sudo update-rc.d /etc/init.d/pirservice.sh defaults
sudo update-rc.d /etc/init.d/pirservice.sh remove
ls -l /etc/rc?.d/*pirservice.sh
When I try to use the following:
sudo update-rc.d /etc/init.d/pirservice.sh disable
update-rc.d: using dependency based boot sequencing
update-rc.d: error: cannot find a LSB script for /etc/init.d/pirservice.sh
#!/bin/sh
# /etc/init.d/pirservice.sh
### BEGIN INIT INFO
# Provides: myservice
# Required-Start: $remote_fs $syslog
# Required-Stop: $remote_fs $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: Put a short description of the service here
# Description: Put a long description of the service here
### END INIT INFO
# Change the next 3 lines to suit where you install your script and what you want to call it
DIR=/usr/local/bin/myservice
DAEMON=$DIR/pir.py
DAEMON_NAME=pir
# This next line determines what user the script runs as.
# Root generally not recommended but necessary if you are using the Raspberry Pi GPIO from Python.
DAEMON_USER=root
# The process ID of the script when it runs is stored here:
PIDFILE=/var/run/$DAEMON_NAME.pid
. /lib/lsb/init-functions
do_start () {
log_daemon_msg "Starting system $DAEMON_NAME daemon"
start-stop-daemon --start --background --pidfile $PIDFILE --make-pidfile --user $DAEMON_USER --startas $DAEMON
log_end_msg $?
do_stop () {
log_daemon_msg "Stopping system $DAEMON_NAME daemon"
log_end_msg $?
case "$1" in
start|stop)
do_${1}
log_end_msg $?
do_stop () {
start-stop-daemon --stop --pidfile $PIDFILE --retry 10
log_end_msg $?
case "$1" in
start|stop)
do_${1}
restart|reload|force-reload)
do_stop
do_start
status)
status_of_proc "$DAEMON_NAME" "$DAEMON" && exit 0 || exit $?
echo "Usage: /etc/init.d/$DEAMON_NAME {start|stop|restart|status}"
exit 1
esac
exit 0
