plugwash
Re: Compile VLC with HW acceleration - complete tutorial
Sun Jul 20, 2014 12:31 am
Because so-far noone has done the work of seperating out the pi specific components into a seperate source package so that the generic vlc can remain in the main section of the repository and the hardware acceleration components can go in the rpi section of the repository.
gkreidl
Sun Jul 20, 2014 6:41 am
plugwash wrote:Because so-far noone has done the work of seperating out the pi specific components into a seperate source package so that the generic vlc can remain in the main section of the repository and the hardware acceleration components can go in the rpi section of the repository.
No, I believe, that wouldn't work. The release ín Debian Wheezy is too old. You cannot compile it to include the OpenMax RPi component.
And for the current version of VLC, some dependencies are not met.
The only solution would be some kind of backport repository, that contains a complete version from about last October (that has to be checked in detail), compiled with the flags set for RPi.
In Jessie it's different. VLC has just to be compiled with certain flags set (enable plugins that are not enabled by default, see my first post),
But I don't know any details about compiling a Debian release.
Minimal Kiosk Browser (kweb)
Micha1982
Fri Aug 22, 2014 3:51 am
gkreidl wrote:configure returns an error, because the current VLC version requires newer versions of libavcodec and libavutil.
The version I compiled was from (about) 20th October; the versions of libavcodec and libavutil required match the versions we have in Raspbian. You either have to compile newer versions or get an older version of vlc from vlc github.
Same problem here, can you tell us how to, please?
Whats the better choice and why? And how to compile newer versions of libavcodec and util exactly? Installing through apt-get install isn't possible...
At configure I also get following warnings
configure: WARNING: No package 'lua5.2' found, trying lua 5.1 instead
checking for LUA... yes
configure: WARNING: No package 'live555' found.
configure: WARNING: Library libraw1394 >= 2.0.1 libavc1394 >= 0.5.3 needed for dv1394 was not found
configure: WARNING: Library dvdread > 4.9.0 needed for dvdread was not found
checking for DVDNAV... no
configure: WARNING: Library dvdnav > 4.9.0 needed for dvdnav was not found
checking for BLURAY... no
configure: WARNING: Library libbluray >= 0.3.0 needed for bluray was not found
checking for OPENCV... yes
checking for SMBCLIENT... no
configure: WARNING: Library smbclient needed for smbclient was not found
checking for DSM... no
configure: WARNING: Library libdsm needed for dsm was not found
checking for SFTP... yes
configure: WARNING: Blackmagic DeckLink SDI include files not found
checking for GNOMEVFS... no
configure: WARNING: Library gnome-vfs-2.0 needed for gnomevfs was not found
configure: WARNING: Library libvncclient >= 0.9.9 needed for vnc was not found
configure: WARNING: Library shine >= 3.0.0 needed for shine was not found
configure: WARNING: No package 'gstreamer-app-1.0' found. GStreamer modules will not be built.
checking for AVCODEC... no
configure: error: Requested 'libavcodec >= 54.25.0' but version of libavcodec is 53.35.0
Requested 'libavutil >= 52.0.0' but version of libavutil is 51.22.2. Pass --disable-avcodec to ignore this error.
which I can't manage to go away through apt-get install
Another idea I had was to use the ready compiled version - but how to? How to handle all that files if extracted that .rar? Do I need to 'make install'? If I do I got following output:
Makefile:1148: libvlc/.deps/core.Po: Datei oder Verzeichnis nicht gefunden
Makefile:1149: libvlc/.deps/equalizer.Po: Datei oder Verzeichnis nicht gefunden
Makefile:1150: libvlc/.deps/media.Po: Datei oder Verzeichnis nicht gefunden
Makefile:1151: libvlc/.deps/media_list.Po: Datei oder Verzeichnis nicht gefunden
Makefile:1152: libvlc/.deps/media_list_player.Po: Datei oder Verzeichnis nicht gefunden
Makefile:1153: libvlc/.deps/media_player.Po: Datei oder Verzeichnis nicht gefunden
Makefile:1154: libvlc/.deps/meta.Po: Datei oder Verzeichnis nicht gefunden
Makefile:1155: src/config/.deps/chain.Po: Datei oder Verzeichnis nicht gefunden
Makefile:1156: src/misc/.deps/variables.Po: Datei oder Verzeichnis nicht gefunden
make: *** Keine Regel, um »src/misc/.deps/variables.Po« zu erstellen.  Schluss.
How can I get it to work, please? What to mention in further updates? Do I need to compile vlc from scratch if any library or something other is updated later automatically through 'update/upgrade' etc.? Many thanks!
Alles, was schiefgehen kann, wird auch schiefgehen.
gkreidl
Fri Aug 22, 2014 8:12 am
Compiling newer versions of some packages and replacing the older ones may always break other applications and is not compatible with apg-get update/upgrade. And you may run into a series of problems, as the newer versions may themselves need newer versions of other packages. I once tried to compile an up to date libwebkit-gtk version and gave up after discovering that I had to replace large parts of the current (Debian Wheezy) linux packages (that's also the problem with the experimental web = Epiphany browser). I don't recommend this.
This leaves the following options:
1) Upgrade to Jessie (testing). Then you will have all the newer package versions installed. But you may run into other problems, of course (testing, not stable). But then you should be able to compile the bleeding edge VLC version.
2) Get an older version from the repository (end of October 2013). This will work and doesn't need the newer packages. You can also get an archive from me that already contains the versions that works on Wheezy (but you still have to run through the configure and compile process). PM me, if you are interested.
Micha1982
Fri Aug 22, 2014 8:29 pm
To get that working version from you would be great - not only for me, for others, too....much more great would it be, if someone put that player into the repo/take care that it will be implemented in further firmware as a standart!
Furthermore, if you upload it anywhere, pls tell us how to handle it/where exactly to copy/extract and how to compile (if it differs from tutorial in any way)
spycrab101
Tue Aug 26, 2014 5:25 pm
Hi. I'll upload a copy on my vps For everyone. I can't pm you unfortunately.
gkreidl
Tue Aug 26, 2014 9:38 pm
Anybody can send a PM here. But some people never look into there inbox.
Joe Schmoe
Tue Aug 26, 2014 9:48 pm
gkreidl wrote:Anybody can send a PM here. But some people never look into there inbox.
I think that's the jist of it. It's very confusing that things stick in "Outbox" until the recipient reads it.
I got caught on this myself - in fact, I think I still have something in my "Outbox" because the idiot that I sent it to quit the board (after making just one post, I think).
So, I think people do, as I did, get the impression that the system either isn't working or is blocked to them (for some unspecified crime) when they see stuff sitting in Outbox.
Micha1982
Sat Sep 13, 2014 12:42 am
Ok, I still was not able to get it working.
Can someone tell me pls whats going on here -
or how to get a working hardware-accelerated vlc-player (which works for others already since months) without investing hours of (frustrating) experimenting and loss of hours of lifetime? :(
input/clock.c:531:2: warning: #warning "input_clock_SetJitter needs more work" [-Wcpp]
  CC     input/control.lo
In file included from input/control.c:37:0:
input/es_out.h: In function 'es_out_SetMode':
input/es_out.h:89:9: warning: unused variable 'i_ret' [-Wunused-variable]
input/es_out.h: In function 'es_out_GetWakeup':
input/es_out.h:95:9: warning: unused variable 'i_ret' [-Wunused-variable]
input/es_out.h: In function 'es_out_GetBuffering':
input/es_out.h:103:9: warning: unused variable 'i_ret' [-Wunused-variable]
input/es_out.h: In function 'es_out_GetEmpty':
input/es_out.h:111:9: warning: unused variable 'i_ret' [-Wunused-variable]
input/es_out.h: In function 'es_out_SetDelay':
input/es_out.h:118:9: warning: unused variable 'i_ret' [-Wunused-variable]
input/es_out.h: In function 'es_out_SetTimes':
input/es_out.h:143:9: warning: unused variable 'i_ret' [-Wunused-variable]
input/es_out.h: In function 'es_out_SetJitter':
input/es_out.h:149:9: warning: unused variable 'i_ret' [-Wunused-variable]
input/es_out.h: In function 'es_out_GetGroupForced':
input/es_out.h:161:9: warning: unused variable 'i_ret' [-Wunused-variable]
input/es_out.h: In function 'es_out_Eos':
input/es_out.h:167:9: warning: unused variable 'i_ret' [-Wunused-variable]
  CC     input/decoder.lo
input/decoder.c: In function 'spu_new_buffer':
input/decoder.c:2456:9: warning: call to 'harmful_delay' declared with attribute warning: use proper event handling instead of short delay [enabled by default]
input/decoder.c: In function 'vout_new_buffer':
input/decoder.c:2420:9: warning: call to 'harmful_delay' declared with attribute warning: use proper event handling instead of short delay [enabled by default]
  CC     input/decoder_synchro.lo
  CC     input/demux.lo
  CC     input/es_out.lo
In file included from input/es_out.c:45:0:
input/es_out.c: In function 'EsOutSelect':
input/es_out.c:1815:27: warning: passing argument 2 of 'LanguageArrayIndex' discards 'const' qualifier from pointer target type [enabled by default]
input/es_out.c:196:12: note: expected 'char *' but argument is of type 'const char *'
input/es_out.c: In function 'EsOutDel':
input/es_out.c:2034:9: warning: 'vlc_object_alive' is deprecated (declared at ../include/vlc_objects.h:76) [-Wdeprecated-declarations]
input/es_out.c: In function 'EsOutControlLocked':
input/es_out.c:2557:20: warning: unused variable 'b_source_paused' [-Wunused-variable]
input/es_out.c:2569:19: warning: unused variable 'i_src_rate' [-Wunused-variable]
input/es_out.c:2580:23: warning: unused variable 'i_date' [-Wunused-variable]
input/es_out.c:2041:13: warning: call to 'harmful_delay.constprop.3' declared with attribute warning: use proper event handling instead of short delay [enabled by default]
  CC     input/es_out_timeshift.lo
In file included from input/es_out_timeshift.c:51:0:
input/es_out_timeshift.c: In function 'TsChangePause':
input/es_out_timeshift.c:887:51: warning: unused parameter 'b_source_paused' [-Wunused-parameter]
  CC     input/event.lo
  CC     input/input.lo
In file included from input/input.c:41:0:
input/input.c: In function 'MainLoop':
input/input.c:698:5: warning: 'vlc_object_alive' is deprecated (declared at ../include/vlc_objects.h:76) [-Wdeprecated-declarations]
input/input.c: In function 'ControlPop':
input/input.c:1503:9: warning: 'vlc_object_alive' is deprecated (declared at ../include/vlc_objects.h:76) [-Wdeprecated-declarations]
input/input.c: In function 'InputSourceInit':
input/input.c:2309:13: warning: 'vlc_object_alive' is deprecated (declared at ../include/vlc_objects.h:76) [-Wdeprecated-declarations]
input/input.c:2425:13: warning: 'vlc_object_alive' is deprecated (declared at ../include/vlc_objects.h:76) [-Wdeprecated-declarations]
  CC     input/meta.lo
  CC     input/resource.lo
  CC     input/stats.lo
  CC     input/stream.lo
input/stream.c: In function 'AStreamPrebufferBlock':
input/stream.c:661:9: warning: 'vlc_object_alive' is deprecated (declared at ../include/vlc_objects.h:76) [-Wdeprecated-declarations]
input/stream.c: In function 'AStreamRefillBlock':
input/stream.c:999:9: warning: 'vlc_object_alive' is deprecated (declared at ../include/vlc_objects.h:76) [-Wdeprecated-declarations]
input/stream.c: In function 'AStreamRefillStream':
input/stream.c:1355:9: warning: 'vlc_object_alive' is deprecated (declared at ../include/vlc_objects.h:76) [-Wdeprecated-declarations]
input/stream.c: In function 'AStreamPrebufferStream':
input/stream.c:1416:9: warning: 'vlc_object_alive' is deprecated (declared at ../include/vlc_objects.h:76) [-Wdeprecated-declarations]
  CC     input/stream_demux.lo
  CC     input/stream_filter.lo
  CC     input/stream_memory.lo
  CC     input/subtitles.lo
  CC     input/var.lo
  CC     video_output/control.lo
  CC     video_output/display.lo
In file included from video_output/display.c:43:0:
video_output/event.h: In function 'vout_SendEventClose':
video_output/event.h:42:2: warning: #warning FIXME: implement video close event [-Wcpp]
video_output/display.c: In function 'VideoBufferNew':
video_output/display.c:57:27: warning: unused variable 'fmt' [-Wunused-variable]
video_output/display.c: In function 'SplitterPrepare':
video_output/display.c:1437:43: warning: unused parameter 'subpicture' [-Wunused-parameter]
video_output/display.c: In function 'SplitterDisplay':
video_output/display.c:1460:43: warning: unused parameter 'subpicture' [-Wunused-parameter]
  CC     video_output/inhibit.lo
Micha1982
i@raspberrypi ~/vlc $ sudo make install
make  install-recursive
make[1]: Entering directory `/home/pi/vlc'
Making install in compat
make[2]: Entering directory `/home/pi/vlc/compat'
make  install-am
make[3]: Entering directory `/home/pi/vlc/compat'
make[4]: Entering directory `/home/pi/vlc/compat'
 /bin/mkdir -p '/usr/lib/vlc'
 ../doltlibtool   --mode=install /usr/bin/install -c   libcompat.la '/usr/lib/vlc'
libtool: install: /usr/bin/install -c .libs/libcompat.lai /usr/lib/vlc/libcompat.la
libtool: install: /usr/bin/install -c .libs/libcompat.a /usr/lib/vlc/libcompat.a
libtool: install: chmod 644 /usr/lib/vlc/libcompat.a
libtool: install: ranlib /usr/lib/vlc/libcompat.a
libtool: finish: PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/sbin" ldconfig -n /usr/lib/vlc
Libraries have been installed in:
   /usr/lib/vlc
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
   - add LIBDIR to the `LD_LIBRARY_PATH' environment variable
     during execution
   - add LIBDIR to the `LD_RUN_PATH' environment variable
     during linking
   - use the `-Wl,-rpath -Wl,LIBDIR' linker flag
   - have your system administrator add LIBDIR to `/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
make[4]: Für das Ziel »install-data-am« ist nichts zu tun.
make[4]: Leaving directory `/home/pi/vlc/compat'
make[3]: Leaving directory `/home/pi/vlc/compat'
make[2]: Leaving directory `/home/pi/vlc/compat'
Making install in doc
make[2]: Entering directory `/home/pi/vlc/doc'
make[3]: Entering directory `/home/pi/vlc/doc'
make[3]: Für das Ziel »install-exec-am« ist nichts zu tun.
 /bin/mkdir -p '/usr/share/doc/vlc'
 /usr/bin/install -c -m 644 bugreport-howto.txt fortunes.txt intf-vcd.txt '/usr/share/doc/vlc'
 /bin/mkdir -p '/usr/share/man/man1'
 /usr/bin/install -c -m 644 vlc.1 vlc-wrapper.1 '/usr/share/man/man1'
 /bin/mkdir -p '/usr/share/doc/vlc/libvlc/QtPlayer'
 /usr/bin/install -c -m 644  libvlc/QtPlayer/LICENSE libvlc/QtPlayer/main.cpp libvlc/QtPlayer/player.cpp libvlc/QtPlayer/player.h libvlc/QtPlayer/QtVLC.pro '/usr/share/doc/vlc/libvlc/QtPlayer'
 /bin/mkdir -p '/usr/share/doc/vlc/libvlc'
 /usr/bin/install -c -m 644  libvlc/gtk_player.c libvlc/libvlc_DVD_ripper.c libvlc/vlc-thumb.c libvlc/wx_player.cpp '/usr/share/doc/vlc/libvlc'
make[3]: Leaving directory `/home/pi/vlc/doc'
make[2]: Leaving directory `/home/pi/vlc/doc'
Making install in po
make[2]: Entering directory `/home/pi/vlc/po'
installing ach.gmo as /usr/share/locale/ach/LC_MESSAGES/vlc.mo
installing af.gmo as /usr/share/locale/af/LC_MESSAGES/vlc.mo
installing am.gmo as /usr/share/locale/am/LC_MESSAGES/vlc.mo
installing an.gmo as /usr/share/locale/an/LC_MESSAGES/vlc.mo
installing ar.gmo as /usr/share/locale/ar/LC_MESSAGES/vlc.mo
installing ast.gmo as /usr/share/locale/ast/LC_MESSAGES/vlc.mo
installing az.gmo as /usr/share/locale/az/LC_MESSAGES/vlc.mo
installing be.gmo as /usr/share/locale/be/LC_MESSAGES/vlc.mo
installing bg.gmo as /usr/share/locale/bg/LC_MESSAGES/vlc.mo
installing bn_IN.gmo as /usr/share/locale/bn_IN/LC_MESSAGES/vlc.mo
installing bn.gmo as /usr/share/locale/bn/LC_MESSAGES/vlc.mo
installing br.gmo as /usr/share/locale/br/LC_MESSAGES/vlc.mo
installing bs.gmo as /usr/share/locale/bs/LC_MESSAGES/vlc.mo
installing ca.gmo as /usr/share/locale/ca/LC_MESSAGES/vlc.mo
installing cgg.gmo as /usr/share/locale/cgg/LC_MESSAGES/vlc.mo
installing ckb.gmo as /usr/share/locale/ckb/LC_MESSAGES/vlc.mo
installing co.gmo as /usr/share/locale/co/LC_MESSAGES/vlc.mo
installing cs.gmo as /usr/share/locale/cs/LC_MESSAGES/vlc.mo
installing cy.gmo as /usr/share/locale/cy/LC_MESSAGES/vlc.mo
installing da.gmo as /usr/share/locale/da/LC_MESSAGES/vlc.mo
installing de.gmo as /usr/share/locale/de/LC_MESSAGES/vlc.mo
installing el.gmo as /usr/share/locale/el/LC_MESSAGES/vlc.mo
installing en_GB.gmo as /usr/share/locale/en_GB/LC_MESSAGES/vlc.mo
installing es.gmo as /usr/share/locale/es/LC_MESSAGES/vlc.mo
installing et.gmo as /usr/share/locale/et/LC_MESSAGES/vlc.mo
installing eu.gmo as /usr/share/locale/eu/LC_MESSAGES/vlc.mo
installing fa.gmo as /usr/share/locale/fa/LC_MESSAGES/vlc.mo
installing ff.gmo as /usr/share/locale/ff/LC_MESSAGES/vlc.mo
installing fi.gmo as /usr/share/locale/fi/LC_MESSAGES/vlc.mo
installing fr.gmo as /usr/share/locale/fr/LC_MESSAGES/vlc.mo
installing fur.gmo as /usr/share/locale/fur/LC_MESSAGES/vlc.mo
installing ga.gmo as /usr/share/locale/ga/LC_MESSAGES/vlc.mo
installing gd.gmo as /usr/share/locale/gd/LC_MESSAGES/vlc.mo
installing gl.gmo as /usr/share/locale/gl/LC_MESSAGES/vlc.mo
installing gu.gmo as /usr/share/locale/gu/LC_MESSAGES/vlc.mo
installing he.gmo as /usr/share/locale/he/LC_MESSAGES/vlc.mo
installing hi.gmo as /usr/share/locale/hi/LC_MESSAGES/vlc.mo
installing hr.gmo as /usr/share/locale/hr/LC_MESSAGES/vlc.mo
installing hu.gmo as /usr/share/locale/hu/LC_MESSAGES/vlc.mo
installing hy.gmo as /usr/share/locale/hy/LC_MESSAGES/vlc.mo
installing ia.gmo as /usr/share/locale/ia/LC_MESSAGES/vlc.mo
installing id.gmo as /usr/share/locale/id/LC_MESSAGES/vlc.mo
installing is.gmo as /usr/share/locale/is/LC_MESSAGES/vlc.mo
installing it.gmo as /usr/share/locale/it/LC_MESSAGES/vlc.mo
installing ja.gmo as /usr/share/locale/ja/LC_MESSAGES/vlc.mo
installing ka.gmo as /usr/share/locale/ka/LC_MESSAGES/vlc.mo
installing kk.gmo as /usr/share/locale/kk/LC_MESSAGES/vlc.mo
installing km.gmo as /usr/share/locale/km/LC_MESSAGES/vlc.mo
installing kn.gmo as /usr/share/locale/kn/LC_MESSAGES/vlc.mo
installing ko.gmo as /usr/share/locale/ko/LC_MESSAGES/vlc.mo
installing ky.gmo as /usr/share/locale/ky/LC_MESSAGES/vlc.mo
installing lg.gmo as /usr/share/locale/lg/LC_MESSAGES/vlc.mo
installing lt.gmo as /usr/share/locale/lt/LC_MESSAGES/vlc.mo
installing lv.gmo as /usr/share/locale/lv/LC_MESSAGES/vlc.mo
installing mk.gmo as /usr/share/locale/mk/LC_MESSAGES/vlc.mo
installing ml.gmo as /usr/share/locale/ml/LC_MESSAGES/vlc.mo
installing mn.gmo as /usr/share/locale/mn/LC_MESSAGES/vlc.mo
installing mr.gmo as /usr/share/locale/mr/LC_MESSAGES/vlc.mo
installing ms.gmo as /usr/share/locale/ms/LC_MESSAGES/vlc.mo
installing my.gmo as /usr/share/locale/my/LC_MESSAGES/vlc.mo
installing nb.gmo as /usr/share/locale/nb/LC_MESSAGES/vlc.mo
installing ne.gmo as /usr/share/locale/ne/LC_MESSAGES/vlc.mo
installing nl.gmo as /usr/share/locale/nl/LC_MESSAGES/vlc.mo
installing nn.gmo as /usr/share/locale/nn/LC_MESSAGES/vlc.mo
installing oc.gmo as /usr/share/locale/oc/LC_MESSAGES/vlc.mo
installing or.gmo as /usr/share/locale/or/LC_MESSAGES/vlc.mo
installing pa.gmo as /usr/share/locale/pa/LC_MESSAGES/vlc.mo
installing pl.gmo as /usr/share/locale/pl/LC_MESSAGES/vlc.mo
installing ps.gmo as /usr/share/locale/ps/LC_MESSAGES/vlc.mo
installing pt_BR.gmo as /usr/share/locale/pt_BR/LC_MESSAGES/vlc.mo
installing pt_PT.gmo as /usr/share/locale/pt_PT/LC_MESSAGES/vlc.mo
installing ro.gmo as /usr/share/locale/ro/LC_MESSAGES/vlc.mo
installing ru.gmo as /usr/share/locale/ru/LC_MESSAGES/vlc.mo
installing si.gmo as /usr/share/locale/si/LC_MESSAGES/vlc.mo
installing sk.gmo as /usr/share/locale/sk/LC_MESSAGES/vlc.mo
installing sl.gmo as /usr/share/locale/sl/LC_MESSAGES/vlc.mo
installing sq.gmo as /usr/share/locale/sq/LC_MESSAGES/vlc.mo
installing sr.gmo as /usr/share/locale/sr/LC_MESSAGES/vlc.mo
installing sv.gmo as /usr/share/locale/sv/LC_MESSAGES/vlc.mo
installing ta.gmo as /usr/share/locale/ta/LC_MESSAGES/vlc.mo
installing te.gmo as /usr/share/locale/te/LC_MESSAGES/vlc.mo
installing tet.gmo as /usr/share/locale/tet/LC_MESSAGES/vlc.mo
installing th.gmo as /usr/share/locale/th/LC_MESSAGES/vlc.mo
installing tl.gmo as /usr/share/locale/tl/LC_MESSAGES/vlc.mo
installing tr.gmo as /usr/share/locale/tr/LC_MESSAGES/vlc.mo
installing uk.gmo as /usr/share/locale/uk/LC_MESSAGES/vlc.mo
installing uz.gmo as /usr/share/locale/uz/LC_MESSAGES/vlc.mo
installing vi.gmo as /usr/share/locale/vi/LC_MESSAGES/vlc.mo
installing wa.gmo as /usr/share/locale/wa/LC_MESSAGES/vlc.mo
installing zh_CN.gmo as /usr/share/locale/zh_CN/LC_MESSAGES/vlc.mo
installing zh_TW.gmo as /usr/share/locale/zh_TW/LC_MESSAGES/vlc.mo
installing zu.gmo as /usr/share/locale/zu/LC_MESSAGES/vlc.mo
if test "vlc" = "gettext-tools"; then \
     /bin/mkdir -p /usr/share/gettext/po; \
     for file in Makefile.in.in remove-potcdate.sin    Makevars.template; do \
       /usr/bin/install -c -m 644 ./$file \
             /usr/share/gettext/po/$file; \
     done; \
     for file in Makevars; do \
       rm -f /usr/share/gettext/po/$file; \
     done; \
   else \
   fi
make[2]: Leaving directory `/home/pi/vlc/po'
Making install in share
make[2]: Entering directory `/home/pi/vlc/share'
make[3]: Entering directory `/home/pi/vlc/share'
 /bin/mkdir -p '/usr/share/applications'
 /usr/bin/install -c -m 644 vlc.desktop '/usr/share/applications'
 /bin/mkdir -p '/usr/share/icons/hicolor/128x128/apps'
 /usr/bin/install -c -m 644 icons/128x128/vlc.png icons/128x128/vlc-xmas.png '/usr/share/icons/hicolor/128x128/apps'
 /bin/mkdir -p '/usr/share/icons/hicolor/16x16/apps'
 /usr/bin/install -c -m 644 icons/16x16/vlc.png icons/16x16/vlc.xpm '/usr/share/icons/hicolor/16x16/apps'
 /bin/mkdir -p '/usr/share/icons/hicolor/256x256/apps'
 /usr/bin/install -c -m 644 icons/256x256/vlc.png '/usr/share/icons/hicolor/256x256/apps'
 /bin/mkdir -p '/usr/share/icons/hicolor/32x32/apps'
 /usr/bin/install -c -m 644 icons/32x32/vlc.png icons/32x32/vlc.xpm icons/32x32/vlc-xmas.xpm '/usr/share/icons/hicolor/32x32/apps'
 /bin/mkdir -p '/usr/share/icons/hicolor/48x48/apps'
 /usr/bin/install -c -m 644 icons/48x48/vlc.png icons/48x48/vlc-xmas.png '/usr/share/icons/hicolor/48x48/apps'
 /bin/mkdir -p '/usr/share/vlc'
 /usr/bin/install -c -m 644 icons/vlc.ico '/usr/share/vlc'
 /bin/mkdir -p '/usr/share/vlc/utils/'
 /usr/bin/install -c utils/gnome-vlc-default.sh utils/audio-vlc-default.sh utils/video-vlc-default.sh '/usr/share/vlc/utils/'
 /bin/mkdir -p '/usr/share/doc/vlc/lua/playlist'
 /usr/bin/install -c -m 644  lua/playlist/README.txt lua/playlist/soundcloud.lua lua/playlist/youtube.lua '/usr/share/doc/vlc/lua/playlist'
 /bin/mkdir -p '/usr/share/doc/vlc/lua/extensions'
 /usr/bin/install -c -m 644  lua/extensions/README.txt '/usr/share/doc/vlc/lua/extensions'
 /bin/mkdir -p '/usr/share/doc/vlc/lua/meta/reader'
 /usr/bin/install -c -m 644  lua/meta/reader/README.txt lua/meta/reader/filename.lua '/usr/share/doc/vlc/lua/meta/reader'
 /bin/mkdir -p '/usr/share/doc/vlc/lua/intf'
 /usr/bin/install -c -m 644  lua/intf/README.txt lua/intf/dumpmeta.lua '/usr/share/doc/vlc/lua/intf'
 /bin/mkdir -p '/usr/share/doc/vlc/lua/meta/fetcher'
 /usr/bin/install -c -m 644  lua/meta/fetcher/README.txt lua/meta/fetcher/tvrage.lua '/usr/share/doc/vlc/lua/meta/fetcher'
 /bin/mkdir -p '/usr/share/doc/vlc/lua'
 /usr/bin/install -c -m 644  lua/README.txt '/usr/share/doc/vlc/lua'
 /bin/mkdir -p '/usr/share/doc/vlc/lua/http/requests'
 /usr/bin/install -c -m 644  lua/http/requests/README.txt '/usr/share/doc/vlc/lua/http/requests'
 /bin/mkdir -p '/usr/share/doc/vlc/lua/sd'
 /usr/bin/install -c -m 644  lua/sd/README.txt lua/sd/icecast.lua '/usr/share/doc/vlc/lua/sd'
 /bin/mkdir -p '/usr/share/doc/vlc/lua/meta/art'
 /usr/bin/install -c -m 644  lua/meta/art/README.txt lua/meta/art/01_googleimage.lua '/usr/share/doc/vlc/lua/meta/art'
 /bin/mkdir -p '/usr/share/vlc/lua/http/dialogs/old'
 /usr/bin/install -c -m 644  lua/http/dialogs/old/browse lua/http/dialogs/old/footer lua/http/dialogs/old/input lua/http/dialogs/old/main lua/http/dialogs/old/playlist lua/http/dialogs/old/sout lua/http/dialogs/old/vlm '/usr/share/vlc/lua/http/dialogs/old'
 /bin/mkdir -p '/usr/share/vlc/lua/http/js'
 /usr/bin/install -c -m 644  lua/http/js/jquery-1.5.1.min.js lua/http/js/ui.js lua/http/js/common.js lua/http/js/jquery.jstree.js lua/http/js/controlers.js lua/http/js/jquery-ui-1.8.13.custom.min.js '/usr/share/vlc/lua/http/js'
 /bin/mkdir -p '/usr/share/vlc/lua/http/old'
 /usr/bin/install -c -m 644  lua/http/old/style.css '/usr/share/vlc/lua/http/old'
 /bin/mkdir -p '/usr/share/vlc/lua/http/css/ui-lightness/images'
 /usr/bin/install -c -m 644  lua/http/css/ui-lightness/images/ui-bg_diagonals-thick_20_666666_40x40.png lua/http/css/ui-lightness/images/ui-bg_flat_10_000000_40x100.png lua/http/css/ui-lightness/images/ui-icons_ffffff_256x240.png lua/http/css/ui-lightness/images/ui-bg_gloss-wave_35_f6a828_500x100.png lua/http/css/ui-lightness/images/ui-bg_glass_65_ffffff_1x400.png lua/http/css/ui-lightness/images/ui-icons_222222_256x240.png lua/http/css/ui-lightness/images/ui-bg_glass_100_f6f6f6_1x400.png lua/http/css/ui-lightness/images/ui-bg_highlight-soft_100_eeeeee_1x100.png lua/http/css/ui-lightness/images/ui-bg_highlight-soft_75_ffe45c_1x100.png lua/http/css/ui-lightness/images/ui-bg_diagonals-thick_18_b81900_40x40.png lua/http/css/ui-lightness/images/ui-icons_ffd27a_256x240.png lua/http/css/ui-lightness/images/ui-icons_228ef1_256x240.png lua/http/css/ui-lightness/images/ui-icons_ef8c08_256x240.png lua/http/css/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png '/usr/share/vlc/lua/http/css/ui-lightness/images'
 /bin/mkdir -p '/usr/share/vlc/skins2/fonts'
 /usr/bin/install -c -m 644  skins2/fonts/FreeSans.ttf skins2/fonts/FreeSansBold.ttf '/usr/share/vlc/skins2/fonts'
 /bin/mkdir -p '/usr/share/vlc/lua/http/dialogs'
 /usr/bin/install -c -m 644  lua/http/dialogs/create_stream.html lua/http/dialogs/equalizer_window.html lua/http/dialogs/mosaic_window.html lua/http/dialogs/batch_window.html lua/http/dialogs/error_window.html lua/http/dialogs/browse_window.html lua/http/dialogs/stream_window.html lua/http/dialogs/offset_window.html lua/http/dialogs/stream_config_window.html '/usr/share/vlc/lua/http/dialogs'
 /bin/mkdir -p '/usr/share/vlc/lua/http/old/images'
 /usr/bin/install -c -m 644  lua/http/old/images/loop.png lua/http/old/images/fullscreen.png lua/http/old/images/prev.png lua/http/old/images/play.png lua/http/old/images/empty.png lua/http/old/images/minus.png lua/http/old/images/slider_right.png lua/http/old/images/slider_point.png lua/http/old/images/pause.png lua/http/old/images/speaker_mute.png lua/http/old/images/delete_small.png lua/http/old/images/snapshot.png lua/http/old/images/info.png lua/http/old/images/refresh.png lua/http/old/images/sout.png lua/http/old/images/sort.png lua/http/old/images/white_cross_small.png lua/http/old/images/shuffle.png lua/http/old/images/repeat.png lua/http/old/images/slow.png lua/http/old/images/slider_left.png lua/http/old/images/help.png lua/http/old/images/stop.png lua/http/old/images/sd.png lua/http/old/images/speaker.png lua/http/old/images/delete.png lua/http/old/images/playlist_small.png lua/http/old/images/eject.png lua/http/old/images/playlist.png lua/http/old/images/volume_up.png lua/http/old/images/next.png lua/http/old/images/volume_down.png lua/http/old/images/slider_bar.png lua/http/old/images/plus.png lua/http/old/images/white.png lua/http/old/images/reset.png '/usr/share/vlc/lua/http/old/images'
 /bin/mkdir -p '/usr/share/vlc/lua/http/images'
 /usr/bin/install -c -m 644  lua/http/images/buttons.png lua/http/images/speaker-32.png lua/http/images/vlc-48.png lua/http/images/Audio-48.png lua/http/images/Folder-48.png lua/http/images/Other-48.png lua/http/images/Back-48.png lua/http/images/Video-48.png lua/http/images/vlc16x16.png '/usr/share/vlc/lua/http/images'
 /bin/mkdir -p '/usr/share/vlc/lua/http/old/js'
 /usr/bin/install -c -m 644  lua/http/old/js/functions.js lua/http/old/js/vlm.js '/usr/share/vlc/lua/http/old/js'
 /bin/mkdir -p '/usr/share/vlc/lua/http/requests'
 /usr/bin/install -c -m 644  lua/http/requests/playlist.xml lua/http/requests/playlist.json lua/http/requests/README.txt lua/http/requests/playlist_jstree.xml lua/http/requests/browse.xml lua/http/requests/browse.json lua/http/requests/vlm_cmd.xml lua/http/requests/status.xml lua/http/requests/status.json lua/http/requests/vlm.xml '/usr/share/vlc/lua/http/requests'
 /bin/mkdir -p '/usr/share/vlc/lua/http/css/ui-lightness'
 /usr/bin/install -c -m 644  lua/http/css/ui-lightness/jquery-ui-1.8.13.custom.css '/usr/share/vlc/lua/http/css/ui-lightness'
 /bin/mkdir -p '/usr/share/vlc/skins2'
 /usr/bin/install -c -m 644  skins2/default.vlt skins2/skin.dtd skins2/skin.catalog skins2/winamp2.xml '/usr/share/vlc/skins2'
 /bin/mkdir -p '/usr/share/vlc/lua/http'
 /usr/bin/install -c -m 644  lua/http/view.html lua/http/mobile.html lua/http/custom.lua lua/http/vlm.html lua/http/mobile_equalizer.html lua/http/vlm_export.html lua/http/mobile_browse.html lua/http/favicon.ico lua/http/mobile_view.html lua/http/index.html '/usr/share/vlc/lua/http'
 /bin/mkdir -p '/usr/share/vlc/lua/http/css'
 /usr/bin/install -c -m 644  lua/http/css/main.css lua/http/css/mobile.css '/usr/share/vlc/lua/http/css'
 /bin/mkdir -p '/usr/lib/vlc/lua/playlist'
 /usr/bin/install -c -m 644  lua/playlist/anevia_streams.luac lua/playlist/anevia_xml.luac lua/playlist/appletrailers.luac lua/playlist/bbc_co_uk.luac lua/playlist/break.luac lua/playlist/canalplus.luac lua/playlist/cue.luac lua/playlist/dailymotion.luac lua/playlist/extreme.luac lua/playlist/france2.luac lua/playlist/googlevideo.luac lua/playlist/jamendo.luac lua/playlist/joox.luac lua/playlist/katsomo.luac lua/playlist/koreus.luac lua/playlist/lelombrik.luac lua/playlist/liveleak.luac lua/playlist/metacafe.luac lua/playlist/metachannels.luac lua/playlist/mpora.luac lua/playlist/pinkbike.luac lua/playlist/pluzz.luac lua/playlist/rockbox_fm_presets.luac lua/playlist/soundcloud.luac lua/playlist/vimeo.luac lua/playlist/youtube.luac lua/playlist/youtube_homepage.luac lua/playlist/zapiks.luac '/usr/lib/vlc/lua/playlist'
 /bin/mkdir -p '/usr/lib/vlc/lua/extensions'
 /usr/bin/install -c -m 644  lua/extensions/VLSub.luac '/usr/lib/vlc/lua/extensions'
 /bin/mkdir -p '/usr/lib/vlc/lua/meta/reader'
 /usr/bin/install -c -m 644  lua/meta/reader/filename.luac '/usr/lib/vlc/lua/meta/reader'
 /bin/mkdir -p '/usr/lib/vlc/lua/modules'
 /usr/bin/install -c -m 644  lua/modules/dkjson.luac lua/modules/sandbox.luac lua/modules/simplexml.luac '/usr/lib/vlc/lua/modules'
 /bin/mkdir -p '/usr/lib/vlc/lua/intf'
 /usr/bin/install -c -m 644  lua/intf/cli.luac lua/intf/dummy.luac lua/intf/dumpmeta.luac lua/intf/luac.luac lua/intf/telnet.luac lua/intf/http.luac '/usr/lib/vlc/lua/intf'
 /bin/mkdir -p '/usr/lib/vlc/lua/meta/fetcher'
 /usr/bin/install -c -m 644  lua/meta/fetcher/tvrage.luac '/usr/lib/vlc/lua/meta/fetcher'
 /bin/mkdir -p '/usr/lib/vlc/lua/sd'
 /usr/bin/install -c -m 644  lua/sd/fmc.luac lua/sd/icecast.luac lua/sd/jamendo.luac lua/sd/metachannels.luac '/usr/lib/vlc/lua/sd'
 /bin/mkdir -p '/usr/lib/vlc/lua/intf/modules'
 /usr/bin/install -c -m 644  lua/intf/modules/common.luac lua/intf/modules/host.luac lua/intf/modules/httprequests.luac '/usr/lib/vlc/lua/intf/modules'
 /bin/mkdir -p '/usr/lib/vlc/lua/meta/art'
 /usr/bin/install -c -m 644  lua/meta/art/02_frenchtv.luac lua/meta/art/03_lastfm.luac lua/meta/art/01_googleimage.luac lua/meta/art/00_musicbrainz.luac '/usr/lib/vlc/lua/meta/art'
 /bin/mkdir -p '/usr/share/kde4/apps/solid/actions'
 /usr/bin/install -c -m 644 solid/vlc-openbd.desktop solid/vlc-opencda.desktop solid/vlc-opendvd.desktop solid/vlc-openvcd.desktop '/usr/share/kde4/apps/solid/actions'
make[3]: Leaving directory `/home/pi/vlc/share'
make[2]: Leaving directory `/home/pi/vlc/share'
Making install in src
make[2]: Entering directory `/home/pi/vlc/src'
  GEN    stamp-revision
make  install-am
make[3]: Entering directory `/home/pi/vlc/src'
make[4]: Entering directory `/home/pi/vlc/src'
 /bin/mkdir -p '/usr/lib'
 ../doltlibtool   --mode=install /usr/bin/install -c   libvlccore.la '/usr/lib'
libtool: install: /usr/bin/install -c .libs/libvlccore.so.7.0.0 /usr/lib/libvlccore.so.7.0.0
libtool: install: (cd /usr/lib && { ln -s -f libvlccore.so.7.0.0 libvlccore.so.7 || { rm -f libvlccore.so.7 && ln -s libvlccore.so.7.0.0 libvlccore.so.7; }; })
libtool: install: (cd /usr/lib && { ln -s -f libvlccore.so.7.0.0 libvlccore.so || { rm -f libvlccore.so && ln -s libvlccore.so.7.0.0 libvlccore.so; }; })
libtool: install: /usr/bin/install -c .libs/libvlccore.lai /usr/lib/libvlccore.la
   /usr/lib
     during execution
     during linking
 /bin/mkdir -p '/usr/include/vlc/plugins'
 /usr/bin/install -c -m 644 ../include/vlc_about.h '/usr/include/vlc/plugins'
 /bin/mkdir -p '/usr/lib/pkgconfig'
 /usr/bin/install -c -m 644 vlc-plugin.pc '/usr/lib/pkgconfig'
 /usr/bin/install -c -m 644 ../include/vlc_access.h ../include/vlc_aout.h ../include/vlc_aout_volume.h ../include/vlc_arrays.h ../include/vlc_art_finder.h ../include/vlc_atomic.h ../include/vlc_avcodec.h ../include/vlc_bits.h ../include/vlc_block.h ../include/vlc_block_helper.h ../include/vlc_charset.h ../include/vlc_codec.h ../include/vlc_common.h ../include/vlc_config.h ../include/vlc_config_cat.h ../include/vlc_configuration.h ../include/vlc_cpu.h ../include/vlc_dialog.h ../include/vlc_demux.h ../include/vlc_epg.h ../include/vlc_es.h ../include/vlc_es_out.h ../include/vlc_events.h ../include/vlc_filter.h ../include/vlc_fourcc.h ../include/vlc_fs.h ../include/vlc_gcrypt.h ../include/vlc_opengl.h ../include/vlc_http.h ../include/vlc_httpd.h ../include/vlc_image.h ../include/vlc_inhibit.h ../include/vlc_input.h ../include/vlc_input_item.h ../include/vlc_keys.h ../include/vlc_main.h ../include/vlc_md5.h ../include/vlc_messages.h ../include/vlc_meta.h ../include/vlc_media_library.h '/usr/include/vlc/plugins'
 /usr/bin/install -c -m 644 ../include/vlc_mime.h ../include/vlc_modules.h ../include/vlc_mouse.h ../include/vlc_mtime.h ../include/vlc_network.h ../include/vlc_objects.h ../include/vlc_picture.h ../include/vlc_picture_fifo.h ../include/vlc_picture_pool.h ../include/vlc_playlist.h ../include/vlc_plugin.h ../include/vlc_probe.h ../include/vlc_rand.h ../include/vlc_services_discovery.h ../include/vlc_fingerprinter.h ../include/vlc_sout.h ../include/vlc_spu.h ../include/vlc_stream.h ../include/vlc_strings.h ../include/vlc_subpicture.h ../include/vlc_text_style.h ../include/vlc_threads.h ../include/vlc_tls.h ../include/vlc_url.h ../include/vlc_variables.h ../include/vlc_vlm.h ../include/vlc_video_splitter.h ../include/vlc_vout.h ../include/vlc_vout_display.h ../include/vlc_vout_osd.h ../include/vlc_vout_window.h ../include/vlc_xml.h ../include/vlc_xlib.h '/usr/include/vlc/plugins'
make[4]: Leaving directory `/home/pi/vlc/src'
make[3]: Leaving directory `/home/pi/vlc/src'
make[2]: Leaving directory `/home/pi/vlc/src'
Making install in modules
make[2]: Entering directory `/home/pi/vlc/modules'
make[3]: Entering directory `/home/pi/vlc/modules'
Making install in .
make[4]: Entering directory `/home/pi/vlc/modules'
make[5]: Entering directory `/home/pi/vlc/modules'
make[5]: Für das Ziel »install-exec-am« ist nichts zu tun.
 /bin/mkdir -p '/usr/lib/vlc/plugins/access'
 ../doltlibtool   --mode=install /usr/bin/install -c   libattachment_plugin.la libfilesystem_plugin.la libidummy_plugin.la libimem_plugin.la librar_plugin.la libsdp_plugin.la libtimecode_plugin.la libvdr_plugin.la libzip_plugin.la libaccess_alsa_plugin.la libaccess_jack_plugin.la libpulsesrc_plugin.la libdc1394_plugin.la liblinsys_hdsdi_plugin.la liblinsys_sdi_plugin.la libshm_plugin.la libv4l2_plugin.la libxcb_screen_plugin.la librdp_plugin.la libcdda_plugin.la libvcd_plugin.la libdvdnav_plugin.la libdvdread_plugin.la liblibbluray_plugin.la libaccess_bd_plugin.la libdtv_plugin.la libdvb_plugin.la libftp_plugin.la libhttp_plugin.la liblive555_plugin.la libaccess_mms_plugin.la libtcp_plugin.la libudp_plugin.la libavio_plugin.la libgnomevfs_plugin.la libaccess_mtp_plugin.la librtp_plugin.la '/usr/lib/vlc/plugins/access'
libtool: install: warning: relinking `libattachment_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -o libattachment_plugin.la -rpath /usr/lib/vlc/plugins/access access/attachment.lo )
libtool: install: /usr/bin/install -c .libs/libattachment_plugin.soT /usr/lib/vlc/plugins/access/libattachment_plugin.so
libtool: install: /usr/bin/install -c .libs/libattachment_plugin.lai /usr/lib/vlc/plugins/access/libattachment_plugin.la
libtool: install: warning: relinking `libfilesystem_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -o libfilesystem_plugin.la -rpath /usr/lib/vlc/plugins/access access/libfilesystem_plugin_la-file.lo access/libfilesystem_plugin_la-directory.lo access/libfilesystem_plugin_la-fs.lo )
libtool: install: /usr/bin/install -c .libs/libfilesystem_plugin.soT /usr/lib/vlc/plugins/access/libfilesystem_plugin.so
libtool: install: /usr/bin/install -c .libs/libfilesystem_plugin.lai /usr/lib/vlc/plugins/access/libfilesystem_plugin.la
libtool: install: warning: relinking `libidummy_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -o libidummy_plugin.la -rpath /usr/lib/vlc/plugins/access access/idummy.lo )
libtool: install: /usr/bin/install -c .libs/libidummy_plugin.soT /usr/lib/vlc/plugins/access/libidummy_plugin.so
libtool: install: /usr/bin/install -c .libs/libidummy_plugin.lai /usr/lib/vlc/plugins/access/libidummy_plugin.la
libtool: install: warning: relinking `libimem_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -o libimem_plugin.la -rpath /usr/lib/vlc/plugins/access access/imem.lo -lm )
libtool: install: /usr/bin/install -c .libs/libimem_plugin.soT /usr/lib/vlc/plugins/access/libimem_plugin.so
libtool: install: /usr/bin/install -c .libs/libimem_plugin.lai /usr/lib/vlc/plugins/access/libimem_plugin.la
libtool: install: warning: relinking `librar_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -o librar_plugin.la -rpath /usr/lib/vlc/plugins/access access/rar/librar_plugin_la-rar.lo access/rar/librar_plugin_la-access.lo access/rar/librar_plugin_la-stream.lo access/rar/librar_plugin_la-module.lo )
libtool: install: /usr/bin/install -c .libs/librar_plugin.soT /usr/lib/vlc/plugins/access/librar_plugin.so
libtool: install: /usr/bin/install -c .libs/librar_plugin.lai /usr/lib/vlc/plugins/access/librar_plugin.la
libtool: install: warning: relinking `libsdp_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -o libsdp_plugin.la -rpath /usr/lib/vlc/plugins/access access/sdp.lo )
libtool: install: /usr/bin/install -c .libs/libsdp_plugin.soT /usr/lib/vlc/plugins/access/libsdp_plugin.so
libtool: install: /usr/bin/install -c .libs/libsdp_plugin.lai /usr/lib/vlc/plugins/access/libsdp_plugin.la
libtool: install: warning: relinking `libtimecode_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -o libtimecode_plugin.la -rpath /usr/lib/vlc/plugins/access access/timecode.lo )
libtool: install: /usr/bin/install -c .libs/libtimecode_plugin.soT /usr/lib/vlc/plugins/access/libtimecode_plugin.so
libtool: install: /usr/bin/install -c .libs/libtimecode_plugin.lai /usr/lib/vlc/plugins/access/libtimecode_plugin.la
libtool: install: warning: relinking `libvdr_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -o libvdr_plugin.la -rpath /usr/lib/vlc/plugins/access access/vdr.lo )
libtool: install: /usr/bin/install -c .libs/libvdr_plugin.soT /usr/lib/vlc/plugins/access/libvdr_plugin.so
libtool: install: /usr/bin/install -c .libs/libvdr_plugin.lai /usr/lib/vlc/plugins/access/libvdr_plugin.la
libtool: install: warning: relinking `libzip_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -I./access/zip/unzip -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -o libzip_plugin.la -rpath /usr/lib/vlc/plugins/access access/zip/libzip_plugin_la-zipstream.lo access/zip/libzip_plugin_la-zipaccess.lo libunzip.la )
libtool: install: /usr/bin/install -c .libs/libzip_plugin.soT /usr/lib/vlc/plugins/access/libzip_plugin.so
libtool: install: /usr/bin/install -c .libs/libzip_plugin.lai /usr/lib/vlc/plugins/access/libzip_plugin.la
libtool: install: warning: relinking `libaccess_alsa_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -I/usr/include/alsa -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -o libaccess_alsa_plugin.la -rpath /usr/lib/vlc/plugins/access access/libaccess_alsa_plugin_la-alsa.lo -lasound )
libtool: install: /usr/bin/install -c .libs/libaccess_alsa_plugin.soT /usr/lib/vlc/plugins/access/libaccess_alsa_plugin.so
libtool: install: /usr/bin/install -c .libs/libaccess_alsa_plugin.lai /usr/lib/vlc/plugins/access/libaccess_alsa_plugin.la
libtool: install: warning: relinking `libaccess_jack_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -o libaccess_jack_plugin.la -rpath /usr/lib/vlc/plugins/access access/libaccess_jack_plugin_la-jack.lo -ljack )
libtool: install: /usr/bin/install -c .libs/libaccess_jack_plugin.soT /usr/lib/vlc/plugins/access/libaccess_jack_plugin.so
libtool: install: /usr/bin/install -c .libs/libaccess_jack_plugin.lai /usr/lib/vlc/plugins/access/libaccess_jack_plugin.la
libtool: install: warning: relinking `libpulsesrc_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -D_REENTRANT -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -o libpulsesrc_plugin.la -rpath /usr/lib/vlc/plugins/access access/libpulsesrc_plugin_la-pulse.lo libvlc_pulse.la -lpulse )
libtool: install: /usr/bin/install -c .libs/libpulsesrc_plugin.soT /usr/lib/vlc/plugins/access/libpulsesrc_plugin.so
libtool: install: /usr/bin/install -c .libs/libpulsesrc_plugin.lai /usr/lib/vlc/plugins/access/libpulsesrc_plugin.la
libtool: install: warning: relinking `libdc1394_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -rpath /usr/lib/vlc/plugins/access -o libdc1394_plugin.la access/libdc1394_plugin_la-dc1394.lo -ldc1394 )
libtool: install: /usr/bin/install -c .libs/libdc1394_plugin.soT /usr/lib/vlc/plugins/access/libdc1394_plugin.so
libtool: install: /usr/bin/install -c .libs/libdc1394_plugin.lai /usr/lib/vlc/plugins/access/libdc1394_plugin.la
libtool: install: warning: relinking `liblinsys_hdsdi_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -rpath /usr/lib/vlc/plugins/access -o liblinsys_hdsdi_plugin.la access/linsys/linsys_hdsdi.lo )
libtool: install: /usr/bin/install -c .libs/liblinsys_hdsdi_plugin.soT /usr/lib/vlc/plugins/access/liblinsys_hdsdi_plugin.so
libtool: install: /usr/bin/install -c .libs/liblinsys_hdsdi_plugin.lai /usr/lib/vlc/plugins/access/liblinsys_hdsdi_plugin.la
libtool: install: warning: relinking `liblinsys_sdi_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -rpath /usr/lib/vlc/plugins/access -o liblinsys_sdi_plugin.la access/linsys/liblinsys_sdi_plugin_la-linsys_sdi.lo -lzvbi -lpthread -lm -lpng -lz )
libtool: install: /usr/bin/install -c .libs/liblinsys_sdi_plugin.soT /usr/lib/vlc/plugins/access/liblinsys_sdi_plugin.so
libtool: install: /usr/bin/install -c .libs/liblinsys_sdi_plugin.lai /usr/lib/vlc/plugins/access/liblinsys_sdi_plugin.la
libtool: install: warning: relinking `libshm_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -o libshm_plugin.la -rpath /usr/lib/vlc/plugins/access access/shm.lo -lm )
libtool: install: /usr/bin/install -c .libs/libshm_plugin.soT /usr/lib/vlc/plugins/access/libshm_plugin.so
libtool: install: /usr/bin/install -c .libs/libshm_plugin.lai /usr/lib/vlc/plugins/access/libshm_plugin.la
libtool: install: warning: relinking `libv4l2_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -o libv4l2_plugin.la -rpath /usr/lib/vlc/plugins/access access/v4l2/libv4l2_plugin_la-v4l2.lo access/v4l2/libv4l2_plugin_la-video.lo access/v4l2/libv4l2_plugin_la-vbi.lo access/v4l2/libv4l2_plugin_la-demux.lo access/v4l2/libv4l2_plugin_la-access.lo access/v4l2/libv4l2_plugin_la-radio.lo access/v4l2/libv4l2_plugin_la-controls.lo access/v4l2/libv4l2_plugin_la-lib.lo -ldl -lm -lzvbi -lpthread -lm -lpng -lz -lpthread )
libtool: install: /usr/bin/install -c .libs/libv4l2_plugin.soT /usr/lib/vlc/plugins/access/libv4l2_plugin.so
libtool: install: /usr/bin/install -c .libs/libv4l2_plugin.lai /usr/lib/vlc/plugins/access/libv4l2_plugin.la
libtool: install: warning: relinking `libxcb_screen_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -o libxcb_screen_plugin.la -rpath /usr/lib/vlc/plugins/access access/screen/libxcb_screen_plugin_la-xcb.lo -lxcb -lxcb-composite -lxcb-xfixes -lxcb-render -lxcb-shape -lxcb -lxcb-shm -lxcb )
libtool: install: /usr/bin/install -c .libs/libxcb_screen_plugin.soT /usr/lib/vlc/plugins/access/libxcb_screen_plugin.so
libtool: install: /usr/bin/install -c .libs/libxcb_screen_plugin.lai /usr/lib/vlc/plugins/access/libxcb_screen_plugin.la
libtool: install: warning: relinking `librdp_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -rpath /usr/lib/vlc/plugins/access -o librdp_plugin.la access/librdp_plugin_la-rdp.lo -lfreerdp-core -lfreerdp-codec -lfreerdp-gdi -lfreerdp-kbd -lfreerdp-rail -lfreerdp-channels -lfreerdp-utils )
libtool: install: /usr/bin/install -c .libs/librdp_plugin.soT /usr/lib/vlc/plugins/access/librdp_plugin.so
libtool: install: /usr/bin/install -c .libs/librdp_plugin.lai /usr/lib/vlc/plugins/access/librdp_plugin.la
libtool: install: warning: relinking `libcdda_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -rpath /usr/lib/vlc/plugins/access -o libcdda_plugin.la access/libcdda_plugin_la-cdda.lo access/vcd/libcdda_plugin_la-cdrom.lo -lcddb )
libtool: install: /usr/bin/install -c .libs/libcdda_plugin.soT /usr/lib/vlc/plugins/access/libcdda_plugin.so
libtool: install: /usr/bin/install -c .libs/libcdda_plugin.lai /usr/lib/vlc/plugins/access/libcdda_plugin.la
libtool: install: warning: relinking `libvcd_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -rpath /usr/lib/vlc/plugins/access -o libvcd_plugin.la access/vcd/vcd.lo access/vcd/cdrom.lo )
libtool: install: /usr/bin/install -c .libs/libvcd_plugin.soT /usr/lib/vlc/plugins/access/libvcd_plugin.so
libtool: install: /usr/bin/install -c .libs/libvcd_plugin.lai /usr/lib/vlc/plugins/access/libvcd_plugin.la
libtool: install: warning: relinking `libdvdnav_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -rpath /usr/lib/vlc/plugins/access -o libdvdnav_plugin.la access/libdvdnav_plugin_la-dvdnav.lo -ldvdnav -lpthread )
libtool: install: /usr/bin/install -c .libs/libdvdnav_plugin.soT /usr/lib/vlc/plugins/access/libdvdnav_plugin.so
libtool: install: /usr/bin/install -c .libs/libdvdnav_plugin.lai /usr/lib/vlc/plugins/access/libdvdnav_plugin.la
libtool: install: warning: relinking `libdvdread_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -rpath /usr/lib/vlc/plugins/access -o libdvdread_plugin.la access/libdvdread_plugin_la-dvdread.lo -ldvdread )
libtool: install: /usr/bin/install -c .libs/libdvdread_plugin.soT /usr/lib/vlc/plugins/access/libdvdread_plugin.so
libtool: install: /usr/bin/install -c .libs/libdvdread_plugin.lai /usr/lib/vlc/plugins/access/libdvdread_plugin.la
libtool: install: warning: relinking `liblibbluray_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -rpath /usr/lib/vlc/plugins/access -o liblibbluray_plugin.la access/liblibbluray_plugin_la-bluray.lo -lbluray )
libtool: install: /usr/bin/install -c .libs/liblibbluray_plugin.soT /usr/lib/vlc/plugins/access/liblibbluray_plugin.so
libtool: install: /usr/bin/install -c .libs/liblibbluray_plugin.lai /usr/lib/vlc/plugins/access/liblibbluray_plugin.la
libtool: install: warning: relinking `libaccess_bd_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -o libaccess_bd_plugin.la -rpath /usr/lib/vlc/plugins/access access/bd/bd.lo access/bd/mpls.lo access/bd/clpi.lo )
libtool: install: /usr/bin/install -c .libs/libaccess_bd_plugin.soT /usr/lib/vlc/plugins/access/libaccess_bd_plugin.so
libtool: install: /usr/bin/install -c .libs/libaccess_bd_plugin.lai /usr/lib/vlc/plugins/access/libaccess_bd_plugin.la
libtool: install: warning: relinking `libdtv_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -DHAVE_LINUX_DVB -DHAVE_DVBPSI -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -o libdtv_plugin.la -rpath /usr/lib/vlc/plugins/access access/dtv/libdtv_plugin_la-access.lo access/dtv/libdtv_plugin_la-linux.lo access/dtv/libdtv_plugin_la-en50221.lo -ldvbpsi )
libtool: install: /usr/bin/install -c .libs/libdtv_plugin.soT /usr/lib/vlc/plugins/access/libdtv_plugin.so
libtool: install: /usr/bin/install -c .libs/libdtv_plugin.lai /usr/lib/vlc/plugins/access/libdtv_plugin.la
libtool: install: warning: relinking `libdvb_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -o libdvb_plugin.la -rpath /usr/lib/vlc/plugins/access access/dvb/libdvb_plugin_la-access.lo access/dvb/libdvb_plugin_la-linux_dvb.lo access/dvb/libdvb_plugin_la-scan.lo -ldvbpsi )
libtool: install: /usr/bin/install -c .libs/libdvb_plugin.soT /usr/lib/vlc/plugins/access/libdvb_plugin.so
libtool: install: /usr/bin/install -c .libs/libdvb_plugin.lai /usr/lib/vlc/plugins/access/libdvb_plugin.la
libtool: install: warning: relinking `libftp_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -o libftp_plugin.la -rpath /usr/lib/vlc/plugins/access access/ftp.lo )
libtool: install: /usr/bin/install -c .libs/libftp_plugin.soT /usr/lib/vlc/plugins/access/libftp_plugin.so
libtool: install: /usr/bin/install -c .libs/libftp_plugin.lai /usr/lib/vlc/plugins/access/libftp_plugin.la
libtool: install: warning: relinking `libhttp_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -o libhttp_plugin.la -rpath /usr/lib/vlc/plugins/access access/http.lo -lz )
libtool: install: /usr/bin/install -c .libs/libhttp_plugin.soT /usr/lib/vlc/plugins/access/libhttp_plugin.so
libtool: install: /usr/bin/install -c .libs/libhttp_plugin.lai /usr/lib/vlc/plugins/access/libhttp_plugin.la
libtool: install: warning: relinking `liblive555_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CXX --mode=relink g++ -I/usr/include/liveMedia -I/usr/include/groupsock -I/usr/include/BasicUsageEnvironment -I/usr/include/UsageEnvironment -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wvolatile-register-var -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -rpath /usr/lib/vlc/plugins/access -o liblive555_plugin.la access/liblive555_plugin_la-live555.lo access/mms/asf.lo access/mms/buffer.lo -lliveMedia_pic -lgroupsock_pic -lBasicUsageEnvironment_pic -lUsageEnvironment_pic )
libtool: install: /usr/bin/install -c .libs/liblive555_plugin.soT /usr/lib/vlc/plugins/access/liblive555_plugin.so
libtool: install: /usr/bin/install -c .libs/liblive555_plugin.lai /usr/lib/vlc/plugins/access/liblive555_plugin.la
libtool: install: warning: relinking `libaccess_mms_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -o libaccess_mms_plugin.la -rpath /usr/lib/vlc/plugins/access access/mms/libaccess_mms_plugin_la-mms.lo access/mms/libaccess_mms_plugin_la-mmsh.lo access/mms/libaccess_mms_plugin_la-mmstu.lo access/mms/libaccess_mms_plugin_la-buffer.lo access/mms/libaccess_mms_plugin_la-asf.lo )
libtool: install: /usr/bin/install -c .libs/libaccess_mms_plugin.soT /usr/lib/vlc/plugins/access/libaccess_mms_plugin.so
libtool: install: /usr/bin/install -c .libs/libaccess_mms_plugin.lai /usr/lib/vlc/plugins/access/libaccess_mms_plugin.la
libtool: install: warning: relinking `libtcp_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -o libtcp_plugin.la -rpath /usr/lib/vlc/plugins/access access/tcp.lo )
libtool: install: /usr/bin/install -c .libs/libtcp_plugin.soT /usr/lib/vlc/plugins/access/libtcp_plugin.so
libtool: install: /usr/bin/install -c .libs/libtcp_plugin.lai /usr/lib/vlc/plugins/access/libtcp_plugin.la
libtool: install: warning: relinking `libudp_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -o libudp_plugin.la -rpath /usr/lib/vlc/plugins/access access/udp.lo -lpthread )
libtool: install: /usr/bin/install -c .libs/libudp_plugin.soT /usr/lib/vlc/plugins/access/libudp_plugin.so
libtool: install: /usr/bin/install -c .libs/libudp_plugin.lai /usr/lib/vlc/plugins/access/libudp_plugin.la
libtool: install: warning: relinking `libavio_plugin.la'
libtool: install: (cd /home/pi/vlc/modules; /bin/bash /home/pi/vlc/modules/../libtool  --silent --tag CC --mode=relink gcc -std=gnu99 -g -O2 -Wall -Wextra -Wsign-compare -Wundef -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wmissing-prototypes -Wvolatile-register-var -Werror-implicit-function-declaration -pipe -fvisibility=hidden -ffast-math -funroll-loops -fomit-frame-pointer -avoid-version -module -export-symbols-regex "^vlc_entry" -shrext .so -no-undefined ../src/libvlccore.la ../compat/libcompat.la -Wl,-Bsymbolic -o libavio_plugin.la -rpath /usr/lib/vlc/plugins/access access/libavio_plugin_la-avio.lo codec/avcodec/libavio_plugin_la-cpu.lo -lavformat -lavcodec -lavutil -lm )
collect2: ld terminated with signal 11 [Segmentation fault]
/usr/bin/ld: BFD (GNU Binutils for Debian) 2.22 assertion fail ../../bfd/elflink.c:2521
/usr/bin/ld: BFD (GNU Binutils for Debian) 2.22 assertion fail ../../bfd/elflink.c:2531
libtool: install: error: relink `libavio_plugin.la' with the above command before installing it
make[5]: *** [install-accessLTLIBRARIES] Fehler 1
make[5]: Leaving directory `/home/pi/vlc/modules'
make[4]: *** [install-am] Fehler 2
make[4]: Leaving directory `/home/pi/vlc/modules'
make[3]: *** [install-recursive] Fehler 1
make[3]: Leaving directory `/home/pi/vlc/modules'
make[2]: *** [install] Fehler 2
make[2]: Leaving directory `/home/pi/vlc/modules'
make[1]: *** [install-recursive] Fehler 1
make[1]: Leaving directory `/home/pi/vlc'
make: *** [install] Fehler 2
pi@raspberrypi ~/vlc $
Alles, was schiefgehen kann, wird auch schiefgehen.
gkreidl
Re: Compile VLC with HW acceleration - complete tutorial
Sat Sep 13, 2014 2:01 am
That's the critical line in your install log:
But I don't know why you're getting the error.
How much memory do you have? Is swap enabled?
Minimal Kiosk Browser (kweb)
Micha1982
Tue Sep 16, 2014 1:20 am
Its a 512-version, I am not sure atm about the split, but I think 64mb are set for graphic....
Swap enabled? Don´t know...where can I see that?
Couldn´t someone simply put a working one into the repository? What is need to put it into repo and why doesn´t it already be there?
Would be great to have such a Vlc-player out-of-the-box - not only for me, I am sure thousands of other users would be happy, too if that player working hw-accelerated.
Edit: gpSP-compiling does not work for me, too (thread is one of the first in ´gaming´-section, last posts) - maybe there is an association/something missing? I don´t know....such a good tutorial - but it simply does not work here, too.
gkreidl
Tue Sep 16, 2014 11:47 am
I tried th create a simple debian package (using checkinstall, which will NOT check for dependencies), but currently it is not even possible to compile VLC any more because of the latest dist-upgrade for the new browser.
libpostproc-dev cannot be installed any more, because it needs libavutil-dev 6:0.8.13, but current version now is 6:9.14. This has to be fixed.
BlackIceNetwork
Tue Oct 07, 2014 4:53 am
Hi gkriedl,
I'm just wondering if this installation still possible to do? I've been following every post I can find, but can't seem to find a successful work around. Question: if no one at the moment isn't able to Compile VLC with HW acceleration on Raspbian would it be possible if someone can share an image of Raspbian with a working version of VLC with HW acceleration already pre-installed?
Thanks In Advance
BlackIceNetwork
gkreidl
Tue Oct 07, 2014 9:02 am
If you are able to find a Raspbian image from the time before the latest dist-upgrade you may be able to compile a version if you do not download the latest code but a VLC commit from end of October 2013.
Or you upgrade to Jessie, which will be frozen in about a month anyway and so become the stable release a while later. You should even be able to compile the latest release of VLC then.
But the real problem is the mess the foundation produced by publishing the new epiphany browser and that no one cares about fixing it. I already published the dependency problem in three different places and also sent an email to one of the developers from the collabora team and got no answer until now. In the beginning I got a lot of help from one of the developers of the collabora team to make kweb(3) work again and I've sent quite a number of bug reports to him. They promised to fix the bugs very soon, but nothing has happened since and now I don't get answers to my emails any more.
BTW, on my system HW accelerated VLC is still working; it's only a development library that cannot be installed any more and so VLC cannot be compiled and not even be installed any more. This should be easy to fix, but - as I said - nobody seems to care.
plugwash
Tue Oct 07, 2014 11:56 am
gkreidl wrote: libpostproc-dev cannot be installed any more, because it needs libavutil-dev 6:0.8.13, but current version now is 6:9.14.
It seems that libpostproc-dev used to be built from the libav source package but was later split out.
The first thing I'd try is grabbing the libpostproc source from debian's wheezy-backports and building it on your system. Something along the lines of
apt-get install devscripts debian-keyring
dget http://ftp.de.debian.org/debian/pool/ma ... po70+1.dsc
cd libpostproc-0.git20120821
dpkg-buildpackage -b
Unfortunately what goes into the foundation repo is beyond my control.
gkreidl
Tue Oct 07, 2014 12:19 pm
plugwash wrote:...
I know it's not your fault, plugwash. The problem is, that nobody seems to be available for us who's responsible to get such things fixed.
I'm not a purist and if the foundation decides to go such a way to get a better browser experience I can live with that. But somebody has to take responsibility to clean up that mess, fix dependencies, that don't work any more, fix bugs (tons of error messages from all kinds of GTK+2/3 applications, for example) and last but not least fix the new browser (engine) itself. It's still full of bugs (no true color support, crashes on certain websites, iframes not scrolling and so on).
BlackIceNetwork
Tue Oct 07, 2014 8:07 pm
gkreidl,
I have 2014-01-07-wheezy-raspbian, but would it be possible for you to make a copy of your Raspbian with VLC HW Acceleration image with Win32DiskImager and uploaded for everyone to use? you can remove all personal files or programs you don't want to share off the image. All I just want is a working copy of Raspbian with VLC HW Acceleration, I can use due to the feature of VLC able to freeze a video on last frame for my project.
Thanks in Advance
gkreidl
Tue Oct 07, 2014 9:33 pm
BlackIceNetwork wrote:gkreidl,
Thanks in Advance
I can send you my git image of VLC. You should be able to compile it if you follow the tutorial in the OP step by step. Contact me by PM.
charlyboss
Wed Oct 15, 2014 4:46 pm
Please, can you send me the link to the git?
I spent a lot of time whit the oficial git repository :(
Many thanks
gkreidl
Thu Oct 16, 2014 7:01 am
With the current Raspbian version it cannot be compiled any more because of a broken dependency.
BlackIceNetwork
Mon Oct 20, 2014 5:47 am
Can someone please share an image of their SD card running Raspbian with VLC hardware acceleration? the reason I'm asking is because at the moment this tutorial is obsolete, due to changes on Raspbian updates and upgrades no one is able to install libpostproc-dev.
Thanks in Advance
plugwash
Tue Oct 21, 2014 11:07 pm
Try adding
deb http://plugwash.raspbian.org/wsf wheezy-wsf main
to your sources.list
Joe Schmoe
Wed Oct 22, 2014 12:40 am
Assuming you are responding to the immediately proceeding post, …
I think you are missing the point, suggesting adding things to the apt-get files. The poster asked for an image of a working system - and I second the request. That's the only way for anyone (I.e., those who claim that it exists and works) to prove that this thing actually exists and actually works.
plugwash
Wed Oct 22, 2014 9:28 am
I was providing a soloution to the problem of libpostproc-dev being uninstallable.
Return to “Raspberry Pi OS”
