I've searched online about how to fix a broken Apt-Get install. I've tried -f, I've tried Aptitude, I've tried Auto Clean, Auto Remove. I even tried editing the installation scripts.
Here is a raw dump outlining the problem:
pi@raspberrypi ~ $ sudo apt-get -f install Reading package lists... Done Building dependency tree Reading state information... Done Correcting dependencies... failed. The following packages have unmet dependencies: E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages. E: Unable to correct dependencies pi@raspberrypi ~ $ sudo apt-get install emacsReading package lists... Done Building dependency tree Reading state information... Done emacs is already the newest version. You might want to run 'apt-get -f install' to correct these: The following packages have unmet dependencies: emacs23-bin-common : Depends: emacs23-common (= 23.4+1-4) but it is not going to be installed E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution). pi@raspberrypi ~ $ sudo apt-get install emacs23-common Reading package lists... Done Building dependency tree Reading state information... Done Suggested packages: emacs23-el emacs23-common-non-dfsg The following packages will be upgraded: emacs23-common 1 upgraded, 0 newly installed, 0 to remove and 17 not upgraded. 4 not fully installed or removed. Need to get 0 B/18.6 MB of archives. After this operation, 59.6 MB of additional disk space will be used. (Reading database ... 75187 files and directories currently installed.) Preparing to replace emacs23-common 23.4+1-4 (using .../emacs23-common_23.4+1-4_all.deb) ... Unpacking replacement emacs23-common ... dpkg: error processing /var/cache/apt/archives/emacs23-common_23.4+1-4_all.deb (--unpack): unable to create `/usr/share/emacs/23.4/etc/images/smilies/grayscale/README.dpkg-new' (while processing `./usr/share/emacs/23.4/etc/images/smilies/grayscale/README'): Input/output error dpkg-deb: error: subprocess paste was killed by signal (Broken pipe) Processing triggers for install-info ... Processing triggers for desktop-file-utils ... Processing triggers for hicolor-icon-theme ... Errors were encountered while processing: /var/cache/apt/archives/emacs23-common_23.4+1-4_all.deb E: Sub-process /usr/bin/dpkg returned an error code (1) pi@raspberrypi ~ $I looked under var/lib/dpkg/info and I'll be damned if I can find emacs23-common to try and comment out the images (I assume it'll work by doing that).
emacs23-bin-common.list emacs23.list emacs23.prerm emacsen-common.postinst emacs.listemacs23-bin-common.md5sums emacs23.md5sums emacsen-common.conffiles emacsen-common.postrm emacs.md5sumsemacs23-bin-common.postinst emacs23.postinst emacsen-common.list emacsen-common.preinstemacs23-bin-common.prerm emacs23.postrm emacsen-common.md5sums emacsen-common.prerm
