Lieta
udev wrong group
Fri Dec 27, 2013 8:06 pm
Hi.
I've set up this udev rule:
cat /etc/udev/rules.d/100-usbadapter.rules
SUBSYSTEM=="usb", ATTRS{idVendor}=="10c4", ATTRS{idProduct}=="ea60", ATTRS{serial}=="0001", SYMLINK+="ttyUSBzwave", GROUP="dialout", MODE="0660"
I'd like it to create a link with group set to "dialout", but instead it's a root:
pi@raspberrypi ~ $ ls -l /dev/ttyUSB*
crw-rw---T 1 root dialout 188, 0 Jan  1  1970 /dev/ttyUSB0
lrwxrwxrwx 1 root root        15 Jan  1  1970 /dev/ttyUSBzwave -> bus/usb/001/004
Re: udev wrong group
Fri Dec 27, 2013 9:40 pm
/dev/ttyUSB0 is a character device so it's owned by root and in group dialout
/dev/USBzwave is a symbolic link to bus/usb/001/004 so will always be owned by root.root (that's how all symlinks work)
What's the ownership and permission bits for the target of the symlink bus/usb/001/004?
Can a user who's in group dialout open and read/write your /dev/USBzwave device?
Lieta
Sun Dec 29, 2013 7:10 am
DougieLawson wrote:What's the ownership and permission bits for the target of the symlink bus/usb/001/004?
pi@raspberrypi ~ $ ls -l /dev/bus/usb/001/004
crw-rw---T 1 root dialout 189, 3 Jan  1  1970 /dev/bus/usb/001/004
DougieLawson wrote:Can a user who's in group dialout open and read/write your /dev/USBzwave device?
No. That's the problem.
Sun Dec 29, 2013 10:46 am
Can you change your application to try to open /dev/bus/usb/001/004? (This is just a temporary experiment, not a permanent fix because the device abstraction layer is there to give movable things fixed names.)
Lieta
Sun Dec 29, 2013 11:38 am
DougieLawson wrote:Can you change your application to try to open /dev/bus/usb/001/004? (This is just a temporary experiment, not a permanent fix because the device abstraction layer is there to give movable things fixed names.)
Doesn't work. It prints: "ERROR: interface FAILED to connect to Port /dev/bus/usb/001/004 (retrying)"
Sun Dec 29, 2013 1:29 pm
So it's not a user permissions thing. It's a device driver / non-functional device problem.
nroff-man
Sun Dec 29, 2013 6:20 pm
Hi
This is what I use for a cp2102 device, adjust for your own adapter and
post your solution if it works for you.
KERNEL=="ttyUSB*", ATTRS{idVendor}=="10c4", ATTRS{idProduct}=="ea60", GROUP="dialout", MODE="0660", RUN+="/bin/ln -sf %k /dev/cygnal"
good luck.
Lieta
Wed Jan 01, 2014 8:42 pm
DougieLawson wrote:So it's not a user permissions thing. It's a device driver / non-functional device problem.
But it works with "/dev/ttyUSB0".
Lieta
Wed Jan 01, 2014 8:43 pm
nroff-man wrote:Hi
good luck.
Doesn't work. Owner and group is still "root":
lrwxrwxrwx 1 root root         7 Jan  1  1970 /dev/ttyUSBzwave -> ttyUSB0
Wed Jan 01, 2014 9:05 pm
The owner and group of a symbolic link will often be root. It doesn't matter. It has read/write/execute permissions for everyone. It's only purpose is to be a link/shortcut to the real file and it is the permissions on the that file that matter.
Lieta
Thu Jan 02, 2014 8:24 am
rpdom wrote:The owner and group of a symbolic link will often be root. It doesn't matter. It has read/write/execute permissions for everyone. It's only purpose is to be a link/shortcut to the real file and it is the permissions on the that file that matter.
Ok, I'll try, but then it doesn't make sense to specify GROUP="dialout" in the rule.
Lieta
Thu Jan 02, 2014 5:47 pm
udev rule proposed by nroff-man works. Rule
KERNEL=="ttyUSB*", ATTRS{idVendor}=="10c4", ATTRS{idProduct}=="ea60", ATTRS{serial}=="0001", GROUP="dialout", MODE="0660", RUN+="/bin/ln -sf %k /dev/ttyUSBzwave"
creates
and "/dev/ttyUSBzwave" is accessible by application. The initial rule didn't work, because group of "/dev/bus/usb/001/004" was "root":
crw-rw-r-T 1 root root 189, 3 Jan  1  1970 /dev/bus/usb/001/004
jojopi
Thu Jan 02, 2014 6:03 pm
/dev/bus/usb/xxx/yyy is a different and lower-level interface than /dev/ttyUSBx. You need the provide the correct type of device for the application you are using.
You should not normally need to create your own udev rules or symlinks. If you want a persistent device name for a ttyUSBx, which does not change based on detection order, there should already be such a symlink under /dev/serial/by-id/.
Lieta
Thu Jan 02, 2014 7:26 pm
jojopi wrote:/dev/bus/usb/xxx/yyy is a different and lower-level interface than /dev/ttyUSBx. You need the provide the correct type of device for the application you are using.
You are right, there is and it works.
lrwxrwxrwx 1 root root 13 Jan  1  1970 usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0001-if00-port0 -> ../../ttyUSB0
Return to “Raspberry Pi OS”
