MrEngman
Re: ASUS USB-AC56 (RTL8812AU/RTL8821AU) Driver compile fails
Sun Nov 12, 2017 9:35 am
rusli wrote:
Sun Nov 12, 2017 7:51 am
[Hi Mr EngMan,
Today I cannot seems to update my rtl8812au driver on my ubuntu-mate 16.04.2.
Running kernel 4.9.61-v7+ #1049
As I run install-wifi it gives me an error. It stated that I am not running Raspbian OS. So exiting script.
*** Raspberry Pi wifi driver installer by MrEngman.
*** Performing self-update
*** Relaunching after update
This script installs drivers for Raspbian.
You do not appear to be using a Raspbian OS so exiting the script.
Try it again. Should be OK now.
rusli
Thu Dec 14, 2017 6:53 am
Hi EngMan,
There is no driver update for kernel
4.9.68-v7+ #1064
Thank you....
MrEngman
Thu Dec 14, 2017 8:45 am
Hi EngMan,
4.9.68-v7+ #1064
Thank you....
Should be available now.
evdubrovskiy
Sun Dec 24, 2017 11:17 am
Hi Mr Engman,
I have TP-Link T4UH v.2 wifi adapter, it uses RTL8812AU chipset.
Can you include in this driver for me.
Here is my lsub.
Bus 001 Device 006: ID 2357:010e
uname -a
Linux RaspberryPi 4.9.70-v7+ #1068 SMP Mon Dec 18 22:12:55 GMT 2017 armv7l GNU/Linux
Thank you...
MrEngman
Sun Dec 24, 2017 1:07 pm
Hi Mr Engman,
Here is my lsub.
uname -a
Thank you...
Hi evdubrovskiy,
evdubrovskiy
Mon Dec 25, 2017 5:33 am
Hi Mr Engman,
It worked, thank you! lsusb still does not show the name of the device.... but it works! :)
And how to enable driver support for VHT? When you build the driver to change
CONFIG_MP_VHT_HW_TX_MODE = n?
GhostriderX11
Sun Dec 31, 2017 5:26 pm
I am trying to install the driver for this build:
Your current kernel revision = 4.9.29-10-osmc+
Your current kernel build = #1
Your wifi module is Bus 001 Device 004: ID 2357:010e
And it uses the 8812au driver.
If possible could you update the driver or let me know what is required, thank you.
Return to “Raspbian”
Who is online
Users browsing this forum: DirkS, tpyo kingg and 17 guests
