Page 13 of 17
Re: Tutorial: Compile VLC with HW acceleration - Jessie, RPi
Posted: Mon Jul 25, 2016 2:33 pm
by k3noni
gkreidl wrote:VLC consists of more than one package. Install synaptic, start it with "gksudo synaptic" and search for "vlc". This will show you, if you still have any VLC packages installed.
OK thanks. I also think that vlc is not fully uninstalled when doing "make install".
Figured it out. It was the firmware 4.4.15. After downgrading to 4.4.14 everything worked as usual.
Posted: Fri Jul 29, 2016 5:37 am
by MikeK
Just a note of thanks for this detailed and accurate procedure. I successfully executed all the steps that enabled a smooth, stutter-free, full-screen rendering to HDMI video/audio. This may not seem such a big deal to many of the members in this forum but for an old Windows programmer like me whose Raspbian (Linux in general) skills are crude at best it was quite an achievement! Many thanks.
Just a couple points of note. (Maybe too obvious in this school. :) )
1. I needed to delete the '.' from the end of the final command for proper execution
2. Before executing the first step, you need to make sure you're in the directory to which you extracted the VLC folder.
FYI, my scenario is as follows.
1. HDMI output to a device that splits the HDMI out to component video and optical audio
2. Source media is .iso DVD images stored on a NAS server (shared video folder mounted as a cifs file system)
Now just working on one stubborn issue. Keyboard navigation through VLC seems to be disabled (I can't stop the video!)
Cheers.
Posted: Fri Jul 29, 2016 9:06 am
by gkreidl
MikeK wrote:Just a note of thanks for this detailed and accurate procedure. I successfully executed all the steps that enabled a smooth, stutter-free, full-screen rendering to HDMI video/audio. This may not seem such a big deal to many of the members in this forum but for an old Windows programmer like me whose Raspbian (Linux in general) skills are crude at best it was quite an achievement! Many thanks.
Cheers.
ad 1) I removed the "." from the install command (a stupid typo).
ad 2) I'm not sure what you mean by "first step". To install dependencies you do not have to go to the VLC folder. The compilation commands start with a "cd ..." which goes to the source code folder.
keyboard commands do work - at least they should. It's the only way to control VLC when the video covers the whole screen. But the VLC window must be in front for keyboard controls to work. If you click by accident outside of the VLC window, it will not be in front any more. It's best practice to maximize the VLC window before playing video in overlay (accelerated) mode.
Posted: Fri Jul 29, 2016 9:17 am
by sheldor_sq
I'm using VLC remote for Android for controls, i think it's also available for iOS. This way, you can fully control vlc, i. e. Play/pause, browse media (local, mounted network drives), even advanced controls like audio delay and subtitles. Starting up network streams (http,rtp) only works for YouTube though.
Posted: Fri Jul 29, 2016 11:53 am
by MikeK
@gkreidl: Of course you're absolutely correct about the keyboard commands. Silly oversight. I should have at least committed 'alt-l-s' to memory before doing a test run ;)
Thanks for the tip about maximizing the VLC window before playing the video in overlay mode. I'll do that in future.
Posted: Mon Aug 29, 2016 7:09 am
by Pontifex
Thanks for taking the time to write this guide. I've followed the instructions in the first post, but I'm unable to get video playback on a connected monitor.
I'm running a RasPi 3 with a Volumio 2 installation (a distribution derived from Jessie). I've successfully compiled and installed VLC, and I've gotten it to play audio successfully. Video playback with OpenMAX fails over both HDMI and SSH. Low quality streams will successfully play with over ssh when I use XVideo or X11 video, but not on a connected HDMI monitor. This leads me to suspect there is something wrong with my X11 configuration as well.
The error messages I get when I try to play a video:
[6b217330] core video output error: video output creation failed
[6ed9b3e8] core decoder error: failed to create video output
I sometimes also get :
[724011c8] xcb_xv vout display error: no available XVideo adaptor
If anyone has any suggestions for what I could do to make this work, I would be quite thankful.
Posted: Mon Aug 29, 2016 2:03 pm
by gkreidl
Pontifex wrote:Thanks for taking the time to write this guide. I've followed the instructions in the first post, but I'm unable to get video playback on a connected monitor.
For SD resolution SDL output should work (software only).
I have no idea, why OpenMax shouldn't work, but maybe there's some difference with the Volumio 2 installation.
Posted: Sat Sep 03, 2016 2:23 pm
by otyugh
I tried a less crude way to install VLC (that would make it easy to uninstall for instance) than using "make install" ; just downloading vlc from jessies source, changing the vlc/debian/rules and adding the flags about omxil I thought were missing.
confflags += \
        --enable-mmal \
        --enable-omxil \
        --enable-rpi-omxil \
Althought I end up with errors :
dh_install: usr/lib/vlc/plugins/codec/libomxil_vout_plugin.so exists in debian/tmp but is not installed
Any tip ?
Posted: Sat Sep 03, 2016 3:39 pm
by gkreidl
otyugh wrote:I tried a less crude way to install VLC (that would make it easy to uninstall for instance) than using "make install" ; just downloading vlc from jessies source, changing the vlc/debian/rules and adding the flags about omxil I thought were missing.
confflags += \
        --enable-mmal \
        --enable-omxil \
Any tip ?
What's easier about that? And it doesn't seem to work.
BTW, the compiled version can be uninstalled by running
sudo make uninstall
(from the VLC source folder).
And one more thing: enabling MMAL will crash VLC. Do not use it.
Posted: Sun Sep 04, 2016 7:48 am
by otyugh
I'll try your way then, as I don't succeed after 2 days of compilation (with that same previous error) ; I really lack knowedge around this, and I couldn't find help. Beat ! :p
Posted: Tue Sep 13, 2016 9:22 am
by nevare
I was wondering if anyone got this to work with the libvlc python bindings?
When starting vlc from command line the right output is selected but when i try to instantiate from libvlc using 'vlc.Instance("--vout=omxil_vout")' it just uses the default output
Posted: Mon Nov 14, 2016 5:37 pm
by rickwookie
I'd really like to get the latest VLC built with hardware acceleration, but I only need the vlc-nox components as I'm doing headless transcoding to h264.
How do I go about building just vlc-nox, and not the full vlc pagackage with all it's X baggage?
Thanks.
Posted: Mon Nov 14, 2016 11:24 pm
by gkreidl
rickwookie wrote:I'd really like to get the latest VLC built with hardware acceleration, but I only need the vlc-nox components as I'm doing headless transcoding to h264.
Thanks.
This won't work. HW acceleration in VLC goes directly to the screen output. It cannot be used for transcoding.
You could either use Handbrake, which is software only but uses NEON and multiple threads (real time SD transcoding), or gstreamer with the gst-omx module, but this is heavy stuff.
Posted: Mon Nov 21, 2016 5:02 pm
by rickwookie
gkreidl wrote:This won't work. HW acceleration in VLC goes directly to the screen output. It cannot be used for transcoding.
Oh I see, so the hardware decoding is using an overlay on the GPU? Like first gen MPEG2 decoder cards for PCs that you had to feed your graphics card output through so you got MPEG2 video on your monitor, that was effectively painted over the main output?
How does the gst-omx module leverage hardware encoding then?
Also, what hardware acceleration are they discussing in this thread: https://ubuntu-mate.community/t/hardwar ... il/4997/18 ?
I need to be able to live transcode an IP camera stream to an h264 RTSP stream, and I can do it using VLC, but the performance is currently to poor using software encoding. I'm open to ideas on how this can be done using other software though.
Posted: Mon Nov 21, 2016 7:14 pm
by gkreidl
I never tried that approach, but it can be done using a gstreamer1.0 tool chain and the gst-omx module. I use it for real time video transcoding.
viewtopic.php?f=38&t=123876
This is configured for a MPEG TS live TV stream, but it should also work with other streams if you modify the tool chain.
Posted: Fri Dec 02, 2016 4:10 pm
by knnthco
Just had to register to say THANK YOU! :D
Instructions in the very first comment worked perfectly for me. Previous to finding this, I spent hours fiddling around with mpv and omxplayer only to witness 360p streams stutter and chop like crazy, not to mention the CPU usage was 100% every time.
With your instructions, this Rasperberry Pi 3 B+ can handle a 720p/60fps stream and not break a sweat. Unreal that a $35 board can do this.
Thank you thank you thank you!
Posted: Sun Dec 11, 2016 4:04 pm
by behrthom
Hi, I'm new to raspberrypi. I have install at the paspberry Pi 3 the actual Raspian with the NOOBS image.
For my first feeling is that everythings work fine.
I want t o install the VLC with the HW accelearations an dfound this instructions.
I follow this instructions by my best, download the tar and unpack the tar at /home/pi
then i start the terminal and try:
[email protected]:~ $ sudo apt-get update
Holen: 1 http://mirrordirector.raspbian.org jessie InRelease [14,9 kB]
Holen: 2 http://archive.raspberrypi.org jessie InRelease [13,2 kB]
Holen: 3 http://mirrordirector.raspbian.org jessie/main armhf Packages [8.981 kB]
Holen: 4 http://archive.raspberrypi.org jessie/main armhf Packages [127 kB]
Holen: 5 http://archive.raspberrypi.org jessie/ui armhf Packages [53,6 kB]
Ign http://archive.raspberrypi.org jessie/main Translation-de_DE
Ign http://archive.raspberrypi.org jessie/main Translation-en
Ign http://archive.raspberrypi.org jessie/ui Translation-de_DE
Ign http://archive.raspberrypi.org jessie/ui Translation-en
Holen: 6 http://mirrordirector.raspbian.org jessie/contrib armhf Packages [37,5 kB]
Holen: 7 http://mirrordirector.raspbian.org jessie/non-free armhf Packages [70,3 kB]
Holen: 8 http://mirrordirector.raspbian.org jessie/rpi armhf Packages [1.356 B]
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-de_DE
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en
Ign http://mirrordirector.raspbian.org jessie/main Translation-de_DE
Ign http://mirrordirector.raspbian.org jessie/main Translation-en
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-de_DE
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-de_DE
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en
Es wurden 9.299 kB in 42 s geholt (217 kB/s).
Paketlisten werden gelesen... Fertig
it looks like good, so i start the next step:
[email protected]:~ $ sudo apt-get install autopoint gettext liba52-0.7.4-dev libaa1-dev libasound2-dev libass-dev libavahi-client-dev libavc1394-dev libavcodec-dev libavformat-dev libbluray-dev libcaca-dev libcddb2-dev libcdio-dev libchromaprint-dev libdbus-1-dev libdc1394-22-dev libdca-dev libdirectfb-dev libdvbpsi-dev libdvdnav-dev libdvdread-dev libegl1-mesa-dev libfaad-dev libflac-dev libfluidsynth-dev libfreerdp-dev libfreetype6-dev libfribidi-dev libgl1-mesa-dev libgles1-mesa-dev libgles2-mesa-dev libgnutls28-dev libgtk2.0-dev libidn11-dev libiso9660-dev libjack-jackd2-dev libkate-dev liblircclient-dev liblivemedia-dev liblua5.2-dev libmad0-dev libmatroska-dev libmodplug-dev libmpcdec-dev libmpeg2-4-dev libmtp-dev libncursesw5-dev libnotify-dev libogg-dev libomxil-bellagio-dev libopus-dev libpng12-dev libpulse-dev libqt4-dev libraw1394-dev libresid-builder-dev librsvg2-dev libsamplerate0-dev libschroedinger-dev libsdl-image1.2-dev libsdl1.2-dev libshine-dev libshout3-dev libsidplay2-dev libsmbclient-dev libspeex-dev libspeexdsp-dev libssh2-1-dev libswscale-dev libtag1-dev libtheora-dev libtwolame-dev libudev-dev libupnp-dev libv4l-dev libva-dev libvcdinfo-dev libvdpau-dev libvncserver-dev libvorbis-dev libx11-dev libx264-dev libxcb-composite0-dev libxcb-keysyms1-dev libxcb-randr0-dev libxcb-shm0-dev libxcb-xv0-dev libxcb1-dev libxext-dev libxinerama-dev libxml2-dev libxpm-dev libzvbi-dev lua5.2 oss4-dev pkg-config zlib1g-dev libtool build-essential autoconf
Abhängigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen.... Fertig
build-essential ist schon die neueste Version.
libpng12-dev ist schon die neueste Version.
libpng12-dev wurde als manuell installiert festgelegt.
pkg-config ist schon die neueste Version.
zlib1g-dev ist schon die neueste Version.
zlib1g-dev wurde als manuell installiert festgelegt.
libfreetype6-dev ist schon die neueste Version.
Einige Pakete konnten nicht installiert werden. Das kann bedeuten, dass
Sie eine unmögliche Situation angefordert haben oder, wenn Sie die
Unstable-Distribution verwenden, dass einige erforderliche Pakete noch
nicht erstellt wurden oder Incoming noch nicht verlassen haben.
Die folgenden Informationen helfen Ihnen vielleicht, die Situation zu lösen:
Die folgenden Pakete haben unerfüllte Abhängigkeiten:
libegl1-mesa-dev : Hängt ab von: libwayland-dev (>= 1.2.0) soll aber nicht installiert werden
libva-dev : Hängt ab von: libwayland-dev (>= 1.0.0) soll aber nicht installiert werden
E: Probleme können nicht korrigiert werden, Sie haben zurückgehaltene defekte Pakete.
Did anybody know what i made wrong?
kind regards Thomas
Posted: Sun Dec 11, 2016 7:02 pm
by gkreidl
Maybe this was caused by the recent XORG update to the non-stable version.
Try installing the libwayland-dev manually and install the missing packages afterwards.
Posted: Sun Dec 11, 2016 7:22 pm
by behrthom
thanks. for the information. But how can i do that?
An other question: I want to try the vlc with hw acceleration to use the vlc to convert an h.264 stream from an ip cam to a MJEP-stream. Is that possible? The reason is the following situation:
I have 4 ip-cams arround the home installed, also i have a cc51 from becker-antriebe GmbH, this homecontrol unit can collect several cams to its homecontrol system by a http request to get the MJPEG-stream from the cams. The problem my ip-cams can't stream MJPEG. So my idea was to built with the raspberry a kind of transcoder, the cc51 get the stream instead of the ip-cams direct over the raspberry. The raspberry get a small http server, a inncomming request open the stream to the asked IP-cam and stream the transcoded MJPEG to the cc51, if the connection lost to the cc51 the streaming will abort by the raspberry webserver.
I see that the vlc can transcoding the streams, the question is do the vlc that over the hw acceleration or not?
Today i bought also the licenses for the VC-l and MPEG-2 for the raspberry in hope to fix my problem also.
Is that helpfull or not?
kind regards Thomas
Posted: Sun Dec 11, 2016 8:53 pm
by gkreidl
No, you can use the HW acceleration only for displaying videos, not for converting them.
Video conversion is possible using gstreamer and the gst-omx module. I'm using it to transcode TV streams in real time.
Posted: Sun Dec 11, 2016 9:23 pm
by behrthom
ok thanks. than I must search for the gstreamer.
ups, it's not so easy and many stuff.
Have you a good idea to start up?
But at first, your opinion: can the paspberry pi 3 do that?
actually i have the problem that the pi have problems to stream the standard YouTube or maxdome videos with the rasbian pixel under chromius, have you got a idea where i can fix that -> output to FullHD makes breaks during the playing, i gives the GPU 128MB also 256MB without any changes, small windows work fine without any breaks ?
kind regards Thomas
PS: is it possible to change to the german forum?
Posted: Sun Dec 11, 2016 10:28 pm
by gkreidl
behrthom wrote:ok thanks. than I must search for the gstreamer.
kind regards Thomas
Create a new thread in the German forum.
Posted: Tue Dec 13, 2016 3:40 pm
by Muskoka
This tutorial no longer works, getting the same error as posted by behrthom above. Dependecies need to be "fixed/sorted out" for this to work as stated in the first post.
Posted: Tue Dec 13, 2016 4:02 pm
by gkreidl
Muskoka wrote:This tutorial no longer works, getting the same error as posted by behrthom above. Dependecies need to be "fixed/sorted out" for this to work as stated in the first post.
I don't think I can do anything about it right now. There seems to be a version mismatch in some dev-packages, perhaps caused by the latest XORG updates.
Posted: Wed Dec 14, 2016 8:39 am
by gkreidl
There are broken dependencies of dev packages required to compile VLC right now.
viewtopic.php?f=66&t=168291
