Jb2cool
Unable to install newer version of curl/libcurl3
Thu Jan 02, 2014 9:23 am
I have a user that's using curl (curlftpfs) to locally mount a USB hard drive that's being served by his Netgear WNDR4000 router. When attempting to connect the FTP path he gets this error;
"Error connecting to ftp: Got a 230 ftp-server response when a 220 was expected".
Now when he tries this with FileZilla on his PC he does indeed get a 230 response but FileZilla is happy with this code and continues.
Looking at a ftp code page online http://en.wikipedia.org/wiki/List_of_FT ... turn_codes
230 User logged in, proceed. Logged out if appropriate.
220 Service ready for new user.
Seems like both should do fine. But it will not accept 230 only 220.
He's done some digging and found that this is infact a bug in the curl libary. The owner of curl "Haxx" have informed him that the bug was corrected in 7.31.0 version of curl. The version available in the Raspbian repository is 7.26.0 but there are also .deb files for a newer version 7.34.0. I tried downloading these for him but they seem to have a dependency mismatch with libc6 where 2.13-38+rpi2 is installed and the new versions of curl/libcurl3 want >=2.17.
Any tips on where to go from here?
rpdom
Re: Unable to install newer version of curl/libcurl3
Thu Jan 02, 2014 10:40 am
The later .deb file in the Raspbian repository is for Rasbian Jessie - the release that will eventually replace Raspbian Wheezy.
You could take a (small) chance and start using Jessie now. Initially you will have a huge number of software upgrades, but you will get the later libcurl3 as well.
skribtsov
Tue Jan 07, 2014 12:12 pm
Got a similar problem with libc6 (> 2.17) while trying to install ssmtp
Can you provide step-by-step instructions please, how I would get this library from Jessie release (If I got you right). Thanks!
plugwash
Tue Jan 07, 2014 2:05 pm
Jb2cool wrote: Any tips on where to go from here?
Something along the lines of
apt-get install build-essential devscripts
apt-get build-dep curl
dget http://ftp.de.debian.org/debian/pool/ma ... 34.0-1.dsc
cd curl-7.34.0
dpkg-buildpackage -b
seanhq
Fri Apr 18, 2014 4:56 pm
make sure you purge all you curlftpfs stuff
apt-get purge curl libcurl3 curlftpfs
I needed to apt-get install automake
Also the versions are different now so go to
http://ftp.de.debian.org/debian/pool/main/c/curl/
and find the newest one
to add sources you need to nano /etc/apt/sources.list and add the same line as above with deb-src instead of deb
EDIT: the line to add is "deb-src http://mirrordirector.raspbian.org/raspbian/ wheezy main contrib non-free rpi"
then "dpkg -i FILENAME" the files that are inside the directory after "dpkg-buildpackage -b", some failed for me but I the ones that worked were enough
then "apt-get intsall curlftpfs"
this worked for me!
rpdom
Fri Apr 18, 2014 5:58 pm
seanhq wrote:to add sources you need to nano /etc/fstab and add the same line as above with deb-src instead of deb
I think you mean /etc/apt/sources.list (or create a new file in /etc/apt/sources.list.d/) not /etc/fstab!
seanhq
Fri Apr 18, 2014 8:52 pm
thanks!
btw great mounting instructions for curlftpfs here
http://www.ubuntugeek.com/how-to-mount- ... buntu.html
that will tell you about your fstab
blobby55
Mon Sep 14, 2015 3:20 pm
I tried this method for installing curl 7.38 but it depends on a newer librtmp0. Since I cannot go back and compile every dependency, I was wondering if anyone has a better idea for updating this package. Should I just wait for Raspbian jessie?
Return to “Raspberry Pi OS”
