MrEngman
Re: ASUS USB-AC56 (RTL8812AU/RTL8821AU) Driver compile fails
Sun Nov 12, 2017 9:35 am
rusli wrote:
Sun Nov 12, 2017 7:51 am
[Hi Mr EngMan,
Today I cannot seems to update my rtl8812au driver on my ubuntu-mate 16.04.2.
Running kernel 4.9.61-v7+ #1049
As I run install-wifi it gives me an error. It stated that I am not running Raspbian OS. So exiting script.
*** Raspberry Pi wifi driver installer by MrEngman.
*** Performing self-update
*** Relaunching after update
This script installs drivers for Raspbian.
You do not appear to be using a Raspbian OS so exiting the script.
Try it again. Should be OK now.
rusli
Thu Dec 14, 2017 6:53 am
Hi EngMan,
There is no driver update for kernel
4.9.68-v7+ #1064
Thank you....
MrEngman
Thu Dec 14, 2017 8:45 am
Hi EngMan,
4.9.68-v7+ #1064
Thank you....
Should be available now.
evdubrovskiy
Sun Dec 24, 2017 11:17 am
Hi Mr Engman,
I have TP-Link T4UH v.2 wifi adapter, it uses RTL8812AU chipset.
Can you include in this driver for me.
Here is my lsub.
Bus 001 Device 006: ID 2357:010e
uname -a
Linux RaspberryPi 4.9.70-v7+ #1068 SMP Mon Dec 18 22:12:55 GMT 2017 armv7l GNU/Linux
Thank you...
MrEngman
Sun Dec 24, 2017 1:07 pm
Hi Mr Engman,
Here is my lsub.
uname -a
Thank you...
Hi evdubrovskiy,
evdubrovskiy
Mon Dec 25, 2017 5:33 am
Hi Mr Engman,
It worked, thank you! lsusb still does not show the name of the device.... but it works! :)
And how to enable driver support for VHT? When you build the driver to change
CONFIG_MP_VHT_HW_TX_MODE = n?
GhostriderX11
Sun Dec 31, 2017 5:26 pm
I am trying to install the driver for this build:
Your current kernel revision = 4.9.29-10-osmc+
Your current kernel build = #1
Your wifi module is Bus 001 Device 004: ID 2357:010e
And it uses the 8812au driver.
If possible could you update the driver or let me know what is required, thank you.
Return to “Raspbian”
