HerpaMoTeH
Writing a daemon script
Thu Dec 05, 2013 10:25 am
So I have the following problem: I wrote down a daemon script based on the skeleton example in the /etc/init.d directory, but whenever I try to start the script I get a no such file or directory error.
Here's the script which I wrote :
#! /bin/sh
### BEGIN INIT INFO
# Provides:          skeleton
# Required-Start:    $remote_fs $syslog
# Required-Stop:     $remote_fs $syslog
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: Example initscript
# Description:       This file should be used to construct scripts to be
#                    placed in /etc/init.d.
### END INIT INFO
# Author: Ivaylo Ivanov <example@test>
# Do NOT "set -e"
# PATH should only include /usr/* if it runs after the mountnfs.sh script
PATH=/sbin:/usr/sbin:/bin:/usr/bin
DESC="MonoDaemon"
NAME=MonoDaemon
DAEMON=/usr/bin/mono
DAEMON_ARGS=/home/pi/Mono/Vyshka.exe
PIDFILE=/home/pi/pid/MonoDaemon.pid
SCRIPTNAME=/etc/init.d/MonoDaemon
# Load the VERBOSE setting and other rcS variables
. /lib/init/vars.sh
# Define LSB log_* functions.
# Depend on lsb-base (>= 3.2-14) to ensure that this file is present
# and status_of_proc is working.
. /lib/lsb/init-functions
# Function that starts the daemon/service
do_start(){
	# Return
	#   0 if daemon has been started
	#   1 if daemon was already running
	#   2 if daemon could not be started
	#start-stop-daemon --start --quiet --pidfile /home/pi/pid/MonoDaemon.pid --exec /usr/bin/mono --test > /dev/null || return 1
	start-stop-daemon --start --background -m --oknodo --pidfile /home/pi/pid/MonoDaemon.pid --exec /usr/bin/mono -- /home/pi/Mono/Vyshka.exe || return 2
	# Add code here, if necessary, that waits for the process to be ready
	# to handle requests from services started subsequently which depend
	# on this one.  As a last resort, sleep for some time.
# Function that stops the daemon/service
do_stop(){
	# Return
	#   0 if daemon has been stopped
	#   1 if daemon was already stopped
	#   2 if daemon could not be stopped
	#   other if a failure occurred
	start-stop-daemon --stop --retry=TERM/30/KILL/5 --pidfile /home/pi/pid/MonoDaemon.pid --name MonoDaemon
	RETVAL="$?"
	[ "${RETVAL}" = 2 ] && return 2
	# Wait for children to finish too if this is a daemon that forks
	# and if the daemon is only ever run from this initscript.
	# If the above conditions are not satisfied then add some other code
	# that waits for the process to drop all resources that could be
	# needed by services started subsequently.  A last resort is to
	# sleep for some time.
	start-stop-daemon --stop --oknodo --retry=0/30/KILL/5 --exec /usr/bin/mono
	[ "$?" = 2 ] && return 2
	# Many daemons don't delete their pidfiles when they exit.
	rm -f /home/pi/pid/MonoDaemon.pid
	return "${RETVAL}"
# Function that sends a SIGHUP to the daemon/service
do_reload() {
	# If the daemon can reload its configuration without
	# restarting (for example, when it is sent a SIGHUP),
	# then implement that here.
	start-stop-daemon --stop --signal 1 --pidfile /home/pi/pid/MonoDaemon.pid --name MonoDaemon
	return 0
case "$1" in
  start)
	[ "${VERBOSE}" != no ] && log_daemon_msg "Starting MonoDaemon" "MonoDaemon"
	do_start
	case "$?" in
		0|1) [ "${VERBOSE}" != no ] && log_end_msg 0 ;;
		2) [ "${VERBOSE}" != no ] && log_end_msg 1 ;;
	esac
  stop)
	[ "${VERBOSE}" != no ] && log_daemon_msg "Stopping MonoDaemon" "MonoDaemon"
	do_stop
	case "$?" in
	esac
  status)
       status_of_proc "/usr/bin/mono" "MonoDaemon" && exit 0 || exit $?
  #reload|force-reload)
	# If do_reload() is not implemented then leave this commented out
	# and leave 'force-reload' as an alias for 'restart'.
	#log_daemon_msg "Reloading MonoDaemon" "MonoDaemon"
	#do_reload
	#log_end_msg $?
  restart|force-reload)
	# If the "reload" option is implemented then remove the
	# 'force-reload' alias
	log_daemon_msg "Restarting MonoDaemon" "MonoDaemon"
	do_stop
	case "$?" in
	  0|1)
		do_start
		case "$?" in
			0) log_end_msg 0 ;;
			1) log_end_msg 1 ;; # Old process is still running
			*) log_end_msg 1 ;; # Failed to start
		esac
	  	# Failed to stop
		log_end_msg 1
	esac
	#echo "Usage: /etc/init.d/MonoDaemon {start|stop|restart|reload|force-reload}" >&2
	echo "Usage: /etc/init.d/MonoDaemon {start|stop|status|restart|force-reload}" >&2
	exit 3
esac
I added the script as a service through the update-rc.d command and when I run service --status-all I see the MonoDaemon service, but when I try to start it I get this error:
pi@raspberrypi /etc/init.d $ sudo service MonoDaemon start
env: /etc/init.d/MonoDaemon: No such file or directory
Any help is going to be appreciated :)
forenbenutzer
Re: Writing a daemon script
Thu Dec 05, 2013 1:08 pm
chmod a+x /etc/init.d/MonoDaemon
did you?
Pitendo - Case And Emulator Project - http://edv-huber.com/index.php/problemloesungen/12-pitendo
HerpaMoTeH
Thu Dec 05, 2013 1:46 pm
Same error :(
pi@raspberrypi /etc/init.d $ sudo chmod a+x MonoDaemon
WebPi
Thu Dec 05, 2013 4:51 pm
What happens if you start it like this:
sudo /etc/init.d/MoonoDaemon start
raspberrywebserver.com - Raspberry Pi tutorials
LinuxWebServers.net - Linux Web Server tutorials and examples
pyplate.com - Python web publishing tool
Thu Dec 05, 2013 4:57 pm
Try running it like this:
sudo sh -x /etc/init.d/MoonoDaemon start
The -x flag should produce more lines of tracing output than you need.
HerpaMoTeH
Fri Dec 06, 2013 9:13 am
Here's the output after I removed all of the empty lines from the script, because it showed some error on them:
pi@raspberrypi /etc/init.d $ ls
alsa-utils              hostname.sh            mtab.sh          rsync
apache2                 hwclock.sh             mysql            rsyslog
binfmt-support          ifplugd                networking       sendsigs
bluetooth               kbd                    network-manager  single
bootlogs                keyboard-setup         nfs-common       skeleton
bootmisc.sh             killprocs              ntp              ssh
checkfs.sh              kmod                   pppd-dns         sudo
checkroot-bootclean.sh  lightdm                procps           triggerhappy
checkroot.sh            MonoDaemon             pulseaudio       udev
console-setup           motd                   rc               udev-mtab
cron                    mountall-bootclean.sh  rc.local         umountfs
dbus                    mountall.sh            rcS              umountnfs.sh
dphys-swapfile          mountdevsubfs.sh       README           umountroot
fake-hwclock            mountkernfs.sh         reboot           urandom
halt                    mountnfs-bootclean.sh  rmnologin        vsftpd
hdparm                  mountnfs.sh            rpcbind          x11-common
pi@raspberrypi /etc/init.d $ sudo sh -x /etc/init.d/MonoDaemon start
+ PATH=/sbin:/usr/sbin:/bin:/usr/bin
+ DESC=MonoDaemon
+ NAME=MonoDaemon
+ DAEMON=/usr/bin/mono
+ DAEMON_ARGS=/home/pi/Mono/Vyshka.exe
+ PIDFILE=/home/pi/pid/MonoDaemon.pid
+ SCRIPTNAME=/etc/init.d/MonoDaemon
+ . /lib/init/vars.sh
/etc/init.d/MonoDaemon: 23: .: Can't open /lib/init/vars.sh
pi@raspberrypi /etc/init.d $ cd /lib/init/
pi@raspberrypi /lib/init $ ls
bootclean.sh  mount-functions.sh  swap-functions.sh  tmpfs.sh  vars.sh
WebPi
Fri Dec 06, 2013 10:26 am
Did you copy any code off a web page? The errors on empty lines makes me wonder if there are some invisible unicode characters causing problems for bash.
HerpaMoTeH
Fri Dec 06, 2013 11:31 am
No, I copied the code from the skeleton script which is a init.d example script.
Fri Dec 06, 2013 3:27 pm
HerpaMoTeH wrote:Here's the output after I removed all of the empty lines from the script, because it showed some error on them:
Your pi user doesn't have the right permissions for that file.
sudo chmod 755 /lib/init/vars.sh
should fix it.
HerpaMoTeH
Fri Dec 06, 2013 3:29 pm
should fix it.
Same error :(
Output:
pi@raspberrypi /lib/init $ sudo chmod 755 /lib/init/vars.sh
pi@raspberrypi /lib/init $ sudo sh -x /etc/init.d/MonoDaemon start
+ DESC=MonoDaemon
+ NAME=MonoDaemon
benjaoming
Tue Sep 20, 2016 5:13 pm
[deleted]
Douglas6
Tue Sep 20, 2016 5:37 pm
Since the previous post is almost three years old, long before systemd hit Raspbian, I'm pretty sure that's not right.
Return to “Raspberry Pi OS”
