csdrbh
Re: Tutorial: Compile VLC with HW acceleration - Jessie, RPi
Wed May 04, 2016 1:19 am
Greetings - new to Raspberry Pi and trying to get vlc working with hardware acceleration to play VOB files (I have about 1200 DVD's ripped on a 16TB Raid5 QNAP.
I followed the updated instructions at the beginning of this post and everything ran to completion. I made sure the audio and video output are set correctly. When I play an mp4 video file, I get the audio output but no video. I just get the orange cone flickering but that is it.
As per one of the entries, I opened up a terminal session and went to the vlc directory and ran ./vlc. I then opened the video file from the menu entry and got the same result. When I cancelled the playback, these are the messages in the terminal session appearing over and over again:
[6f0f798] core filter error: Failed to create video filter2
[6f8007c8] core filter error: Failed to create video filter2
[6f80fdf8] chain filter error: Too high level of recursion (2)
[6f80f798] core filter error: Failed to create video filter2
[6f804538] core vout display error: Failed to create video filter2
[6f804538] core vout display error: Failed to adapt decoder format to display
[6f711b00] core video output error: video output creation failed
[6ebd4000] core decoder error: failed to create video output
[6f80f798] core filter error: Failed to create video filter28
Any ideas as to what the problem might be would be appreciated! I'll keep searching the Forums for an answer. Thanks for any assistance!!
gkreidl
Wed May 04, 2016 3:54 am
Are you sure, that you used the right video setting (OpenMax IL)?
Do you have set GPU memory to at least 128 MB?
Check, that the mp4 file uses either H264 or H263 codec. Try playing it with omxplayer first, to check if the codec is supported.
For VOB files you will need the MPEG-2 licence key.
Minimal Kiosk Browser (kweb)
csdrbh
Wed May 04, 2016 6:09 pm
I will double check everything when I get back home tonight.
Curious, if I play VOB files that I ripped with DVDShrink using VLC on Windows or OS X without any issues, why is there a need to license a codec on linux? Maybe I missed something in one of the other Forum entries.
Thanks for your help and I'll post an update tonight.
gkreidl
Wed May 04, 2016 6:34 pm
csdrbh wrote:I will double check everything when I get back home tonight.
MPEG codecs require a licence fee, software and hardware, but they only enforce them on hardware codecs, because in some countries (France, for example) the law or patent rights are different (VLC comes from France).
csdrbh
Thu May 05, 2016 2:51 am
I double checked the Video Output and it was set to OpenMax IL
I set the GPU memory to 128 - gpu_mem_1024=128
I checked the file once it was loaded into VLC and it reported that the codec was H264. Trying to play the video with vlc resulted in the same stream of error messages. I got audio, but no video - just the cone logo flashing like a refresh rate. It was only the cone that was flashing not the rest of the display screen outside of the vlc window.
I then opened the video with omxplayer and it played correctly - both audio and video. Here is what omxplayer reported after I stopped the playback:
omxplayer -o hdmi /home/pi/Videos/test.mp4
Video codec omx-h264 width 1280 height 720 profile 100 fps 30.000000
Audio codec aac channels 2 samplerate 44100 bitspersample 16
Subtitle count: 0, state: off, index: 1, delay: 0
V:PortSettingsChanged: [email protected] interlace:0 deinterlace:0 anaglyph:0 par:1.00 display:0 layer:0 alpha:255 aspectMode:0
Stopped at: 00:00:10
have a nice day ;)
Any other ideas??
gkreidl
Thu May 05, 2016 3:58 am
Reset preferences to default values. Then set video and audio again.
If that doesn't help, you have to check your build. Run the configure command again and compare the output to the following:
checking build system type... armv7l-unknown-linux-gnueabihf
checking host system type... armv7l-unknown-linux-gnueabihf
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking whether UID '1000' is supported by ustar format... yes
checking whether GID '1000' is supported by ustar format... yes
checking how to create a ustar tar archive... gnutar
checking whether make supports nested variables... (cached) yes
checking whether to enable maintainer-specific portions of Makefiles... yes
checking for style of include used by make... GNU
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether gcc understands -c and -o together... yes
checking dependency style of gcc... gcc3
checking for gcc option to accept ISO C99... -std=gnu99
checking how to run the C preprocessor... gcc -std=gnu99 -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking minix/config.h usability... no
checking minix/config.h presence... no
checking for minix/config.h... no
checking whether it is safe to define __EXTENSIONS__... yes
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking whether we are using the GNU Objective C compiler... no
checking whether gcc accepts -g... no
checking dependency style of gcc... (cached) gcc3
checking for egrep... (cached) /bin/grep -E
checking whether make sets $(MAKE)... (cached) yes
checking dependency style of gcc -std=gnu99... gcc3
checking for desktop-file-validate... desktop-file-validate
checking for yasm... yasm
checking for an ANSI C-conforming const... yes
checking for inline... inline
checking for C/C++ restrict keyword... __restrict
checking for an Android system... no
checking for 3rd party libraries path... not found
checking how to print strings... printf
checking for a sed that does not truncate output... /bin/sed
checking for fgrep... /bin/grep -F
checking for ld used by gcc -std=gnu99... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking how to convert armv7l-unknown-linux-gnueabihf file names to armv7l-unknown-linux-gnueabihf format... func_convert_file_noop
checking how to convert armv7l-unknown-linux-gnueabihf file names to toolchain format... func_convert_file_noop
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... (cached) pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for ar... ar
checking for archiver @FILE support... @
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc -std=gnu99 object... ok
checking for sysroot... no
checking for mt... mt
checking if mt is a manifest tool... no
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc -std=gnu99 supports -fno-rtti -fno-exceptions... no
checking for gcc -std=gnu99 option to produce PIC... -fPIC -DPIC
checking if gcc -std=gnu99 PIC flag -fPIC -DPIC works... yes
checking if gcc -std=gnu99 static flag -static works... yes
checking if gcc -std=gnu99 supports -c -o file.o... yes
checking if gcc -std=gnu99 supports -c -o file.o... (cached) yes
checking whether the gcc -std=gnu99 linker (/usr/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking for shl_load... no
checking for shl_load in -ldld... no
checking for dlopen... no
checking for dlopen in -ldl... yes
checking whether a program can dlopen itself... yes
checking whether a statically linked program can dlopen itself... no
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
checking how to run the C++ preprocessor... g++ -E
checking for ld used by g++... /usr/bin/ld
checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC -DPIC
checking if g++ PIC flag -fPIC -DPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
checking if g++ supports -c -o file.o... (cached) yes
checking dynamic linker characteristics... (cached) GNU/Linux ld.so
checking for windres... no
checking for bash... /bin/bash
checking if dolt supports this host... yes, replacing libtool
checking whether NLS is requested... yes
checking for msgfmt... /usr/bin/msgfmt
checking for gmsgfmt... /usr/bin/msgfmt
checking for xgettext... /usr/bin/xgettext
checking for msgmerge... /usr/bin/msgmerge
checking for shared library run path origin... done
checking for CFPreferencesCopyAppValue... no
checking for CFLocaleCopyCurrent... no
checking for GNU gettext in libc... yes
checking whether to use NLS... yes
checking where the gettext function comes from... libc
checking for iconv... yes
checking for working iconv... yes
checking for iconv declaration...
         extern size_t iconv (iconv_t cd, char * *inbuf, size_t *inbytesleft, char * *outbuf, size_t *outbytesleft);
checking for buggy GNU/libc versions... not present
checking for shared objects suffix... .so
checking whether nanosleep is declared... yes
checking for daemon... yes
checking for fcntl... yes
checking for fstatvfs... yes
checking for fork... yes
checking for getenv... yes
checking for getpwuid_r... yes
checking for isatty... yes
checking for lstat... yes
checking for memalign... yes
checking for mmap... yes
checking for open_memstream... yes
checking for openat... yes
checking for pread... yes
checking for posix_fadvise... yes
checking for posix_madvise... yes
checking for setlocale... yes
checking for stricmp... no
checking for strnicmp... no
checking for strptime... yes
checking for uselocale... yes
checking for atof... yes
checking for atoll... yes
checking for dirfd... yes
checking for fdopendir... yes
checking for flockfile... yes
checking for fsync... yes
checking for getdelim... yes
checking for getpid... yes
checking for gmtime_r... yes
checking for lldiv... yes
checking for localtime_r... yes
checking for nrand48... yes
checking for poll... yes
checking for posix_memalign... yes
checking for rewind... yes
checking for setenv... yes
checking for strcasecmp... yes
checking for strcasestr... yes
checking for strdup... yes
checking for strlcpy... no
checking for strndup... yes
checking for strnlen... yes
checking for strsep... yes
checking for strtof... yes
checking for strtok_r... yes
checking for strtoll... yes
checking for swab... yes
checking for tdestroy... yes
checking for strverscmp... yes
checking for fdatasync... yes
checking for static_assert in assert.h... yes
checking for working strcoll... yes
checking for accept4... yes
checking for pipe2... yes
checking for eventfd... yes
checking for vmsplice... yes
checking for sched_getaffinity... yes
checking for struct pollfd... yes
checking for library containing connect... none required
checking for library containing inet_pton... none required
checking for if_nameindex... yes
checking for if_nametoindex... yes
checking for socklen_t in sys/socket.h... yes
checking for struct sockaddr_storage... yes
checking for getopt_long... yes
checking for cos in -lm... yes
checking for lrintf in -lm... yes
checking for library containing dlopen... -ldl
checking for library containing pthread_rwlock_init... -lpthread
checking for clock_nanosleep in -lrt... yes
checking search.h usability... yes
checking search.h presence... yes
checking for search.h... yes
checking getopt.h usability... yes
checking getopt.h presence... yes
checking for getopt.h... yes
checking locale.h usability... yes
checking locale.h presence... yes
checking for locale.h... yes
checking xlocale.h usability... yes
checking xlocale.h presence... yes
checking for xlocale.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking netinet/udplite.h usability... no
checking netinet/udplite.h presence... no
checking for netinet/udplite.h... no
checking sys/eventfd.h usability... yes
checking sys/eventfd.h presence... yes
checking for sys/eventfd.h... yes
checking for net/if.h... yes
checking for sys/mount.h... yes
checking machine/param.h usability... no
checking machine/param.h presence... no
checking for machine/param.h... no
checking sys/shm.h usability... yes
checking sys/shm.h presence... yes
checking for sys/shm.h... yes
checking linux/version.h usability... yes
checking linux/version.h presence... yes
checking for linux/version.h... yes
checking linux/dccp.h usability... yes
checking linux/dccp.h presence... yes
checking for linux/dccp.h... yes
checking scsi/scsi.h usability... yes
checking scsi/scsi.h presence... yes
checking for scsi/scsi.h... yes
checking linux/magic.h usability... yes
checking linux/magic.h presence... yes
checking for linux/magic.h... yes
checking syslog.h usability... yes
checking syslog.h presence... yes
checking for syslog.h... yes
checking mntent.h usability... yes
checking mntent.h presence... yes
checking for mntent.h... yes
checking for ssize_t... yes
checking pthread.h usability... yes
checking pthread.h presence... yes
checking for pthread.h... yes
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking zlib.h usability... yes
checking zlib.h presence... yes
checking for zlib.h... yes
checking for MINIZIP... no
checking unzip.h usability... no
checking unzip.h presence... no
checking for unzip.h... no
checking for IDN... yes
checking for DBUS... yes
checking for ntohl in sys/param.h... no
checking if gcc -std=gnu99 accepts -Wall... yes
checking if gcc -std=gnu99 accepts -Wextra... yes
checking if gcc -std=gnu99 accepts -Wsign-compare... yes
checking if gcc -std=gnu99 accepts -Wundef... yes
checking if gcc -std=gnu99 accepts -Wpointer-arith... yes
checking if gcc -std=gnu99 accepts -Wbad-function-cast... yes
checking if gcc -std=gnu99 accepts -Wwrite-strings... yes
checking if gcc -std=gnu99 accepts -Wmissing-prototypes... yes
checking if gcc -std=gnu99 accepts -Wvolatile-register-var... yes
checking if gcc -std=gnu99 accepts -Werror-implicit-function-declaration... yes
checking if gcc -std=gnu99 accepts -pipe... yes
checking if g++ accepts -Wall... yes
checking if g++ accepts -Wextra... yes
checking if g++ accepts -Wsign-compare... yes
checking if g++ accepts -Wundef... yes
checking if g++ accepts -Wpointer-arith... yes
checking if g++ accepts -Wvolatile-register-var... yes
checking if gcc -std=gnu99 accepts -fvisibility=hidden... yes
checking if gcc -std=gnu99 accepts -O4... yes
checking if gcc -std=gnu99 accepts -ffast-math... yes
checking if gcc -std=gnu99 accepts -funroll-loops... yes
checking if gcc -std=gnu99 accepts -fomit-frame-pointer... yes
checking if linker supports -Bsymbolic... -Wl,-Bsymbolic
checking __attribute__ ((aligned ())) support... 64
checking for __attribute__((packed))... yes
checking execinfo.h usability... yes
checking execinfo.h presence... yes
checking for execinfo.h... yes
checking for backtrace... yes
checking if gcc -std=gnu99 groks 3D Now! inline assembly... no
checking for LUA... yes
checking for luac... /usr/bin/luac
checking for LIVE555... yes
checking for DC1394... yes
checking for DV1394... yes
checking for LINSYS_SDI... yes
checking for DVDREAD... yes
checking for DVDNAV... yes
checking for dvdnav_stream_cb in dvdnav/dvdnav.h... no
checking for BLURAY... yes
checking for OPENCV... yes
checking for SMBCLIENT... yes
checking for SFTP... yes
checking linux/videodev2.h usability... yes
checking linux/videodev2.h presence... yes
checking for linux/videodev2.h... yes
checking sys/videoio.h usability... no
checking sys/videoio.h presence... no
checking for sys/videoio.h... no
checking DeckLinkAPIDispatch.cpp usability... no
checking DeckLinkAPIDispatch.cpp presence... no
checking for DeckLinkAPIDispatch.cpp... no
configure: WARNING: Blackmagic DeckLink SDI include files not found
checking for GNOMEVFS... yes
checking for cdrom_msf0 in linux/cdrom.h... yes
checking for scsireq in sys/scsiio.h... no
checking for ioc_toc_header in sys/cdio.h... no
checking for LIBCDDB... yes
checking for Linux DVB version 5.1... yes
checking for VNC... yes
checking for FREERDP... yes
checking for ASDCP... no
checking for DVBPSI... yes
checking gme/gme.h usability... yes
checking gme/gme.h presence... yes
checking for gme/gme.h... yes
checking for SID... yes
checking sidplay/builders/resid.h usability... yes
checking sidplay/builders/resid.h presence... yes
checking for sidplay/builders/resid.h... yes
checking for OGG... yes
checking for LIBVORBIS... yes
checking for MUX_OGG... yes
checking for SHOUT... yes
checking ebml/EbmlVersion.h usability... yes
checking ebml/EbmlVersion.h presence... yes
checking for ebml/EbmlVersion.h... yes
checking for libebml version >= 1.0.0... yes
checking matroska/KaxVersion.h usability... yes
checking matroska/KaxVersion.h presence... yes
checking for matroska/KaxVersion.h... yes
checking for libmatroska version >= 1.0.0... yes
checking matroska/KaxAttachments.h usability... yes
checking matroska/KaxAttachments.h presence... yes
checking for matroska/KaxAttachments.h... yes
checking for main in -lebml_pic... no
checking for main in -lebml... yes
checking for LIBMODPLUG... yes
checking mpc/mpcdec.h usability... yes
checking mpc/mpcdec.h presence... yes
checking for mpc/mpcdec.h... yes
checking for SHINE... yes
checking for libcrystalhd/libcrystalhd_if.h... no
checking mad.h usability... yes
checking mad.h presence... yes
checking for mad.h... yes
checking for mad_bit_init in -lmad... yes
checking for libavutil variant... libav
checking for GST_APP... yes
checking for GST_VIDEO... yes
checking for AVCODEC... yes
checking libavcodec/avcodec.h usability... yes
checking libavcodec/avcodec.h presence... yes
checking for libavcodec/avcodec.h... yes
checking libavutil/avutil.h usability... yes
checking libavutil/avutil.h presence... yes
checking for libavutil/avutil.h... yes
checking for LIBVA_DRM... yes
checking for LIBVA_X11... yes
checking libavcodec/vaapi.h usability... yes
checking libavcodec/vaapi.h presence... yes
checking for libavcodec/vaapi.h... yes
configure: VA API acceleration activated
checking for AVFORMAT... yes
checking libavformat/avformat.h usability... yes
checking libavformat/avformat.h presence... yes
checking for libavformat/avformat.h... yes
checking libavformat/avio.h usability... yes
checking libavformat/avio.h presence... yes
checking for libavformat/avio.h... yes
checking for libavcodec/avcodec.h... (cached) yes
checking for libavutil/avutil.h... (cached) yes
checking for SWSCALE... yes
checking libswscale/swscale.h usability... yes
checking libswscale/swscale.h presence... yes
checking for libswscale/swscale.h... yes
checking for POSTPROC... no
configure: WARNING: No package 'libpostproc' found.
checking faad.h usability... yes
checking faad.h presence... yes
checking for faad.h... yes
checking for faacDecOpen in -lfaad... no
checking for NeAACDecOpen in -lfaad... yes
checking for VPX... no
checking for TWOLAME... yes
checking a52dec/a52.h usability... yes
checking a52dec/a52.h presence... yes
checking for a52dec/a52.h... yes
checking for a52_free in -la52... yes
checking for DCA... yes
checking for FLAC... yes
checking for LIBMPEG2... yes
checking for VORBIS... yes
checking for SPEEX... yes
checking for SPEEXDSP... yes
checking for OPUS... yes
checking for THEORA... yes
checking for SCHROEDINGER... yes
checking png.h usability... yes
checking png.h presence... yes
checking for png.h... yes
checking for png_set_rows in -lpng... yes
checking jpeglib.h usability... yes
checking jpeglib.h presence... yes
checking for jpeglib.h... yes
checking for X262... no
checking for X265... no
configure: WARNING: Library x265 needed for x265 was not found
checking for X26410B... no
checking for X264... yes
checking for MFX... no
configure: WARNING: Library libmfx needed for mfx was not found
checking for FLUIDSYNTH... yes
checking for ZVBI... yes
checking for LIBASS... yes
checking fontconfig/fontconfig.h usability... yes
checking fontconfig/fontconfig.h presence... yes
checking for fontconfig/fontconfig.h... yes
checking for KATE... yes
checking for TIGER... no
checking for EGL... yes
checking for GL... yes
checking for GLES2... yes
checking for GLES1... yes
checking for X... libraries , headers
checking for gethostbyname... yes
checking for connect... yes
checking for remove... yes
checking for shmat... yes
checking for IceConnectionNumber in -lICE... yes
checking X11/Xlib.h usability... yes
checking X11/Xlib.h presence... yes
checking for X11/Xlib.h... yes
checking for XCB... yes
checking for XCB_SHM... yes
checking for XCB_COMPOSITE... yes
checking for XPROTO... yes
checking for XCB_XV... yes
checking for XCB_RANDR... yes
checking for XCB_KEYSYMS... yes
checking for VDPAU... yes
configure: VDPAU decoding acceleration activated
checking for SDL... yes
checking for SDL_IMAGE... yes
checking for FREETYPE... yes
checking Carbon/Carbon.h usability... no
checking Carbon/Carbon.h presence... no
checking for Carbon/Carbon.h... no
checking for fontconfig/fontconfig.h... (cached) yes
checking for FRIBIDI... yes
checking for SVG... yes
checking for SVGDEC... yes
checking linux/fb.h usability... yes
checking linux/fb.h presence... yes
checking for linux/fb.h... yes
checking for CACA... yes
checking kva.h usability... no
checking kva.h presence... no
checking for kva.h... no
checking for PULSE... yes
checking for ALSA... yes
checking sndio.h usability... no
checking sndio.h presence... no
checking for sndio.h... no
checking audioclient.h usability... no
checking audioclient.h presence... no
checking for audioclient.h... no
checking for JACK... no
configure: WARNING: Requested 'jack >= 1.9.7' but version of jack is 0.124.1, trying jack1 instead
checking for JACK... yes
checking for SAMPLERATE... yes
checking kai.h usability... no
checking kai.h presence... no
checking for kai.h... no
checking for CHROMAPRINT... yes
checking for QT... no
checking for QT... yes
checking for moc-qt4... /usr/bin/moc-qt4
checking for rcc... /usr/bin/rcc
checking for uic-qt4... /usr/bin/uic-qt4
checking whether Qt uses Xlib... yes
checking for XPM... yes
checking for XINERAMA... yes
checking for XEXT... yes
checking libtar.h usability... yes
checking libtar.h presence... yes
checking for libtar.h... yes
checking for NCURSES... yes
checking for GOOM... no
configure: WARNING: Library libgoom2 needed for goom was not found
checking for PROJECTM... yes
checking for VSXU... no
configure: WARNING: No package 'libvsxu' found.
checking for BONJOUR... yes
checking for UDEV... yes
checking for MTP... yes
checking for UPNP... yes
checking for LIBXML2... yes
checking whether GCRYCTL_SET_THREAD_CBS is declared... yes
checking for gcry_control in -lgcrypt... yes
checking for GNUTLS... yes
checking for TAGLIB... yes
checking for NOTIFY... yes
checking whether byte ordering is bigendian... no
./configure: line 52737: kde4-config: command not found
checking that generated files are newer than configure... done
configure: creating ./config.status
config.status: creating Makefile
config.status: creating doc/Makefile
config.status: creating modules/Makefile
config.status: creating m4/Makefile
config.status: creating po/Makefile.in
config.status: creating share/Makefile
config.status: creating compat/Makefile
config.status: creating src/Makefile
config.status: creating lib/Makefile
config.status: creating bin/Makefile
config.status: creating test/Makefile
config.status: creating modules/access_output/Makefile
config.status: creating modules/audio_filter/Makefile
config.status: creating modules/control/Makefile
config.status: creating modules/gui/Makefile
config.status: creating modules/gui/ios_dialog_provider/Makefile
config.status: creating modules/gui/macosx/Makefile
config.status: creating modules/gui/minimal_macosx/Makefile
config.status: creating modules/gui/macosx_dialog_provider/Makefile
config.status: creating modules/gui/qt4/Makefile
config.status: creating modules/gui/skins2/Makefile
config.status: creating modules/misc/Makefile
config.status: creating modules/mux/Makefile
config.status: creating modules/packetizer/Makefile
config.status: creating modules/stream_out/Makefile
config.status: creating modules/text_renderer/Makefile
config.status: creating modules/video_filter/Makefile
config.status: creating modules/video_output/Makefile
config.status: creating modules/visualization/Makefile
config.status: creating modules/hw/vdpau/Makefile
config.status: creating config.h
config.status: config.h is unchanged
config.status: executing depfiles commands
config.status: executing libtool commands
config.status: executing po-directories commands
config.status: creating po/POTFILES
libvlc configuration
version               : 2.2.2
system                : linux
architecture          : armv7l
optimizations         : yes
vlc aliases           : cvlc rvlc qvlc svlc nvlc
cjan
Thu May 05, 2016 4:46 am
if anyone need rebuild, 2.2.3 is out, btw.
gkreidl
Thu May 05, 2016 9:20 am
cjan wrote:if anyone need rebuild, 2.2.3 is out, btw.
It can be built with the same instructions as in the OP. I'll edit it now.
MMAL must stay disabled because it crashes everything. OpenMax IL is the only working HW acceleration. SD video and some 720p video can also be played with SDL output (RPi3), using software codecs.
Knoose
Sun May 08, 2016 10:06 am
Hello there,
This compile is truly awesome! All is working well except for one thing.
Whenever is start a video which does not use the full screen, I can still see the desktop in background.
Now, with OMXPlayer you could solve this with "-b". Is there a way for the HW accelerated VLC to do the same?
Thanks and best,
Knoose
gkreidl
Sun May 08, 2016 2:31 pm
Knoose wrote:Hello there,
Thanks and best,
Knoose
Unfortunately not :-(
Knoose
Sun May 08, 2016 4:41 pm
Hello gkreidl,
Thank you for your reply. Although it is not the news I was hoping for. So I just have to wait until this will be fixed.
In the meantime have a small workaround for anyone interested :) :
I turned off "use same wallpaper on all desktops" and created a second desktop with a black image as background.
Afterwards I set the taskbar settings to dissappear when unused effectively giving me a black background.
So whenever I want to watch a movie I use the second desktop and it works fine. You can even call on the VLC GUI and its controls.
Best,
Knoose
sheldor_sq
Tue Jun 14, 2016 2:37 pm
csdrbh wrote:I double checked the Video Output and it was set to OpenMax IL
have a nice day ;)
Any other ideas??
i had quite the same problem, only .avi files seemed to work. i figured out the problem though. it appeared that i had 2 versions of VLC installed, and the default executable was the one that couldn't manage any other format than *.avi; after starting up vlc-2.2.2/cvlc it all works fine, including network streams, and remote control (via VLC remote on android)
maybe this helps you ;)
Limo
Sun Jun 19, 2016 4:26 pm
Hi guys,
Did anyone manage to use livestreamer with VLC and the new OpenGL beta drivers ?
When I try to launch a stream I get a black screen (not only in VLC but the whole screen). Screen comes back when I alt+F4 VLC.
I really hope one day this driver will work fine, because OpenMAX video output... you know... meh.
gkreidl
Sun Jun 19, 2016 5:41 pm
Limo wrote:Hi guys,
The OpenGL driver does not include video decoding. OpenMax or MMAL are still required. At the moment the OpenGL driver keeps them from working, so HW video decoding doesn't work at all.
Limo
Sun Jun 19, 2016 9:05 pm
gkreidl wrote:The OpenGL driver does not include video decoding. OpenMax or MMAL are still required. At the moment the OpenGL driver keeps them from working, so HW video decoding does work at all.
Ok, thanks for the reply, I didn't know that.
Is it planned to add this feature for the OpenGL driver in the future ?
gkreidl
Mon Jun 20, 2016 5:31 am
No, It's not part of the OpenGL specification.
alnaseh
Fri Jun 24, 2016 2:13 am
i have tried it with the latest vlc 3.0.0 git code and it is compiled without issues. on the other hand, it starts throwing errors messages everywhere:
core stream error: unknown query in demux_vaControlDefault
it might be related to the VLC code since it is not stable.
gkreidl
Fri Jun 24, 2016 4:06 am
alnaseh wrote:i have tried it with the latest vlc 3.0.0 git code and it is compiled without issues. on the other hand, it starts throwing errors messages everywhere:
Before I compiled the 2.2.2 and later the 2.2.3 version I also tried the 3.0 versions: no chance, all the RPi related things (both omx and MMAL support) were terribly broken.
cjan
Tue Jul 05, 2016 1:20 am
does P3 play 1920×1080.mp4 on vlc-openmax?
gkreidl
Tue Jul 05, 2016 5:47 am
cjan wrote:does P3 play 1920×1080.mp4 on vlc-openmax?
Yes.
k3noni
Thu Jul 07, 2016 10:06 am
Thanks and best,
Knoose
Actually you can, just below where you specify openmax IL in video options (Force Aspect Ratio) you can specify the scale just set it to "16:9" and the image will always be scaled so it fits the entire screen.
k3noni
Mon Jul 25, 2016 7:55 am
Keep getting this error in vlc (after updating the system yesterday).
"double free or corruption (out)"
It only occurs when pressing stop, next or prev buttons - either on the remote or in the app itself.
I did a full recompile - didn`t help
Any suggestions ?
gkreidl
Mon Jul 25, 2016 9:05 am
k3noni wrote:Keep getting this error in vlc (after updating the system yesterday).
Any suggestions ?
Did you receive an update of any VLC package? This shouldn't happen, but maybe you did not un-install a VLC version from the repository before installing the compiled version.
k3noni
Mon Jul 25, 2016 12:23 pm
Any suggestions ?
I did
make uninstall.
deleted the old src folder
compiled everything again from scratch
and did a "make install" with the new compilation.
also did a "apt-get remove vlc" before compilation.
It`s strange that even if i do "sudo apt-get install vlc" and run vlc bash says "command not found" :)
How do i check if there are wrong vlc packages?
gkreidl
Mon Jul 25, 2016 2:17 pm
VLC consists of more than one package. Install synaptic, start it with "gksudo synaptic" and search for "vlc". This will show you, if you still have any VLC packages installed.
Return to “Raspbian”
