Radicale 0.8 is out!
Posted: Fri Sep 13, 2013 7:18 am
by ploc
http://radicale.org/news/
This brand new version of radicale offers some very interesting features :
  • New authentication and rights management modules
  • Experimental database storage
  • Command-line option for custom configuration file
  • Root URL not at the root of a domain
  • Improved support for iCal, CalDAVSync, CardDAVSync, CalDavZAP and CardDavMATE
  • Empty PROPFIND requests handled
  • Colon allowed in passwords
  • Configurable realm message
The new release has been packaged for Debian :
http://packages.debian.org/search?suite ... s=radicale
Do you think Radicale 0.8 could be packaged for raspbian also ?
Thanks for your answer.
Re: Radicale 0.8 is out!
Posted: Sat Sep 14, 2013 11:30 am
by xXAzazelXx
you could just install it with pip.
Posted: Sat Sep 14, 2013 11:45 am
by ploc
Yes, using pip is a good alternative.
But for those who like regular debian packages, a real debian package is better.
Posted: Sat Sep 14, 2013 12:12 pm
by plugwash
It's an arch all package so it should just work on raspbian. Indeed we may well have already pulled it into raspbian jessie.
Posted: Tue Sep 17, 2013 4:17 pm
by ploc
plugwash wrote:Indeed we may well have already pulled it into raspbian jessie.
It would be a very very very good idea.
Is it simple to do it ? When can it be done ?
Posted: Wed Oct 02, 2013 9:50 pm
by ploc
Is anyone reading this thread ?
Posted: Wed Oct 02, 2013 9:55 pm
by jaycuse
I'm following it. I'm interested in using radicale to replace google calendar.
Posted: Thu Oct 03, 2013 7:42 am
by ploc
I am writing a tutorial to simply install radicale and some user friendly front-end in order to replace Google Calendar.
But radicale 0.8 has some really interesting features that radicale 0.7 does not offer.
And having radicale 0.8 in raspbian repository makes it simple to install using apt-get, which a key to a wide adoption of radicale...
If any administrator of raspbian can read this...
Posted: Sun Oct 06, 2013 10:22 pm
by ploc
On this page, it is written :
Please feel free to get in touch through the forums if a package you require is missing. We can't guarantee to provide it but we should at least be able to explain why it is not available and may be able to suggest alternatives.
But unfortunately, it appears that no raspbian admin seem to be reading this post, nor answering it...
It is possible to please have an answer about radicale 0.8, which is a really more mature release of radicale than radicale 0.7 !
Posted: Sun Oct 06, 2013 10:49 pm
by plugwash
ploc wrote: But unfortunately, it appears that no raspbian admin seem to be reading this post, nor answering it...
I am a "raspbian admin"
There is a difference between "missing packages" and "packages that aren't the version you would preffer". The point of a stable release is to provide a stable consistent base that changes as little as possible. Not to provide the latest and greatest. So raspbian wheezy will for the most part* continue to have the same versions of packages it has now.
Raspbian jessie already has radicale 0.8 and has had it for ages.
* There are a handful of packages where debian pulls in new upstream versions to stable releases because they belive it is the only way to reasonablly do security support. I will also likely bring a newer mono version info raspbian wheezy at some point because the version curently there is basically unsusable.
Posted: Mon Oct 07, 2013 1:10 pm
by ploc
Thank you plugwash for your answer.
Can you explain me what you meant by the following sentence (I'm not good enough in english):
And do you mean with your last answer that raspbian is based on wheezy and will always be ?
Or is raspbian based on debian stable (and will then switch to jessie when it will become the next stable) ?
What is your advice if I really want to use radicale 0.8, what is the best way to install radicale 0.8 without breaking the basic raspbian ?
The reason I wanted to see radicale 0.8 added to raspbian repository is that it appears that radicale 0.8 is really more mature than radicale 0.7, which is a good reason to add to raspbian repository. My goal is to get sitcked on raspbian with minimum modifications to it, in order to make home servers with raspberries easier to install for non expert users...
Posted: Mon Oct 07, 2013 1:58 pm
by confuseling
You can already switch to Raspbian Jessie if you want, just change all occurrences of "wheezy" or "stable" in /etc/apt/sources.list (or sources.list.d) to "Jessie", then do an "apt-get dist-upgrade" or "aptitude full-upgrade".
It's called Testing for a reason though, and it might well break.
A better solution might be to try to backport it from Jessie's source.
http://forums.debian.net/viewtopic.php?f=16&t=38976
Debian (and therefore Raspbian) Stable is Stable *precisely* because it doesn't change any more than necessary to fix major bugs.
http://www.debian.org/doc/manuals/debia ... ng.en.html
