Tonight I thought I'd see if any packages needed an update so ran my usual
apt-get update && apt-get dist-upgrade # which is normal practice on a brand new distro
That fails with
root@pi ~ # apt-get update && apt-get dist-upgrade
Ign http://archive.raspberrypi.org jessie InRelease
Hit http://mirrordirector.raspbian.org jessie InRelease
Ign http://archive.raspberrypi.org jessie Release.gpg
Hit http://dist.quick2wire.com wheezy InRelease
Hit http://mirrordirector.raspbian.org jessie/main armhf Packages
Hit http://mirrordirector.raspbian.org jessie/contrib armhf Packages
Hit http://mirrordirector.raspbian.org jessie/non-free armhf Packages
Hit http://dist.quick2wire.com wheezy/main Sources
Hit http://mirrordirector.raspbian.org jessie/rpi armhf Packages
Hit http://repository.wolfram.com stable InRelease
Hit http://dist.quick2wire.com wheezy/main armhf Packages
Hit http://repository.wolfram.com stable/non-free armhf Packages
Err http://archive.raspberrypi.org jessie/main armhf Packages
404 Not Found [IP: 2a00:1098:0:82:1000:13:0:6 80]
Ign http://archive.raspberrypi.org jessie/main Translation-en_GB
Ign http://repository.wolfram.com stable/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/main Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en_GB
Ign http://dist.quick2wire.com wheezy/main Translation-en_GB
W: Failed to fetch http://archive.raspberrypi.org/debian/dists/jessie/main/binary-armhf/Packages 404 Not Found [IP: 2a00:1098:0:82:1000:13:0:6 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
root@pi ~ #
root@pi ~/ipv6 # apt-get update && apt-get dist-upgrade
404 Not Found [IP: 93.93.130.214 80]
W: Failed to fetch http://archive.raspberrypi.org/debian/dists/jessie/main/binary-armhf/Packages 404 Not Found [IP: 93.93.130.214 80]
root@pi ~/ipv6 #
