Finally got my pi to print on my Canon printer (not sure which fixed it), then tried to start for a lamp server...Apache2 common won't configure.
tannenba@raspberrypi:~$ sudo apt-get -f install apache2 Reading package lists... Done
Building dependency tree
apache2 is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 8 not upgraded.
3 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue [Y/n]? Y
Setting up apache2.2-common (2.2.22-13) ...
insserv: warning: script 'mathkernel' missing LSB tags and overrides
insserv: There is a loop between service minidlna and mathkernel if stopped
insserv: loop involving service mathkernel at depth 2
insserv: loop involving service minidlna at depth 1
insserv: Stopping mathkernel depends on minidlna and therefore on system facility `$all' which can not be true!
insserv: exiting now without changing boot order!
update-rc.d: error: insserv rejected the script header
dpkg: error processing apache2.2-common (--configure):
subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of apache2-mpm-worker:
apache2-mpm-worker depends on apache2.2-common (= 2.2.22-13); however:
Package apache2.2-common is not configured yet.
dpkg: error processing apache2-mpm-worker (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of apache2:
apache2 depends on apache2-mpm-worker (= 2.2.22-13) | apache2-mpm-prefork (= 2.2.22-13) | apache2-mpm-event (= 2.2.22-13) | apache2-mpm-itk (= 2.2.22-13); however:
Package apache2-mpm-worker is not configured yet.
Package apache2-mpm-prefork is not installed.
Package apache2-mpm-event is not installed.
Package apache2-mpm-itk is not installed.
apache2 depends on apache2.2-common (= 2.2.22-13); however:
dpkg: error processing apache2 (--configure):
apache2.2-common
apache2-mpm-worker
apache2
E: Sub-process /usr/bin/dpkg returned an error code
What is 'mathkernel'?
I removed minidlna, so why is it still a problem?
Is there an easy fix?
