan
endif
ifeq ($(CONFIG_PLATFORM_TEGRA4_DALMORE), y)
ARCH := arm
CROSS_COMPILE := /home/android_sdk/nvidia/tegra-17r9-partner-android-4.2-dalmore_20130131/prebuilts/gcc/linux-x86/arm/arm-eabi-4.6/bin/arm-eabi-
KSRC := /home/android_sdk/nvidia/tegra-17r9-partner-android-4.2-dalmore_20130131/out/target/product/dalmore/obj/KERNEL
MODULE_NAME := wlan
endif
ifeq ($(CONFIG_PLATFORM_ARM_TCC8900), y)
ARCH := arm
CROSS_COMPILE := /home/android_sdk/Telechips/SDK_2304_20110613/prebuilt/linux-x86/toolchain/arm-eabi-4.4.3/bin/arm-eabi-
KSRC := /home/android_sdk/Telechips/SDK_2304_20110613/kernel
MODULE_NAME := wlan
endif
ifeq ($(CONFIG_PLATFORM_ARM_TCC8920), y)
ARCH := arm
CROSS_COMPILE := /home/android_sdk/Telechips/v12.06_r1-tcc-android-4.0.4/prebuilt/linux-x86/toolchain/arm-eabi-4.4.3/bin/arm-eabi-
KSRC := /home/android_sdk/Telechips/v12.06_r1-tcc-android-4.0.4/kernel
MODULE_NAME := wlan
endif
ifeq ($(CONFIG_PLATFORM_ARM_TCC8920_JB42), y)
ARCH := arm
CROSS_COMPILE := /home/android_sdk/Telechips/v13.03_r1-tcc-android-4.2.2_ds_patched/prebuilts/gcc/linux-x86/arm/arm-eabi-4.6/bin/arm-eabi-
KSRC := /home/android_sdk/Telechips/v13.03_r1-tcc-android-4.2.2_ds_patched/kernel
MODULE_NAME := wlan
endif
ifeq ($(CONFIG_PLATFORM_ARM_RK2818), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DCONFIG_PLATFORM_ANDROID -DCONFIG_PLATFORM_ROCKCHIPS
ARCH := arm
CROSS_COMPILE := /usr/src/release_fae_version/toolchain/arm-eabi-4.4.0/bin/arm-eabi-
KSRC := /usr/src/release_fae_version/kernel25_A7_281x
MODULE_NAME := wlan
endif
ifeq ($(CONFIG_PLATFORM_ARM_RK3188), y)
# default setting for Power control
EXTRA_CFLAGS += -DRTW_SUPPORT_PLATFORM_SHUTDOWN
# default setting for Special function
ARCH := arm
CROSS_COMPILE := /home/android_sdk/Rockchip/Rk3188/prebuilts/gcc/linux-x86/arm/arm-eabi-4.6/bin/arm-eabi-
KSRC := /home/android_sdk/Rockchip/Rk3188/kernel
MODULE_NAME := wlan
endif
ifeq ($(CONFIG_PLATFORM_ARM_RK3066), y)
EXTRA_CFLAGS += -DCONFIG_PLATFORM_ARM_RK3066
endif
EXTRA_CFLAGS += -fno-pic
ARCH := arm
CROSS_COMPILE := /home/android_sdk/Rockchip/rk3066_20130607/prebuilts/gcc/linux-x86/arm/arm-linux-androideabi-4.6/bin/arm-linux-androideabi-
#CROSS_COMPILE := /home/android_sdk/Rockchip/Rk3066sdk/prebuilts/gcc/linux-x86/arm/arm-linux-androideabi-4.6/bin/arm-linux-androideabi-
KSRC := /home/android_sdk/Rockchip/Rk3066sdk/kernel
MODULE_NAME :=wlan
endif
ifeq ($(CONFIG_PLATFORM_ARM_URBETTER), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN #-DCONFIG_MINIMAL_MEMORY_USAGE
ARCH := arm
CROSS_COMPILE := /media/DATA-1/urbetter/arm-2009q3/bin/arm-none-linux-gnueabi-
KSRC := /media/DATA-1/urbetter/ics-urbetter/kernel
MODULE_NAME := wlan
endif
ifeq ($(CONFIG_PLATFORM_ARM_TI_PANDA), y)
ARCH := arm
#CROSS_COMPILE := /media/DATA-1/aosp/ics-aosp_20111227/prebuilt/linux-x86/toolchain/arm-eabi-4.4.3/bin/arm-eabi-
#KSRC := /media/DATA-1/aosp/android-omap-panda-3.0_20120104
CROSS_COMPILE := /media/DATA-1/android-4.0/prebuilt/linux-x86/toolchain/arm-eabi-4.4.3/bin/arm-eabi-
KSRC := /media/DATA-1/android-4.0/panda_kernel/omap
MODULE_NAME := wlan
endif
ifeq ($(CONFIG_PLATFORM_MIPS_JZ4760), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DCONFIG_MINIMAL_MEMORY_USAGE
ARCH ?= mips
CROSS_COMPILE ?= /mnt/sdb5/Ingenic/Umido/mips-4.3/bin/mips-linux-gnu-
KSRC ?= /mnt/sdb5/Ingenic/Umido/kernel
endif
ifeq ($(CONFIG_PLATFORM_SZEBOOK), y)
ARCH:=arm
CROSS_COMPILE:=/opt/crosstool2/bin/armeb-unknown-linux-gnueabi-
KVER:= 2.6.31.6
KSRC:= ../code/linux-2.6.31.6-2020/
endif
#Add setting for MN10300
ifeq ($(CONFIG_PLATFORM_MN10300), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DCONFIG_PLATFORM_MN10300
ARCH := mn10300
CROSS_COMPILE := mn10300-linux-
KVER := 2.6.32.2
KSRC := /home/winuser/work/Plat_sLD2T_V3010/usr/src/linux-2.6.32.2
INSTALL_PREFIX :=
endif
ifeq ($(CONFIG_PLATFORM_ARM_SUNxI), y)
EXTRA_CFLAGS += -DCONFIG_PLATFORM_ARM_SUNxI
EXTRA_CFLAGS += -DDCONFIG_P2P_IPS
endif
# default setting for A10-EVB mmc0
#EXTRA_CFLAGS += -DCONFIG_WITS_EVB_V13
_PLATFORM_FILES += platform/platform_ARM_SUNxI_sdio.o
endif
ARCH := arm
CROSS_COMPILE=/home/android_sdk/Allwinner/a10/android-jb42/lichee-jb42/buildroot/output/external-toolchain/bin/arm-none-linux-gnueabi-
KVER  := 3.0.8
#KSRC:= ../lichee/linux-3.0/
KSRC=/home/android_sdk/Allwinner/a10/android-jb42/lichee-jb42/linux-3.0
endif
ifeq ($(CONFIG_PLATFORM_ARM_SUN6I), y)
EXTRA_CFLAGS += -DCONFIG_PLATFORM_ARM_SUN6I
EXTRA_CFLAGS += -DCONFIG_P2P_IPS -DCONFIG_QOS_OPTIMIZATION
endif
# default setting for A31-EVB mmc0
EXTRA_CFLAGS += -DCONFIG_A31_EVB
_PLATFORM_FILES += platform/platform_ARM_SUNnI_sdio.o
endif
ARCH := arm
#Android-JB42
#CROSS_COMPILE := /home/android_sdk/Allwinner/a31/android-jb42/lichee/buildroot/output/external-toolchain/bin/arm-linux-gnueabi-
#KSRC :=/home/android_sdk/Allwinner/a31/android-jb42/lichee/linux-3.3
#ifeq ($(CONFIG_USB_HCI), y)
#MODULE_NAME := 8188eu_sw
#endif
# ==== Cross compile setting for kitkat-a3x_v4.5 =====
CROSS_COMPILE := /home/android_sdk/Allwinner/a31/kitkat-a3x_v4.5/lichee/buildroot/output/external-toolchain/bin/arm-linux-gnueabi-
KSRC :=/home/android_sdk/Allwinner/a31/kitkat-a3x_v4.5/lichee/linux-3.3
endif
ifeq ($(CONFIG_PLATFORM_ARM_SUN7I), y)
EXTRA_CFLAGS += -DCONFIG_PLATFORM_ARM_SUN7I
endif
endif
ARCH := arm
# ===Cross compile setting for Android 4.2 SDK ===
#CROSS_COMPILE := /home/android_sdk/Allwinner/a20_evb/lichee/out/android/common/buildroot/external-toolchain/bin/arm-linux-gnueabi-
#KSRC := /home/android_sdk/Allwinner/a20_evb/lichee/linux-3.3
# ==== Cross compile setting for Android 4.3 SDK =====
#CROSS_COMPILE := /home/android_sdk/Allwinner/a20/android-jb43/lichee/out/android/common/buildroot/external-toolchain/bin/arm-linux-gnueabi-
#KSRC := /home/android_sdk/Allwinner/a20/android-jb43/lichee/linux-3.4
# ==== Cross compile setting for kitkat-a20_v4.4 =====
CROSS_COMPILE := /home/android_sdk/Allwinner/a20/kitkat-a20_v4.4/lichee/out/android/common/buildroot/external-toolchain/bin/arm-linux-gnueabi-
KSRC := /home/android_sdk/Allwinner/a20/kitkat-a20_v4.4/lichee/linux-3.4
endif
ifeq ($(CONFIG_PLATFORM_ARM_SUN8I_W3P1), y)
EXTRA_CFLAGS += -DCONFIG_PLATFORM_ARM_SUN8I
EXTRA_CFLAGS += -DCONFIG_PLATFORM_ARM_SUN8I_W3P1
endif
endif
ARCH := arm
#CROSS_COMPILE := /home/android_sdk/Allwinner/a23/android-jb42/lichee/out/android/common/buildroot/external-toolchain/bin/arm-linux-gnueabi-
#KSRC :=/home/android_sdk/Allwinner/a23/android-jb42/lichee/linux-3.4
# ===Cross compile setting for Android 4.4 SDK ===
CROSS_COMPILE := /home/android_sdk/Allwinner/a23/android-kk44/lichee/out/android/common/buildroot/external-toolchain/bin/arm-linux-gnueabi-
KSRC :=/home/android_sdk/Allwinner/a23/android-kk44/lichee/linux-3.4
endif
ifeq ($(CONFIG_PLATFORM_ARM_SUN8I_W5P1), y)
EXTRA_CFLAGS += -DCONFIG_PLATFORM_ARM_SUN8I_W5P1
endif
endif
ARCH := arm
# ===Cross compile setting for Android L SDK ===
CROSS_COMPILE := /home/android_sdk/Allwinner/a33/android-L/lichee/out/sun8iw5p1/android/common/buildroot/external-toolchain/bin/arm-linux-gnueabi-
KSRC :=/home/android_sdk/Allwinner/a33/android-L/lichee/linux-3.4
endif
ifeq ($(CONFIG_PLATFORM_ACTIONS_ATV5201), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DCONFIG_PLATFORM_ACTIONS_ATV5201
EXTRA_CFLAGS += -DCONFIG_SDIO_DISABLE_RXFIFO_POLLING_LOOP
ARCH := mips
CROSS_COMPILE := mipsel-linux-gnu-
KVER  := $(KERNEL_VER)
KSRC:= $(CFGDIR)/../../kernel/linux-$(KERNEL_VER)
endif
ifeq ($(CONFIG_PLATFORM_ARM_RTD299X), y)
EXTRA_CFLAGS += -DUSB_XMITBUF_ALIGN_SZ=1024 -DUSB_PACKET_OFFSET_SZ=0
ifeq ($(CONFIG_ANDROID), y)
endif
#ARCH, CROSS_COMPILE, KSRC,and  MODDESTDIR are provided by external makefile
INSTALL_PREFIX :=
endif
ifeq ($(CONFIG_PLATFORM_HISILICON), y)
EXTRA_CFLAGS += -DCONFIG_LITTLE_ENDIAN -DCONFIG_PLATFORM_HISILICON
ifeq ($(SUPPORT_CONCURRENT),y)
endif
ARCH := arm
ifeq ($(CROSS_COMPILE),)
       CROSS_COMPILE = arm-hisiv200-linux-
endif
MODULE_NAME := rtl8192eu
ifeq ($(KSRC),)
       KSRC := ../../../../../../kernel/linux-3.4.y
endif
endif
# Platform setting
ifeq ($(CONFIG_PLATFORM_ARM_SPREADTRUM_6820), y)
ifeq ($(CONFIG_ANDROID_2X), y)
EXTRA_CFLAGS += -DANDROID_2X
endif
EXTRA_CFLAGS += -DCONFIG_PLATFORM_SPRD
EXTRA_CFLAGS += -DPLATFORM_SPREADTRUM_6820
ifeq ($(RTL871X), rtl8188e)
EXTRA_CFLAGS += -DSOFTAP_PS_DURATION=50
endif
_PLATFORM_FILES += platform/platform_sprd_sdio.o
endif
endif
ifeq ($(CONFIG_PLATFORM_ARM_SPREADTRUM_8810), y)
endif
EXTRA_CFLAGS += -DPLATFORM_SPREADTRUM_8810
endif
endif
endif
ifeq ($(CONFIG_PLATFORM_ARM_WMT), y)
_PLATFORM_FILES += platform/platform_ARM_WMT_sdio.o
endif
ARCH := arm
CROSS_COMPILE := /home/android_sdk/WonderMedia/wm8880-android4.4/toolchain/arm_201103_gcc4.5.2/mybin/arm_1103_le-
KSRC := /home/android_sdk/WonderMedia/wm8880-android4.4/kernel4.4/
MODULE_NAME :=8189es_kk
endif
ifeq ($(CONFIG_PLATFORM_RTK119X), y)
#EXTRA_CFLAGS += -DCONFIG_PLATFORM_ARM_SUN7I
#EXTRA_CFLAGS += -DCONFIG_P2P_IPS -DCONFIG_QOS_OPTIMIZATION
EXTRA_CFLAGS += -DCONFIG_QOS_OPTIMIZATION
#EXTRA_CFLAGS += -DCONFIG_#PLATFORM_OPS
#_PLATFORM_FILES += platform/platform_ARM_SUNxI_usb.o
endif
endif
ARCH := arm
# ==== Cross compile setting for Android 4.4 SDK =====
#CROSS_COMPILE := arm-linux-gnueabihf-
KVER  := 3.10.24
#KSRC :=/home/android_sdk/Allwinner/a20/android-kitkat44/lichee/linux-3.4
CROSS_COMPILE := /home/realtek/software_phoenix/phoenix/toolchain/usr/local/arm-2013.11/bin/arm-linux-gnueabihf-
KSRC := /home/realtek/software_phoenix/linux-kernel
MODULE_NAME := 8192eu
endif
ifeq ($(CONFIG_PLATFORM_NOVATEK_NT72668), y)
EXTRA_CFLAGS += -DCONFIG_PLATFORM_NOVATEK_NT72668
ARCH ?= arm
KVER := 3.8.0
KSRC := /Custom/Novatek/TCL/linux-3.8_header
#KSRC := $(KERNELDIR)
endif
ifeq ($(CONFIG_PLATFORM_ARM_TCC8930_JB42), y)
ARCH := arm
CROSS_COMPILE := /home/android_sdk/Telechips/v13.05_r1-tcc-android-4.2.2_tcc893x-evm_build/prebuilts/gcc/linux-x86/arm/arm-eabi-4.6/bin/arm-eabi-
KSRC := /home/android_sdk/Telechips/v13.05_r1-tcc-android-4.2.2_tcc893x-evm_build/kernel
MODULE_NAME := wlan
endif
MODULE_NAME := rtw_sdio
endif
MODULE_NAME := rtw_usb
endif
MODULE_NAME := rtw_pci
endif
endif
USER_MODULE_NAME ?=
ifneq ($(USER_MODULE_NAME),)
MODULE_NAME := $(USER_MODULE_NAME)
endif
ifneq ($(KERNELRELEASE),)
rtk_core :=	core/rtw_cmd.o \
		core/rtw_security.o \
		core/rtw_debug.o \
		core/rtw_io.o \
		core/rtw_ioctl_query.o \
		core/rtw_ioctl_set.o \
		core/rtw_ieee80211.o \
		core/rtw_mlme.o \
		core/rtw_mlme_ext.o \
		core/rtw_wlan_util.o \
		core/rtw_vht.o \
		core/rtw_pwrctrl.o \
		core/rtw_rf.o \
		core/rtw_recv.o \
		core/rtw_sta_mgt.o \
		core/rtw_ap.o \
		core/rtw_xmit.o	\
		core/rtw_p2p.o \
		core/rtw_tdls.o \
		core/rtw_br_ext.o \
		core/rtw_iol.o \
		core/rtw_sreset.o \
		core/rtw_btcoex.o \
		core/rtw_beamforming.o \
		core/rtw_odm.o \
		core/efuse/rtw_efuse.o
$(MODULE_NAME)-y += $(rtk_core)
$(MODULE_NAME)-$(CONFIG_INTEL_WIDI) += core/rtw_intel_widi.o
$(MODULE_NAME)-$(CONFIG_WAPI_SUPPORT) += core/rtw_wapi.o	\
					core/rtw_wapi_sms4.o
$(MODULE_NAME)-y += $(_OS_INTFS_FILES)
$(MODULE_NAME)-y += $(_HAL_INTFS_FILES)
$(MODULE_NAME)-y += $(_OUTSRC_FILES)
$(MODULE_NAME)-y += $(_PLATFORM_FILES)
$(MODULE_NAME)-$(CONFIG_MP_INCLUDED) += core/rtw_mp.o \
					core/rtw_mp_ioctl.o
$(MODULE_NAME)-$(CONFIG_MP_INCLUDED)+= core/rtw_bt_mp.o
endif
endif
obj-$(CONFIG_RTL8814AU) := $(MODULE_NAME).o
else
export CONFIG_RTL8814AU = m
all: modules
modules:
	$(MAKE) ARCH=$(ARCH) CROSS_COMPILE=$(CROSS_COMPILE) -C $(KSRC) M=$(shell pwd)  modules
strip:
	$(CROSS_COMPILE)strip $(MODULE_NAME).ko --strip-unneeded
install:
	install -p -m 644 $(MODULE_NAME).ko  $(MODDESTDIR)
	/sbin/depmod -a ${KVER}
uninstall:
	rm -f $(MODDESTDIR)/$(MODULE_NAME).ko
config_r:
	@echo "make config"
	/bin/bash script/Configure script/config.in
.PHONY: modules clean
clean:
	cd hal/phydm/ ; rm -fr */*.mod.c */*.mod */*.o */.*.cmd */*.ko
	cd hal/phydm/ ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko
	cd hal/led ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko
	cd hal ; rm -fr */*/*.mod.c */*/*.mod */*/*.o */*/.*.cmd */*/*.ko
	cd hal ; rm -fr */*.mod.c */*.mod */*.o */.*.cmd */*.ko
	cd hal ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko
	cd core/efuse ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko
	cd core ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko
	cd os_dep/linux ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko
	cd os_dep ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko
	cd platform ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko
	rm -fr Module.symvers ; rm -fr Module.markers ; rm -fr modules.order
	rm -fr *.mod.c *.mod *.o .*.cmd *.ko *~
	rm -fr .tmp_versions
endif
Then I compiled, installed, and enabled the driver:
make clean
make
sudo make install
sudo modprobe 8812au
There it is:
pi@raspberrypi:~/software/source/rtl8812au $ lsmod
8812au               1379604  0
configs                35110  0
fuse                   99501  5
xt_tcpudp               2526  1
xt_DSCP                 2328  1
iptable_mangle          2047  1
ipt_MASQUERADE          1363  1
nf_nat_masquerade_ipv4     3123  1 ipt_MASQUERADE
iptable_nat             2320  1
nf_nat_ipv4             6071  1 iptable_nat
nf_nat                 18854  2 nf_nat_masquerade_ipv4,nf_nat_ipv4
nf_conntrack_ipv4       8890  2
nf_defrag_ipv4          1824  1 nf_conntrack_ipv4
xt_conntrack            3339  1
nf_conntrack          104700  5 nf_conntrack_ipv4,nf_nat_masquerade_ipv4,xt_conntrack,nf_nat_ipv4,nf_nat
iptable_filter          2197  1
rfcomm                 37646  5
cmac                    3239  1
bnep                   12051  2
hci_uart               19956  1
btbcm                   7916  1 hci_uart
uinput                  9061  2
bluetooth             365511  41 hci_uart,bnep,btbcm,rfcomm
binfmt_misc             7988  1
sg                     20761  0
cdc_acm                19350  0
brcmfmac              222784  0
brcmutil                9092  1 brcmfmac
cfg80211              542899  2 8812au,brcmfmac
rfkill                 20851  5 bluetooth,cfg80211
vc4                   130960  11
snd_bcm2835            24427  4
drm_kms_helper        161750  2 vc4
drm                   355780  5 vc4,drm_kms_helper
snd_pcm                97226  3 snd_bcm2835
syscopyarea             3225  1 drm_kms_helper
snd_timer              23840  2 snd_pcm
sysfillrect             3826  1 drm_kms_helper
sysimgblt               2480  1 drm_kms_helper
fb_sys_fops             1741  1 drm_kms_helper
snd                    70032  8 snd_timer,snd_bcm2835,snd_pcm
i2c_bcm2835             7081  0
bcm2835_gpiomem         3940  0
spi_bcm2835             7596  0
evdev                  12423  14
joydev                  9988  0
uio_pdrv_genirq         3923  0
rpi_ft5406              4783  0
uio                    10204  1 uio_pdrv_genirq
rpi_backlight           2632  0
fixed                   3285  0
i2c_dev                 6913  0
ip_tables              13161  3 iptable_mangle,iptable_filter,iptable_nat
x_tables               20578  7 iptable_mangle,ip_tables,iptable_filter,xt_tcpudp,ipt_MASQUERADE,xt_DSCP,xt_conntrack
ipv6                  405928  84
Good luck with your hacking and cracking. :)
EDIT:
One extra tip...
For my adapter (Rosewill Limited, RNX-AC600UB, RTL8811AU), rtw_power_mgnt=0 is required.
For example:
sudo modprobe 8812au rtw_power_mgnt=0
or create a file like this:
/etc/modprobe.d/8812au.conf
options 8812au rtw_power_mgnt=0
rootkali
Fri Mar 10, 2017 8:06 pm
Thanks Mr.Engman!! The smile on my face when I reboot and see that beautiful little LED light up on my WiFi Card :D
You've been a huge help! Myself and I'm sure many others are greatly appreciative!
rusli
Sun Mar 19, 2017 3:43 pm
Mr Engman,
Do you have the latest driver for RT8812au for 4.9.16-v7+ #978???
MrEngman wrote:
rusli wrote:Hi MrEngman,
Do you have the latest up to date release kernal version 4.9.13-v7+ Build#974 for the driver rtl8812au???
I do now. https://dl.dropboxusercontent.com/u/802 ... 974.tar.gz
MrEngman
MrEngman
Sun Mar 19, 2017 4:23 pm
rusli wrote:Mr Engman,
MrEngman
Yes, there is a driver for your kernel version if you are using Raspbian.
The drivers were installed on Dropbox but they have made a major change to their web site and its really screwed things up. Really annoying to say the least so I have moved the drivers to a new site. You will need to download and install a new script to use the new site.
Download and install the new version of the script with commands
sudo wget http://www.fars-robotics.net/install-wifi -O /usr/bin/install-wifi
sudo chmod +x /usr/bin/install-wifi
The command
sudo install-wifi -h
will show details on using it.
To install the driver on your current kernel you should just need to run command
sudo install-wifi
This will select the driver you need and automatically download and install it.
To download and install the driver without using the script you should be able to use commands
wget http://www.fars-robotics.net/8812au-4.9.13-v7-974.tar.gz
tar xzf 8812au-4.9.13-v7-974.tar.gz
./install.sh
MrEngman
rusli
Sun Mar 19, 2017 4:39 pm
ktb,
on the latest raspbian it only have gcc 4.9 not gcc 6.0 as what you mentioned.
that goes the same to the current ubuntu-mate 16.04.2, it is using gcc 5.0 instead of gcc 6.0.
Will that work.
Because as I follow your steps I have errors!
:~ $ sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-6 20
update-alternatives: error: alternative path /usr/bin/gcc-6 doesn't exist
:~ $ sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-4.9 50
update-alternatives: using /usr/bin/gcc-4.9 to provide /usr/bin/gcc (gcc) in auto mode
:~ $ sudo update-alternatives --install /usr/bin/g++ g++ /usr/bin/g++-6 20
update-alternatives: error: alternative path /usr/bin/g++-6 doesn't exist
~ $ sudo update-alternatives --install /usr/bin/g++ g++ /usr/bin/g++-4.9 50
update-alternatives: using /usr/bin/g++-4.9 to provide /usr/bin/g++ (g++) in auto mode
ktb
Sun Mar 19, 2017 8:37 pm
rusli wrote:ktb,
Will that work.
Yeah, I'm using Raspbian Stretch. If you only have GCC 4.9, then you probably don't need to do that. The point is that the rpi-source tool expects you to use close to the same version of GCC as was used to build the kernel.
rpi-source complains if the major.minor version of gcc differs from the one used to build the kernel.
https://github.com/notro/rpi-source/wiki
rusli
Wed Mar 22, 2017 2:37 am
Mr Engman,
The link which you gave me earlier did not work.
http://www.fars-robotics.net/8812au-4.9 ... 974.tar.gz
There is a kernel update and I need the latest version of the driver.
4.9.16-v7+ #978
Thank you.
MrEngman
Wed Mar 22, 2017 3:47 am
4.9.16-v7+ #978
Thank you.
It works for me. The link you posted here that you say didn't work is rather screwed up
http://www.fars-robotics.net/8812au-4.9.13-v7-974.tar.gztar%20xzf%208812au-4.9.13-v7-974.tar.gz
so I'm not surprised it didn't work. How you ended up with that I have no idea.
The link for the driver version you now want is
http://www.fars-robotics.net/8812au-4.9.16-v7-978.tar.gz
If you use the new script I gave details of in my earlier post it will automatically determine the driver version you need and install it without you having to figure out the filename, although that is not too difficult. Just check the filename and you will see it is based on the kernel revision and build.which you can get from command uname -a or uname -rv
MrEngman
ArchieSt
Re: Netis USB-AC1200 RTL8812AU Driver compile fails
Thu Mar 30, 2017 2:28 pm
Good day Mr Engman
Could you please advise whether you have a compile drive for the Realtek 8812au driver for kernel 4.4.50-v7- 970 and where did you place it?
I have tried your normal Dropbox address as follows but no luck
wget https://dl.dropboxusercontent.com/u/802 ... 970.tar.gz
This on a Rpi 3
Thank you in advance
Regards
Archie
MrEngman
Thu Mar 30, 2017 2:40 pm
ArchieSt wrote:Good day Mr Engman
This on a Rpi 3
Regards
Archie
I have moved the drivers to a new web site as Dropbox made changes a couple of weeks ago which screwed up all the older scripts and addresses.
Details of a new script and new site are available here posting.php?mode=quote&f=66&p=1133815
MrEngman
rockstarbill
Wed Apr 12, 2017 3:00 am
Hey there,
Nice script and driver. I have one issue though, my Pi keeps asking for a keyring password before it will logon to the network with this driver. I use the Pi headless, so I need a way to prevent this. Any ideas?
MrEngman
Wed Apr 12, 2017 9:28 am
rockstarbill wrote:Hey there,
Sorry, but I've no idea what a keyring password is. Never seen it mentioned before but I'm certain it's nothing to do with the driver as I use it on several Pis headless. I had a quick search on the internet and found it appears to be a password used to unlock a storage for other passwords.
Found this but I don't know if it will help http://ask.xmodulo.com/disable-entering ... yring.html
I would suggest you start a new thread to ask about the keyring password and how to fix it.
EDIT: Searching the forum for "keyring" brings up a load of posts.
MrEngman
ArchieSt
Thu Apr 13, 2017 12:23 pm
Good day Mr Engman
Thank you very much for that it is appreciated
Regards
Archie
This on a Rpi 3
Regards
Archie
MrEngman
deadite66
Mon Apr 17, 2017 7:45 am
is this enough to stop the wifi module stopping due to kernel upgrades?
apt-mark hold raspberrypi-bootloader raspberrypi-kernel libraspberrypi-bin
rusli
Wed Apr 26, 2017 6:14 pm
Hi Mr Engman,
I have TP-Link T4UHP wifi adapter, it uses RTL8812AU chipset.
Can you include in this driver for me.
Here is my lsub.
Bus 001 Device 004: ID 2357:0122
Thank you...
MrEngman
Wed Apr 26, 2017 7:14 pm
rusli wrote:Hi Mr Engman,
Here is my lsub.
Thank you...
Hi rusli,
Can you tell me which kernel version you are using so I can compile a version you can try out just to make sure it works OK. If it's OK I will then include it in all the other versions I have.
MrEngman
rusli
Thu Apr 27, 2017 10:07 am
MrEngman,
I have the latest up to date kernel version 4.9.24-v7+ #993.
Did you do the driver for RTL8814AU as well????
Sure, why not...I can test it for you if the driver for TP-LINK T4UHP works with your new kernel updates.
MrEngman
Thu Apr 27, 2017 3:16 pm
rusli wrote:MrEngman,
I have added the USB ID to the 8812au driver.
I assume it is an 8812a device and not an 8821a device as both are handled by the driver I compile.
You can download and install it using commands
wget http://fars-robotics.net/8812au-4.9.24-v7-993.tar.gz
tar xzf 8812au-4.9.24-v7-993.tar.gz
./install.sh
or if you use my install wifi script you can download and install it using command
sudo install-wifi 8812au
Let me know how you get on.
MrEngman
rusli
Thu Apr 27, 2017 3:46 pm
Mr EngMan,
Fantastic! The TP-LINK T4UHP work like a charm!
I download and install via your http link from wget.
It does not work with install-wifi until the next kernel update.
Once again, I appreciate your help.
Thumbs up bro!
./install.sh
MrEngman
propergol
Sat May 27, 2017 8:30 am
Dear MrEngman, :mrgreen:
as you maybe remember I use your driver on my RTL8812 based dongle since I own it.
Sadly the dongle shows some random deconnections even if on latest kernels it is a litle bit better than 2 or 3 month ago.
I have tried using different settings on my routers/AP where I have access to a lot of wifi parameters : nothing helped.
I have tried tu use a powered USB HUB : same result, so it is not a current isue.
Since I was out of solution, I decided to try my Odroid C2 with Debian Jessie (arm64) https://forum.odroid.com/viewtopic.php?f=138&t=19403 instead of my PI3 : results are WORST :lol:
With the driver of this distrib, connection shows ultra low and inconsistant speed.
But but but... after a lot of search it seems I have found a distrib that use a much stable driver for the RTL8812AU : Libreelec :P
Throughput measured with iperf3 shows a very stable 200Mb/s (USB limited speed?) and as far as I tested, no disconnection at all.
So my question is :
would it be possible to use the sources used in Libreelec for this driver on Odroid C2 and compile it for the PI?
Maybe it is not the same source as the one you use now?
Since I am a Linux noob I don't know if this are relevant infos or not sorry.
MrEngman
Mon May 29, 2017 9:55 am
propergol wrote:Dear MrEngman, :mrgreen:
So my question is :
Not sure what your problem could be. I use the driver on a couple of Pis and have no issues with it at all. Do you have a file /etc/modprobe.d/8812au.conf which is used to control power management?
Just so you can try I have changed my drivers to use the code you suggested.
MrEngman
propergol
Mon May 29, 2017 3:46 pm
I am not sure I did install the new driver : I just used "sudo install-wifi", but it appears that the command install driver even if you already have the same version.
Anyway, sadly no change regarding disconections :( but maybe a litle bit more regular throughput.
It looks like the connection reset when no data is send/received for few minutes.
I did check the powersave function in /etc/modprobe.d/8812au.conf and it is of, even my router doesnt reports the dongle as being using the power save mode while other of my device are. (Flags: P=Powersave Mode, S=Short GI, T=STBC, A=Associated, U=Authenticated, G=Guest)
What is strange is that for example streaming a movie from the PI and it's dongle would run perfectly whithout any cut, or lost frame.
But on the other side typing from time to time in a remote SSH console miss typed letters form time to time and can be non responsive for 1 or 2 second.
Ping too doesnt look to generate enough wireless traffic to keep the connection alive.
If I restart a stream then both ping and SSH console are perfect :roll:
I guess I would have to generate kind of dumy traffic in order to get this damn dongle alive :mrgreen:
MrEngman
Mon May 29, 2017 4:33 pm
propergol wrote:I am not sure I did install the new driver : I just used "sudo install-wifi", but it appears that the command install driver even if you already have the same version.
The install-wifi script will load the new driver and overwrite the old one. You will need to reboot to ensure the new driver is used.
I have an ASUS USB-AC56 connected to a Pi 3B. The Pi 3B built in wifi is disabled. I am connected to the Pi using SSH. No sign of any problems so far.
MrEngman
rusli
Sat Jun 10, 2017 12:10 am
Hi Mr Engman,
I have issues with the mt7610u driver. It is having issues with current update kernel version 4.9.31-v7+.
The wifi adapter did not work.
lsusb
Bus 001 Device 006: ID 046d:c05a Logitech, Inc. M90/M100 Optical Mouse
Bus 001 Device 005: ID 046d:c315 Logitech, Inc. Classic Keyboard 200
Bus 001 Device 010: ID 148f:761a Ralink Technology, Corp.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
And I get this error.
modprobe: FATAL: Module mt7610u_sta.ko not found in directory /lib/modules/4.9.31-v7+
Even I try these still it does not work
sudo modprobe /lib/modules/4.9.31-v7+/kernel/drivers/net/wireless/mt7610u_sta.ko
modprobe: FATAL: Module /lib/modules/4.9.31-v7+/kernel/drivers/net/wireless/mt7610u_sta.ko not found in directory /lib/modules/4.9.31-v7+
MrEngman
Sat Jun 10, 2017 7:48 am
lsusb
This post is for the 8812au driver not the mt7610 driver. You should really start a new post.
As you have now got kernel 4.9.31-v7+ I expect you have run command sudo rpi-update. Every time you update the kernel you will need to re-install the driver.
Run the wifi install script using command sudo install-wifi and it will install the driver and you should then find it works.
MrEngman
Return to “Raspbian”
Who is online
Users browsing this forum: No registered users and 13 guests
