fergusondavid6
xsnow on Raspbian
Sat Dec 14, 2013 10:55 pm
I was wanting to install xsnow (http://dropmix.xs4all.nl/rick/Xsnow/) on my Raspberry Pi, but when I followed the tutorial (http://www.cyberciti.biz/tips/linux-unix-xsnow.html), it said xsnow not found.
Could someone explain to me why this is happening, and how I can install it on my pi?
Re: xsnow on Raspbian
Sat Dec 14, 2013 11:25 pm
Starting on a brand new install of Raspbian from NOOBS 1_3_2
sudo apt-get install libxt-dev libxpm-dev libxext-dev xutils-dev build-essential
cd /tmp
wget http://dropmix.xs4all.nl/rick/Xsnow/xsnow-1.42.tar.gz
tar -xzvf xsnow-1.42.tar.gz
cd xsnow-1.42
xmkmf
make
sudo make install
This is a doctor free zone.
fergusondavid6
Sun Dec 15, 2013 8:09 am
Many thanks for your help. I followed your instructions, and everything installed fine. However, when I try and run xsnow, no snow appears. I am running it in a LXTerminal with the GUI.
Do you know what is wrong?
Sun Dec 15, 2013 11:24 am
fergusondavid6 wrote:Hi,
Move the mouse click away from the window running xsnow. Press Ctrl+C.
fergusondavid6
Sun Dec 15, 2013 12:30 pm
Hi again,
I did what you said, and it worked, but only for about 2-3 seconds. After that, it quit.
I have made a video showing the issue:
http://youtu.be/3XPCVwC4ZoA
Is there any way to fix this?
Sun Dec 15, 2013 8:59 pm
I'd guess the way to fix it is to re-write the code so that it doesn't react to stray keyboard or mouse movements and runs longer before it dies.
If you change line 209 (in xsnow.c) to
#define debug 1
and recompile then it will spew out lots of diagnostic messages (which might help find why it fails).
fergusondavid6
Sun Dec 15, 2013 9:58 pm
After a bit of experimenting, I found that if you hit CTRL-C on the desktop, without xsnow running, then all the icons dissapear, the after the same amount of time that xsnow runs for, reappear again.
Could the issue be that xsnow only runs while the icons have gone, and is there a way to make them disappear for longer?
Thanks for your help.
jojopi
Sun Dec 15, 2013 10:01 pm
It does not fail. It draws perfectly happily into the root window. You just cannot see the root window most of the time because your GUI overlays its own pointless window.
To fix it "killall pcmanfm", and avoid restarting the GUI file manager.
fergusondavid6
Mon Dec 16, 2013 6:56 am
Many thanks for all your help. It now works perfectly.
RottenRonnie
Fri Dec 02, 2016 8:59 pm
Just a note to say that the instructions provided work under Raspbian Jessie.
Thanks!
wvermin
Tue Jun 04, 2019 12:42 pm
Ok, it took some time, but there is now a fully functional xsnow for raspbian (stretch).
I guess it will run in older raspbian's also.
Check out: https://www.ratrabbit.nl/ratrabbit/cont ... troduction
Return to “Raspbian”
