gkreidl
Re: Compile VLC with HW acceleration - complete tutorial
Mon Jan 06, 2014 8:02 pm
mikerccs wrote:Ok, everyone just calm down and focus on solving my problem. :)
yes. :-)
use the debug info in the message window.
Minimal Kiosk Browser (kweb)
mikerccs
Mon Jan 06, 2014 8:29 pm
Here's what I see in the Module Tree tab after trying to open the stream:
libvlc (0x99f8f8)
interface "qt4" (0xa39128)
generic "lua" (0xb08d50)
interface "dbus" (0xa2ef58)
interface "xcb_hotkeys" (0xa36c80)
interface "hotkeys" (0xa37db0)
playlist (0x9af4f8)
audio output "alsa" (0xa4b380)
mikerccs
Mon Jan 13, 2014 4:21 pm
Does the info I posted above indicate what the problem might be playing this stream?
mikerccs
Thu Jan 16, 2014 4:38 pm
I'm still looking for a solution to this. Any idea why I can't play this particular video stream with this version of VLC?
mikerccs
Thu Jan 16, 2014 4:57 pm
I figured out how to get the debug info out of the VLC. Here it is:
core error: open of `rtsp://192.168.1.205:8557/PSIA/Streaming/channels/2?videoCodecType=H.264' failed
core debug: adding item `rtsp://192.168.1.205:8557/PSIA/Streaming/channels/2?videoCodecType=H.264' ( rtsp://192.168.1.205:8557/PSIA/Streaming/channels/2?videoCodecType=H.264 )
core debug: processing request item: rtsp://192.168.1.205:8557/PSIA/Streaming/channels/2?videoCodecType=H.264, node: null, skip: 0
core debug: rebuilding array of current - root Playlist
core debug: rebuild done - 5 items, index 4
core debug: starting playback of the new playlist item
core debug: resyncing on rtsp://192.168.1.205:8557/PSIA/Streaming/channels/2?videoCodecType=H.264
core debug: rtsp://192.168.1.205:8557/PSIA/Streaming/channels/2?videoCodecType=H.264 is at 4
core debug: creating new input thread
core debug: Creating an input for 'rtsp://192.168.1.205:8557/PSIA/Streaming/channels/2?videoCodecType=H.264'
qt4 debug: Adding a new MRL to recent ones: rtsp://192.168.1.205:8557/PSIA/Streaming/channels/2?videoCodecType=H.264
core debug: using timeshift granularity of 50 MiB, in path '/tmp'
core debug: no fetch required for (null) (art currently (null))
core debug: `rtsp://192.168.1.205:8557/PSIA/Streaming/channels/2?videoCodecType=H.264' gives access `rtsp' demux `' path `192.168.1.205:8557/PSIA/Streaming/channels/2?videoCodecType=H.264'
core debug: creating demux: access='rtsp' demux='' location='192.168.1.205:8557/PSIA/Streaming/channels/2?videoCodecType=H.264' file='(null)'
core debug: looking for access_demux module matching "rtsp": 18 candidates
core debug: no access_demux modules matched
core debug: creating access 'rtsp' location='192.168.1.205:8557/PSIA/Streaming/channels/2?videoCodecType=H.264', path='(null)'
core debug: looking for access module matching "rtsp": 21 candidates
core debug: no access modules matched
core debug: finished input
core debug: dead input
core debug: changing item without a request (current 4/5)
core debug: nothing to play
gkreidl
Thu Jan 16, 2014 5:51 pm
That gives a hint. Try reconfiguring and compiling with these options:
./configure --prefix=/usr --enable-rpi-omxil --disable-ogg --disable-mux_ogg  --enable-realrtsp
realrtsp is disabled by default.
mikerccs
Thu Jan 16, 2014 7:40 pm
Thanks very much. Seems like we are getting close to getting this working. I'm getting an error when I run that config command though:
configure: error: invalid feature name: mux_ogg
I don't think I received this error previously.
Thanks!
gkreidl
Thu Jan 16, 2014 9:07 pm
Maybe you have a newer version. In my config file it's included.
Try without that option, but maybe you'll get a compiler error later on. This error was the reason why I excluded the ogg support (partially).
mikerccs
Fri Jan 17, 2014 5:13 pm
Looks like I'm still getting he same error and debug info. Any other ideas what might be causing this?
core debug: rebuild done - 1 items, index 0
core debug: rtsp://192.168.1.205:8557/PSIA/Streaming/channels/2?videoCodecType=H.264 is at 0
core debug: changing item without a request (current 0/1)
microwavesafe
Tue Jun 10, 2014 8:05 am
I have tried to follow your tutorial, but I can't seem to get it to do anything.
When I run the following command
vlc --vout moxil_vout big_buck_bunny_480p_h264.mov
I just get
core error: video output creation failed
core error: failed to create video output
If I try a network camera feed I get an error
core decoder error: corrupt module: /usr/lib/vlc/plugins/codec/libavcodec_plugin.so
the library is there. I should point out that I'm trying to run this without X. I need to be able to run this from the command line and omxplayer does not work with the network camera I'm trying to use.
I followed two different tutorials from scratch now with the same result. Is there something in the latest Raspbian firmware that's screwing this up? Does anyone have any ideas of what's going wrong. The log file doesn't seem to be giving much away.
gkreidl
Tue Jun 10, 2014 8:39 am
My version, which I compiled 7 months ago is still working and I have always the latest firmware and linux kernel (through rpi-update). So, no: it's not a question of RPi firmware or OS.
Perhaps you should try one of the interface versions first. nvlc runs without X. vlc itself, without setting the interface in the command line, tries to run the QT version.
microwavesafe
Tue Jun 10, 2014 8:55 am
Ah, thanks for the tip, that's what I'm missing. Running the same command, but with nvlc
nvlc --vout moxil_vout big_buck_bunny_480p_h264.mov
I now get a nice ncurses screen showing me that the video is playing, including a progress bar, but alas no video output. Is it behind the ncurses screen? Do I have to specify the render layer? I've checked all the other virtual terminals just in case, but nothing there. Maybe it doesn't work without X?
I've just tried
--no-xlib --fullscreen --video-on-top
options, but they haven't worked. Has anyone got VLC to play on a terminal only?
gkreidl
Tue Jun 10, 2014 9:20 am
I can play any kind of media with nvlc directly from the command line.
You should boot into the full X QT version once and modify the settings as described in my OP. They will be saved and also used with nvlc.
microwavesafe
Tue Jun 10, 2014 9:34 am
OK so I'm guessing something else has gone wrong. In X it doesn't even play big_buck_bunny, after changing the settings to OpenMax. So I think I'm going to start again and go through the steps more carefully.
microwavesafe
Tue Jun 10, 2014 4:51 pm
So I started again from scratch and followed the tutorial exactly (cut and paste all commands). Only thing I did to begin with was
sudo apt-get update
sudo apt-get upgrade
out of habit more than anything. I then made the settings changes you mention and downloaded this file
http://mirrorblender.top-ix.org/peach/b ... p_h264.mov
In X, this crashes VLC, in the terminal using nvlc it does the same as before, ncurses screen comes up but nothing else. The stream from the camera also fails to load with the same error as before
Any ideas? I would literally put money in to see this made into a package for Raspbian! Maybe the source code from the VLC git is no longer working?
gkreidl
Tue Jun 10, 2014 5:06 pm
The only difference I can see is that I compiled my version in November, so it was not the current one. And I was not the only one getting it to work.
microwavesafe
Tue Jun 10, 2014 5:16 pm
I think your right. Do you have the git hash that you checked out by any chance?
gkreidl
Tue Jun 10, 2014 5:41 pm
microwavesafe wrote:I think your right. Do you have the git hash that you checked out by any chance?
No, only hint I have is that I compiled it around Nov., 1st.
I never updated my git source afterwards.
gkreidl
Fri Jul 18, 2014 9:48 am
The MAKE file is created by boootstrap/configure. Did you get any errors when running those scripts?
realies
Fri Jul 18, 2014 9:51 am
I thought nothing crucial was mistaken... to be honest I'm new and sorry for the effort to help me, but I'm not sure, so here's my log:
pi@raspberrypi ~ $ cd vlc
pi@raspberrypi ~/vlc $ export ACLOCAL_ARGS="-I /usr/share/aclocal"
pi@raspberrypi ~/vlc $ ./bootstrap
NOTE: GNU gettext appears to be missing or out-of-date.
Please install or update GNU gettext.
Also check if you have cvs, a dependency of autopoint.
Otherwise, you will not be able to build a source tarball.
generating modules/**/Makefile.am
+ autoreconf --install --force --verbose -I m4 -I /usr/share/aclocal
autoreconf: Entering directory `.'
autoreconf: running: true --force
autoreconf: running: aclocal -I m4 -I /usr/share/aclocal --force -I m4
autoreconf: configure.ac: tracing
autoreconf: running: libtoolize --copy --force
libtoolize: putting auxiliary files in AC_CONFIG_AUX_DIR, `autotools'.
libtoolize: copying file `autotools/ltmain.sh'
libtoolize: putting macros in AC_CONFIG_MACRO_DIR, `m4'.
libtoolize: copying file `m4/libtool.m4'
libtoolize: copying file `m4/ltoptions.m4'
libtoolize: copying file `m4/ltsugar.m4'
libtoolize: copying file `m4/ltversion.m4'
libtoolize: copying file `m4/lt~obsolete.m4'
autoreconf: running: /usr/bin/autoconf --include=m4 --include=/usr/share/aclocal --force
autoreconf: running: /usr/bin/autoheader --include=m4 --include=/usr/share/aclocal --force
autoreconf: running: automake --add-missing --copy --force-missing
configure.ac:64: installing `autotools/compile'
configure.ac:23: installing `autotools/config.guess'
configure.ac:23: installing `autotools/config.sub'
configure.ac:27: installing `autotools/install-sh'
configure.ac:27: installing `autotools/missing'
bin/Makefile.am: installing `autotools/depcomp'
autoreconf: Leaving directory `.'
+ rm -f po/Makevars.template
+ rm -f stamp-h*
+ set +x
Successfully bootstrapped
pi@raspberrypi ~/vlc $ ./configure --prefix=/usr --enable-rpi-omxil --disable-ogg --disable-mux_ogg
checking build system type... armv6l-unknown-linux-gnueabihf
checking host system type... armv6l-unknown-linux-gnueabihf
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking how to create a ustar tar archive... gnutar
checking whether make supports nested variables... yes
checking whether to enable maintainer-specific portions of Makefiles... yes
checking for style of include used by make... GNU
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking dependency style of gcc... gcc3
checking for gcc option to accept ISO C99... -std=gnu99
checking how to run the C preprocessor... gcc -std=gnu99 -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking minix/config.h usability... no
checking minix/config.h presence... no
checking for minix/config.h... no
checking whether it is safe to define __EXTENSIONS__... yes
checking whether gcc -std=gnu99 and cc understand -c and -o together... yes
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking whether we are using the GNU Objective C compiler... no
checking whether gcc accepts -g... no
checking dependency style of gcc... (cached) gcc3
checking for egrep... (cached) /bin/grep -E
checking whether make sets $(MAKE)... (cached) yes
checking dependency style of gcc -std=gnu99... gcc3
checking for desktop-file-validate... desktop-file-validate
checking for yasm... no
checking for an ANSI C-conforming const... yes
checking for inline... inline
checking for C/C++ restrict keyword... __restrict
checking for an Android system... no
checking for 3rd party libraries path... not found
checking how to print strings... printf
checking for a sed that does not truncate output... /bin/sed
checking for fgrep... /bin/grep -F
checking for ld used by gcc -std=gnu99... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking how to convert armv6l-unknown-linux-gnueabihf file names to armv6l-unknown-linux-gnueabihf format... func_convert_file_noop
checking how to convert armv6l-unknown-linux-gnueabihf file names to toolchain format... func_convert_file_noop
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... (cached) pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for ar... ar
checking for archiver @FILE support... @
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc -std=gnu99 object... ok
checking for sysroot... no
checking for mt... mt
checking if mt is a manifest tool... no
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc -std=gnu99 supports -fno-rtti -fno-exceptions... no
checking for gcc -std=gnu99 option to produce PIC... -fPIC -DPIC
checking if gcc -std=gnu99 PIC flag -fPIC -DPIC works... yes
checking if gcc -std=gnu99 static flag -static works... yes
checking if gcc -std=gnu99 supports -c -o file.o... yes
checking if gcc -std=gnu99 supports -c -o file.o... (cached) yes
checking whether the gcc -std=gnu99 linker (/usr/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking for shl_load... no
checking for shl_load in -ldld... no
checking for dlopen... no
checking for dlopen in -ldl... yes
checking whether a program can dlopen itself... yes
checking whether a statically linked program can dlopen itself... no
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
checking how to run the C++ preprocessor... g++ -E
checking for ld used by g++... /usr/bin/ld
checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC -DPIC
checking if g++ PIC flag -fPIC -DPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
checking if g++ supports -c -o file.o... (cached) yes
checking dynamic linker characteristics... (cached) GNU/Linux ld.so
checking for windres... no
checking for bash... /bin/bash
checking if dolt supports this host... yes, replacing libtool
checking whether NLS is requested... yes
checking for msgfmt... /usr/bin/msgfmt
checking for gmsgfmt... /usr/bin/msgfmt
checking for xgettext... /usr/bin/xgettext
checking for msgmerge... /usr/bin/msgmerge
checking for shared library run path origin... done
checking for CFPreferencesCopyAppValue... no
checking for CFLocaleCopyCurrent... no
checking for GNU gettext in libc... yes
checking whether to use NLS... yes
checking where the gettext function comes from... libc
checking for iconv... yes
checking for working iconv... yes
checking for iconv declaration...
         extern size_t iconv (iconv_t cd, char * *inbuf, size_t *inbytesleft, char * *outbuf, size_t *outbytesleft);
checking for buggy GNU/libc versions... not present
checking for shared objects suffix... .so
checking whether nanosleep is declared... yes
checking for daemon... yes
checking for fcntl... yes
checking for fstatvfs... yes
checking for fork... yes
checking for getenv... yes
checking for getpwuid_r... yes
checking for isatty... yes
checking for lstat... yes
checking for memalign... yes
checking for mmap... yes
checking for openat... yes
checking for pread... yes
checking for posix_fadvise... yes
checking for posix_madvise... yes
checking for setlocale... yes
checking for stricmp... no
checking for strnicmp... no
checking for strptime... yes
checking for uselocale... yes
checking for atof... yes
checking for atoll... yes
checking for dirfd... yes
checking for fdopendir... yes
checking for flockfile... yes
checking for fsync... yes
checking for getdelim... yes
checking for getpid... yes
checking for gmtime_r... yes
checking for lldiv... yes
checking for localtime_r... yes
checking for nrand48... yes
checking for poll... yes
checking for posix_memalign... yes
checking for rewind... yes
checking for setenv... yes
checking for strcasecmp... yes
checking for strcasestr... yes
checking for strdup... yes
checking for strlcpy... no
checking for strndup... yes
checking for strnlen... yes
checking for strsep... yes
checking for strtof... yes
checking for strtok_r... yes
checking for strtoll... yes
checking for swab... yes
checking for tdestroy... yes
checking for strverscmp... yes
checking for fdatasync... yes
checking for static_assert in assert.h... no
checking for working strcoll... yes
checking for accept4... yes
checking for pipe2... yes
checking for eventfd... yes
checking for vmsplice... yes
checking for sched_getaffinity... yes
checking for struct pollfd... yes
checking for library containing connect... none required
checking for library containing inet_pton... none required
checking for if_nameindex... yes
checking for if_nametoindex... yes
checking for socklen_t in sys/socket.h... yes
checking for struct sockaddr_storage... yes
checking for getopt_long... yes
checking for cos in -lm... yes
checking for lrintf in -lm... yes
checking for library containing dlopen... -ldl
checking for library containing pthread_rwlock_init... -lpthread
checking for clock_nanosleep in -lrt... yes
checking search.h usability... yes
checking search.h presence... yes
checking for search.h... yes
checking getopt.h usability... yes
checking getopt.h presence... yes
checking for getopt.h... yes
checking locale.h usability... yes
checking locale.h presence... yes
checking for locale.h... yes
checking xlocale.h usability... yes
checking xlocale.h presence... yes
checking for xlocale.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking netinet/udplite.h usability... no
checking netinet/udplite.h presence... no
checking for netinet/udplite.h... no
checking sys/eventfd.h usability... yes
checking sys/eventfd.h presence... yes
checking for sys/eventfd.h... yes
checking for net/if.h... yes
checking for sys/mount.h... yes
checking machine/param.h usability... no
checking machine/param.h presence... no
checking for machine/param.h... no
checking sys/shm.h usability... yes
checking sys/shm.h presence... yes
checking for sys/shm.h... yes
checking linux/version.h usability... yes
checking linux/version.h presence... yes
checking for linux/version.h... yes
checking linux/dccp.h usability... yes
checking linux/dccp.h presence... yes
checking for linux/dccp.h... yes
checking scsi/scsi.h usability... yes
checking scsi/scsi.h presence... yes
checking for scsi/scsi.h... yes
checking linux/magic.h usability... yes
checking linux/magic.h presence... yes
checking for linux/magic.h... yes
checking syslog.h usability... yes
checking syslog.h presence... yes
checking for syslog.h... yes
checking mntent.h usability... yes
checking mntent.h presence... yes
checking for mntent.h... yes
checking for ssize_t... yes
checking pthread.h usability... yes
checking pthread.h presence... yes
checking for pthread.h... yes
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking zlib.h usability... yes
checking zlib.h presence... yes
checking for zlib.h... yes
checking for MINIZIP... no
checking unzip.h usability... no
checking unzip.h presence... no
checking for unzip.h... no
checking for IDN... no
checking for DBUS... yes
checking for ntohl in sys/param.h... no
checking if gcc -std=gnu99 accepts -Wall... yes
checking if gcc -std=gnu99 accepts -Wextra... yes
checking if gcc -std=gnu99 accepts -Wsign-compare... yes
checking if gcc -std=gnu99 accepts -Wundef... yes
checking if gcc -std=gnu99 accepts -Wpointer-arith... yes
checking if gcc -std=gnu99 accepts -Wbad-function-cast... yes
checking if gcc -std=gnu99 accepts -Wwrite-strings... yes
checking if gcc -std=gnu99 accepts -Wmissing-prototypes... yes
checking if gcc -std=gnu99 accepts -Wvolatile-register-var... yes
checking if gcc -std=gnu99 accepts -Werror-implicit-function-declaration... yes
checking if gcc -std=gnu99 accepts -pipe... yes
checking if g++ accepts -Wall... yes
checking if g++ accepts -Wextra... yes
checking if g++ accepts -Wsign-compare... yes
checking if g++ accepts -Wundef... yes
checking if g++ accepts -Wpointer-arith... yes
checking if g++ accepts -Wvolatile-register-var... yes
checking if gcc -std=gnu99 accepts -fvisibility=hidden... yes
checking if gcc -std=gnu99 accepts -ffast-math... yes
checking if gcc -std=gnu99 accepts -funroll-loops... yes
checking if gcc -std=gnu99 accepts -fomit-frame-pointer... yes
checking if linker supports -Bsymbolic... -Wl,-Bsymbolic
checking __attribute__ ((aligned ())) support... 64
checking for __attribute__((packed))... yes
checking execinfo.h usability... yes
checking execinfo.h presence... yes
checking for execinfo.h... yes
checking for backtrace... yes
checking if gcc -std=gnu99 groks 3D Now! inline assembly... no
checking for LUA... no
configure: WARNING: No package 'lua5.2' found, trying lua 5.1 instead
checking for LUA... yes
checking for luac... /usr/bin/luac
checking for LIVE555... no
configure: WARNING: No package 'live555' found.
checking for live555 version 1324598400 or later... no
configure: WARNING: live555 is missing or its installed version is too old:
Version 2011.12.23 or later is required to proceed.
You can get an updated one from http://www.live555.com/liveMedia .
checking for DC1394... yes
checking for DV1394... no
configure: WARNING: Library libraw1394 >= 2.0.1 libavc1394 >= 0.5.3 needed for dv1394 was not found
checking for LINSYS_SDI... yes
checking for DVDREAD... no
configure: WARNING: Library dvdread > 4.9.0 needed for dvdread was not found
checking for DVDNAV... no
configure: WARNING: Library dvdnav >= 4.2.1 needed for dvdnav was not found
checking for BLURAY... no
configure: WARNING: Library libbluray >= 0.3.0 needed for bluray was not found
checking for OPENCV... yes
checking for SMBCLIENT... no
configure: WARNING: Library smbclient needed for smbclient was not found
checking for DSM... no
configure: WARNING: Library libdsm needed for dsm was not found
checking for SFTP... yes
checking linux/videodev2.h usability... yes
checking linux/videodev2.h presence... yes
checking for linux/videodev2.h... yes
checking sys/videoio.h usability... no
checking sys/videoio.h presence... no
checking for sys/videoio.h... no
checking DeckLinkAPIDispatch.cpp usability... no
checking DeckLinkAPIDispatch.cpp presence... no
checking for DeckLinkAPIDispatch.cpp... no
configure: WARNING: Blackmagic DeckLink SDI include files not found
checking for GNOMEVFS... yes
checking for cdrom_msf0 in linux/cdrom.h... yes
checking for scsireq in sys/scsiio.h... no
checking for ioc_toc_header in sys/cdio.h... no
checking for LIBCDDB... yes
checking for Linux DVB version 5.1... yes
checking for VNC... no
configure: WARNING: Library libvncclient >= 0.9.9 needed for vnc was not found
checking for FREERDP... no
configure: WARNING: Library freerdp >= 1.0.1 needed for freerdp was not found
checking for ASDCP... no
checking for DVBPSI... yes
checking gme/gme.h usability... yes
checking gme/gme.h presence... yes
checking for gme/gme.h... yes
checking for SID... yes
checking sidplay/builders/resid.h usability... no
checking sidplay/builders/resid.h presence... no
checking for sidplay/builders/resid.h... no
configure: WARNING:  (required for sid).
checking for LIBVORBIS... yes
checking for SHOUT... yes
checking ebml/EbmlVersion.h usability... yes
checking ebml/EbmlVersion.h presence... yes
checking for ebml/EbmlVersion.h... yes
checking for libebml version >= 1.0.0... yes
checking matroska/KaxVersion.h usability... no
checking matroska/KaxVersion.h presence... no
checking for matroska/KaxVersion.h... no
checking for LIBMODPLUG... yes
checking mpc/mpcdec.h usability... yes
checking mpc/mpcdec.h presence... yes
checking for mpc/mpcdec.h... yes
checking for SHINE... no
configure: WARNING: Library shine >= 3.0.0 needed for shine was not found
checking interface/mmal/mmal.h usability... yes
checking interface/mmal/mmal.h presence... yes
checking for interface/mmal/mmal.h... yes
checking for bcm_host_init in -lbcm_host... yes
checking for libcrystalhd/libcrystalhd_if.h... no
checking mad.h usability... yes
checking mad.h presence... yes
checking for mad.h... yes
checking for mad_bit_init in -lmad... yes
checking for libavutil variant... libav
checking for GST_APP... no
configure: WARNING: No package 'gstreamer-app-1.0' found. GStreamer modules will not be built.
checking for AVCODEC... no
configure: error: Requested 'libavcodec >= 54.25.0' but version of libavcodec is 53.35.0
Requested 'libavutil >= 52.0.0' but version of libavutil is 51.22.2. Pass --disable-avcodec to ignore this error.
pi@raspberrypi ~/vlc $ make
make: *** No targets specified and no makefile found.  Stop.
I've been receiving this a couple of times when I tried installing it.
gkreidl
Fri Jul 18, 2014 12:12 pm
configure returns an error, because the current VLC version requires newer versions of libavcodec and libavutil.
The version I compiled was from (about) 20th October; the versions of libavcodec and libavutil required match the versions we have in Raspbian. You either have to compile newer versions or get an older version of vlc from vlc github.
realies
Fri Jul 18, 2014 12:49 pm
I just installed vlc using sudo apt-get install vlc. Is that not using the HW acceleration or would it be possible to modify it in order to have it running? I can see a pretty much more than 50% cpu usage when I play an mp3 file while running X.
gkreidl
Fri Jul 18, 2014 2:03 pm
realies wrote:I just installed vlc using sudo apt-get install vlc. Is that not using the HW acceleration or would it be possible to modify it in order to have it running? I can see a pretty much more than 50% cpu usage when I play an mp3 file while running X.
No hardware acceleration. But installing it first and then installing a newer version on top is the recommended way.
Joe Schmoe
Fri Jul 18, 2014 3:04 pm
Why can't they put the good one into the repository?
This thread has been going on for a long time - they should have gotten it working by now.
gkreidl
Fri Jul 18, 2014 3:30 pm
Joe Schmoe wrote:Why can't they put the good one into the repository?
This is the Debian stable release policy; you should know this by now. If you want newer versions, upgrade to Jessie.
Return to “Raspberry Pi OS”
