mariourquia23
Re: ASUS USB-AC56 (RTL8812AU/RTL8821AU) Driver compile fails
Thu Dec 24, 2015 3:27 am
MrEngman wrote:
misra wrote:I'm trying to install a TP-Link Acher T4U.
[email protected]:~/8812au $ uname -rv
4.1.15-v7+ #830 SMP Tue Dec 15 17:02:45 GMT 2015
[email protected]:~/8812au $ lsusb
Bus 001 Device 006: ID 2357:0101
Bus 001 Device 004: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 007: ID 7392:7811 Edimax Technology Co., Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
The T4U is installed as Devince 006.
I've downloaded 8812au-4.1.15-830.tar.gz and installed. No luck.
Am I missing something?
Try 8812au-4.1.15-v7-830.tar.gz. Note: extra -v7
wget https://dl.dropboxusercontent.com/u/80256631/8812au-4.1.15-v7-830.tar.gz
tar xzf 8812au-4.1.15-v7-830.tar.gz
./install.sh
MrEngman
I Bought a Ourlink 802.11ac dongle for my raspberry pi 2, the outcome of uname and lsusb commands are:
(note for the 0bda:a811 id)
[email protected] ~ $ lsusb
Bus 001 Device 005: ID 046d:c517 Logitech, Inc. LX710 Cordless Desktop Laser
Bus 001 Device 007: ID 0bda:a811 Realtek Semiconductor Corp.
[email protected] ~ $ uname -r
4.1.7v7-aufs
[email protected] ~ $ uname -a
Linux raspberrypi 4.1.7v7-aufs #1 SMP PREEMPT Wed Sep 16 13:19:27 CEST 2015 armv7l GNU/Linux
I got the drivers with the dongle, but when I'm compiling it got error "/lib/modules/4.1.7v7-aufs/build: No such file or directory" which means that I don't have linux-headers installed, the case is that for my kernel looks like there is none.
[email protected] ~/Desktop/linux $ sudo apt-get install linux-headers-
linux-headers-3.10-3-all              linux-headers-3.18.0-trunk-all
linux-headers-3.10-3-all-armhf        linux-headers-3.18.0-trunk-all-armhf
linux-headers-3.10-3-common           linux-headers-3.18.0-trunk-common
linux-headers-3.10-3-rpi              linux-headers-3.18.0-trunk-rpi
linux-headers-3.12-1-all              linux-headers-3.18.0-trunk-rpi2
linux-headers-3.12-1-all-armhf        linux-headers-3.6-trunk-all
linux-headers-3.12-1-common           linux-headers-3.6-trunk-all-armhf
linux-headers-3.12-1-rpi              linux-headers-3.6-trunk-common
linux-headers-3.16.0-4-all            linux-headers-3.6-trunk-rpi
linux-headers-3.16.0-4-all-armhf      linux-headers-rpi
linux-headers-3.16.0-4-common         linux-headers-rpi2-rpfv
linux-headers-3.16.0-4-rpi            linux-headers-rpi-rpfv
could you please help me?
MrEngman
Thu Dec 24, 2015 10:14 am
Hi mariourquia23,
The error you see is because when compiling modules a link is needed to the linux source or headers. You can create the link using command
sudo ln -s /home/pi/src/linux /lib/modules/$(uname -r)/build
You will need to change the directory /home/pi/src/linux to the directory where your linux source is saved.
Just one warning and that is that the output of your command uname -a appears to show you may be using Berryboot. If it is I'm not sure compiling the module using any of the header directories you showed in you post will work. If you are using Berryboot I would suggest it might be a good idea to look on the Berryboot forum regarding compiling extra modules.
MrEngman
diederik
Thu Dec 24, 2015 10:18 am
MrEngman wrote:I'm not sure compiling the module using any of the header directories you showed in you post will work.
I am sure and can tell you that it won't work.
Damaiste
Thu Dec 24, 2015 10:16 pm
I am a complete noob with linux and I'm trying to learn this stuff as I go. I recently purchased a raspberry pi and installed raspbian, I already owned an alpha awus036ach which uses this driver and i would really like to continue using this wifi adapter. I followed the step in this guide to download and install the driver, reset the pi, and now nothing has a changed. My wifi adapter still won't power on. any suggestions on how to proceed or what to test / try next? any support will be appreciated.
MrEngman
Thu Dec 24, 2015 10:56 pm
Damaiste wrote:I am a complete noob with linux and I'm trying to learn this stuff as I go. I recently purchased a raspberry pi and installed raspbian, I already owned an alpha awus036ach which uses this driver and i would really like to continue using this wifi adapter. I followed the step in this guide to download and install the driver, reset the pi, and now nothing has a changed. My wifi adapter still won't power on. any suggestions on how to proceed or what to test / try next? any support will be appreciated.
How have you connected your wifi adapter to the Pi? Do you use a hub or is it directly connected to the Pi?
If connected directly to the Pi it could be a power issue. When you reset the Pi and it is starting up do you see the power LED flashing or turning off at all?
What model is your Pi? What does command uname -a show? What driver version did you download and install?
MrEngman
Damaiste
Thu Dec 24, 2015 11:14 pm
MrEngman
Right now it is connected directly to the Pi, I don't have access to a hub atm.
I assume your referring to the LED on the wifi adapter, it does not turn on at all when the Pi is booting. I don't think its a power issue since it powers on when I boot up OSMC, but I may be wrong.
I am using a Pi 2.
Linux raspberry 4.1.13-v7+ #826 SMP PREEMPT ... arm7l GNU/Linux
I installed this, wget https://dl.dropboxusercontent.com/u/802 ... 826.tar.gz
Thanks for looking over this.
diederik
Thu Dec 24, 2015 11:41 pm
Damaiste wrote:I assume your referring to the LED on the wifi adapter, it does not turn on at all when the Pi is booting.
No, he meant the red (=power) LED on the Pi itself. If it is blinking or completely off then it is a power issue.
Damaiste
Thu Dec 24, 2015 11:57 pm
Oh, well in that case the red light is steady on.
MrEngman
Fri Dec 25, 2015 12:05 am
Exactly
MrEngman
Damaiste
Fri Dec 25, 2015 12:50 am
Exactly
MrEngman
The red light is on steady for the most part, it has 1 blink during boot up
Damaiste
Sat Dec 26, 2015 12:46 am
Just a quick follow up, I started off with a fresh install of Raspbian today, did the update, then ran through the steps listed in this discussion and my Alpha awus036ach is working like a champ. Thanks for all the great info and keep up the excellent work.
MrEngman
Sat Dec 26, 2015 3:05 am
Damaiste wrote:Just a quick follow up, I started off with a fresh install of Raspbian today, did the update, then ran through the steps listed in this discussion and my Alpha awus036ach is working like a champ. Thanks for all the great info and keep up the excellent work.
That's good to hear. Have fun with your Pi. Happy Christmas.
MrEngman
onclesam691
Thu Jan 28, 2016 3:41 pm
I have a Raspberry Pi B+ with OpenElec.
uname -a: Linux OpenELEC 3.12.26-rpi-aufs #1 PREEMPT Thu Aug 14 10:48:01 CEST 2014 armv6l GNU/Linux
I have downloaded a version of the drivers on this post but it seems that it is for another version
insmod /lib/modules/3.12.26-rpi-aufs/kernel/drivers/net/wireless/8812au.ko
insmod: ERROR: could not insert module /lib/modules/3.12.26-rpi-aufs/kernel/drivers/net/wireless/8812au.ko: Invalid module format
Can someone give the correct ko because we can't use the make command under openelec.
MrEngman
Thu Jan 28, 2016 9:11 pm
onclesam691 wrote:Hi,
From the output of command uname -a it appears as though you are running BerryBoot. In which case the driver needs compiling for BerryBoot.
MrEngman
Nixies
Sat Apr 16, 2016 3:42 pm
Hello MrEngman,
Like jfleboite, I would like to use the WUSB6300 Linksys adapter that embeds a Realtek driver matching the rtl881au WiFi driver on my RPI but it does not work. I saw that you were able to compile a driver for him but I tried it and it does not work on my distrib. The version I am using is the 4.1.7-v7+ #817 SMP PREEMPT Sat Sep 19 15:32:00 BST 2015 armv7l GNU/Linux.
I tried to do it on my Raspi but it did not work because of header missmatch :-(
If you have the means to compile the driver for my kernel version it should be very welcome :-), or probably explain me the way of doing it...
In advance I thank you very much.
Best regards,
Nixies
MrEngman
Sun Apr 17, 2016 1:09 pm
Nixies wrote:Hello MrEngman,
Best regards,
Nixies
Try this
wget https://dl.dropboxusercontent.com/u/80256631/8812au-4.1.7-v7-817.tar.gz
tar xzf 8812au-4.1.7-v7-817.tar.gz
./install.sh
The command ./install.sh installs the driver and any other required files.
I use a standard format for the filename of the drivers I compile. If you update your kernel use command uname -a to find the new kernel revision and build and change the file name above to use the new kernel version and build.
As an example for kernel 4.1.21-v7+ #872 you would need to change the filename to 8812au-4.1.21-v7-872.tar.gz in the commands above.
MrEngman
Nixies
Sun Apr 17, 2016 3:51 pm
Hello MrEngman,
I have just tried this and it works perfectly :) . I thank you very much.
Does it mean that this driver is available for any kernel version ? We just have to modify the file name as explained and it's ok ?
Are you at the origine of these driver compilation or is it a job of the community ?
Sorry for these questions but I am a bit curious ;)
Thanks a lot again !
Nixies
MrEngman
Sun Apr 17, 2016 4:23 pm
Nixies
I re-compile this driver and several others, 8188eu, 8192eu, mt7610 and mt7612(mt7662) whenever there is an update via rpi-update. All versions for raspbian kernels 3.18, 4.1 and 4.4 are available on Dropbox.
MrEngman
Nixies
Sun Apr 17, 2016 5:27 pm
Ok, I see. Thank you very much for this great job.
Do you have an address where to learn how to re-compile drivers for Raspbian ?
Thanks,
Nixies
Nixies
Tue Apr 19, 2016 3:26 pm
Hello MrEngman,
Anyway I thank you very much for your help.
Nixies
gabe817
Edimax EW-7811UAC (RTL8812AU)
Wed Apr 20, 2016 11:02 pm
Hello MrEngman,
I'm using the EW-7811UAC on a Raspberry Pi B+ (I've also tried a Pi 2) configured as a WiFi bridge (Access Point without DHCP enabled). The Pi is connected directly to my router via an Ethernet cable. I'm doing this in order to have WiFi available that conforms to 802.11ac specs. It seems no matter what I do I cannot achieve link speeds anywhere near the 433 Mbps max. The best I can do on 802.11ac is 54 Mbps and on 802.11n 72 Mbps
Here's what I get from iwconfig -
wlan0 IEEE 802.11AC ESSID:"RasPiAP" Nickname:"<[email protected]>"
Mode:Master Frequency:5.765 GHz Access Point: 74:DA:38:6A:04:AD
Bit Rate:54 Mb/s Sensitivity:0/0
Retry:off RTS thr:off Fragment thr:off
Power Management:off
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
The uname -a command gives me this -
Linux raspberrypi 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux
and I'm using this driver -
wget https://dl.dropboxusercontent.com/u/802 ... 858.tar.gz - which I believe you may be the author.
This is my hostapd.conf file -
ctrl_interface=/var/run/hostapd
macaddr_acl=0 auth_algs=1
driver=nl80211
interface=wlan0
bridge=br0
country_code=US
hw_mode=a
ieee80211n=1
#ieee80211h=1
wmm_enabled=1
#ht_capab=[HT40+][SHORT-GI-40][DSSS_CK-40]
ieee80211ac=1
channel=153
ssid=RasPiAP
ignore_broadcast_ssid=0
wpa=3
wpa_passphrase=password
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
I've tried uncommenting the commented lines in various combinations but without success.
By the way, I connected this adapter to a Windows 10 notebook PC configured as a network bridge and was able to a attain a link speed of 433 Mbps so I know my adapter is working.
Any help is greatly appreciated - I've been fighting this for a week.
Baumi25
Wed May 11, 2016 8:34 am
Hey,
First of all, thank you MrEngman for your great work!
But here comes my problem:
I am using an Edimax 7811USC which also uses the RTL8812AU Driver.
After following MrEngmans guide, I got the adapter working in managed mode and could easily connect to my wifi.
However, when I put the adapter in monitor mode (by creating a seperate interface "mon0") and try to change the channel, it gives me the error: Operation not supported (-95).
Can someone explain to me why this error occures? I have been working on this for several days now, but couldn't find a solution.
Baumi25
ArchieSt
Mon Jul 11, 2016 9:36 am
Good day MrEngman
I see you are extremely knowledgeable with usb wifi problems. I am very new to all of this and require some assistance if you do not mind.
I have a RPi 2B and an Asus USB-AC56 Wifi dongle.
I downloaded your compiled driver 8812au-4.4.14-v7-896.tar.gz driver
used tar -xzf 8812au-4.4.14-v7-896.tar.gz to extract the file
Then i executed ./install.sh and rebooted the RPi.
The drivers do not load and the unit does not come up
Could you please assist?
I would really appreciate your assistance
This is what I have on my Rpi
[email protected]:~ $ lsusb
Bus 001 Device 009: ID 1a2c:0b2a China Resource Semico Co., Ltd
Bus 001 Device 008: ID 058f:6254 Alcor Micro Corp. USB Hub
Bus 001 Device 007: ID 12d1:1003 Huawei Technologies Co., Ltd. E220 HSDPA Modem / E230/E270/E870 HSDPA/HSUPA Modem
Bus 001 Device 006: ID 1bcf:0005 Sunplus Innovation Technology Inc.
Bus 001 Device 005: ID 058f:6254 Alcor Micro Corp. USB Hub
Bus 001 Device 004: ID 0b05:17d2 ASUSTek Computer, Inc.
$ lsmod
Module Size Used by
bnep 11853 2
bluetooth 365780 5 bnep
cfg80211 499234 0
rfkill 21397 3 cfg80211,bluetooth
snd_bcm2835 23163 1
snd_pcm 95441 1 snd_bcm2835
snd_timer 22396 1 snd_pcm
snd 68368 5 snd_bcm2835,snd_timer,snd_pcm
bcm2835_gpiomem 3823 0
bcm2835_wdt 4133 0
uio_pdrv_genirq 3718 0
uio 10230 1 uio_pdrv_genirq
evdev 11650 6
joydev 9194 0
sr_mod 14471 0
sg 20799 0
cdrom 31754 1 sr_mod
option 32256 0
usb_wwan 9052 1 option
usbserial 29964 2 option,usb_wwan
i2c_dev 6578 0
fuse 89800 3
ipv6 367543 38
ifconfig
eth0 Link encap:Ethernet HWaddr b8:27:eb:83:6b:b7
inet addr:192.168.1.2 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fd88:cefa:95c3:4900:4506:e3fc:a931:a8e5/64 Scope:Global
inet6 addr: fe80::15ff:5e91:97ce:5945/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:557 errors:0 dropped:0 overruns:0 frame:0
TX packets:507 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:48282 (47.1 KiB) TX bytes:74161 (72.4 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:2 errors:0 dropped:0 overruns:0 frame:0
TX packets:2 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:276 (276.0 B) TX bytes:276 (276.0 B)
MrEngman
Mon Jul 11, 2016 12:24 pm
ArchieSt wrote:Good day MrEngman
I have just set up a Pi 2 B, with raspbian 4.4.14-v7+ #896, with the Asus USB-AC56 wifi dongle and it is working OK.
I assume you are using Raspbian. Is it wheezy or jessie? Can you post the output of command uname -a and the contents of files /etc/network/interfaces and /etc/wpa_supplicant/wpa_supplicant.conf?
MrEngman
ArchieSt
Mon Jul 11, 2016 1:08 pm
Good day MrEngman
Thank you for your quick response
I am indeed using Rasbian JESSIE
[email protected]:~/Downloads $ uname -a
Linux raspberrypi 4.4.14+ #896 Sat Jul 2 14:16:46 BST 2016 armv6l GNU/Linux
GNU nano 2.2.6 File: /etc/network/interfaces Modified
allow-hotplug wlan0
iface wlan0 inet static
address 192.168.42.1
netmask 255.255.255.0
# wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
#allow-hotplug wlan1
GNU nano 2.2.6 File: /etc/wpa_supplicant/wpa_supplicant.conf
country=ZA
update_config=1
#iface wlan1 inet manual
Return to “Raspbian”
