neovanmatix
Run script if screensaver is active?
Sat Jan 11, 2014 3:53 pm
Hi there,
is it possible to run a program/script when the default screensaver starts and ends?
I've attached a little PiTFT-display which a backlight which i can control via GPIO.
Actual, the display is getting black but the backlight is still on.
I've found nothing, how i could start scripts when the default screensaver is starting/ending; maybe someone could give me an hint?
Re: Run script if screensaver is active?
Sat Jan 11, 2014 11:59 pm
Pull the source code: http://www.jwz.org/xscreensaver/xscreen ... .26.tar.gz
You can probably replace ../xscreensaver-5.26/driver/dpms.c with your own version to switch off/switch on the backlight by twiddling the GPIO pin.
This is a doctor free zone.
KyleBoyer
Wed Mar 25, 2015 11:57 pm
Was there a solution to this? I am looking into the same idea, and I'm surprised there isn't a solution yet.
florca
Thu Mar 26, 2015 7:39 am
Yes, there's a simple solution here which you could adapt.
https://github.com/ramses0/xscreensaver-pi-hdmi
After this was written there's a new "vcgencmd display_power 1 | 0" command to turn HDMI power on | off, which I've edited the script to run instead of the current approach. I use it as originally designed to control the power on the HDMI monitor.
Phil
Return to “Raspbian”
