nevesagar
How to downgrade wheezy
Thu Aug 29, 2013 6:02 pm
I installed wheezy earlier...
Setup my rpi and everything was working as expected.
I also had the FM transmitter working.
However, I wanted to try some text-to-speech thing and i issued following two commands for that.
sudo apt-get update
sudo apt-get upgrade
The result was that my FM Transmitter ( P*** ) is _not_ working any more..
How can I downgrade the wheezy to get back my original state ?
Here is the log of what did these commands did:
$ sudo apt-get update
Hit http://raspberrypi.collabora.com wheezy Release.gpg
Get:1 http://archive.raspberrypi.org wheezy Release.gpg [490 B]
Hit http://raspberrypi.collabora.com wheezy/rpi armhf Packages
Get:2 http://mirrordirector.raspbian.org wheezy Release.gpg [490 B]
Get:3 http://archive.raspberrypi.org wheezy Release [7,215 B]
Get:4 http://mirrordirector.raspbian.org wheezy Release [14.4 kB]
Get:5 http://archive.raspberrypi.org wheezy/main armhf Packages [7,412 B]
Get:6 http://mirrordirector.raspbian.org wheezy/main armhf Packages [7,415 kB]
Ign http://raspberrypi.collabora.com wheezy/rpi Translation-en_GB
Ign http://archive.raspberrypi.org wheezy/main Translation-en_GB
Hit http://mirrordirector.raspbian.org wheezy/contrib armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/non-free armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/rpi armhf Packages
Ign http://mirrordirector.raspbian.org wheezy/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/rpi Translation-en_GB
100% [6 Packages bzip2 0 B]
Fetched 7,445 kB in 1min 58s (62.7 kB/s)
Reading package lists... Done
pi@raspberrypi ~/applications/P*** $
pi@raspberrypi ~/applications/P*** $ sudo apt-get upgrade
Building dependency tree
The following packages will be upgraded:
base-files gnupg gpgv libgcrypt11 libjack-jackd2-0 linux-libc-dev
6 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 3,457 kB of archives.
After this operation, 23.6 kB disk space will be freed.
Do you want to continue [Y/n]? Y
Get:1 http://archive.raspberrypi.org/debian/ wheezy/main libjack-jackd2-0 armhf 1.9.8~dfsg.4+20120529git007cdc37-5+rpi [184 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian/ wheezy/main base-files armhf 7.1wheezy1+rpi1 [81.1 kB]
Get:3 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libgcrypt11 armhf 1.5.0-5+deb7u1 [300 kB]
Get:4 http://mirrordirector.raspbian.org/raspbian/ wheezy/main gpgv armhf 1.4.12-7+deb7u1 [206 kB]
Get:5 http://mirrordirector.raspbian.org/raspbian/ wheezy/main gnupg armhf 1.4.12-7+deb7u1 [1,898 kB]
Get:6 http://mirrordirector.raspbian.org/raspbian/ wheezy/main linux-libc-dev armhf 3.2.46-1+rpi1 [788 kB]
Fetched 3,457 kB in 25s (138 kB/s)
(Reading database ... 62747 files and directories currently installed.)
Preparing to replace base-files 7.1wheezy1 (using .../base-files_7.1wheezy1+rpi1_armhf.deb) ...
Unpacking replacement base-files ...
Processing triggers for man-db ...
Processing triggers for install-info ...
Setting up base-files (7.1wheezy1+rpi1) ...
Installing new version of config file /etc/issue ...
Installing new version of config file /etc/issue.net ...
Installing new version of config file /etc/os-release ...
(Reading database ... 62751 files and directories currently installed.)
Preparing to replace libgcrypt11:armhf 1.5.0-5 (using .../libgcrypt11_1.5.0-5+deb7u1_armhf.deb) ...
Unpacking replacement libgcrypt11:armhf ...
Preparing to replace libjack-jackd2-0:armhf 1.9.8~dfsg.4+20120529git007cdc37-5 (using .../libjack-jackd2-0_1.9.8~dfsg.4+20120529git007cdc37-5+rpi_armhf.deb) ...
Unpacking replacement libjack-jackd2-0:armhf ...
Preparing to replace gpgv 1.4.12-7 (using .../gpgv_1.4.12-7+deb7u1_armhf.deb) ...
Unpacking replacement gpgv ...
Setting up gpgv (1.4.12-7+deb7u1) ...
Preparing to replace gnupg 1.4.12-7 (using .../gnupg_1.4.12-7+deb7u1_armhf.deb) ...
Unpacking replacement gnupg ...
Setting up gnupg (1.4.12-7+deb7u1) ...
Preparing to replace linux-libc-dev:armhf 3.2.41-2+rpi1 (using .../linux-libc-dev_3.2.46-1+rpi1_armhf.deb) ...
Unpacking replacement linux-libc-dev:armhf ...
Setting up libgcrypt11:armhf (1.5.0-5+deb7u1) ...
Setting up libjack-jackd2-0:armhf (1.9.8~dfsg.4+20120529git007cdc37-5+rpi) ...
Setting up linux-libc-dev:armhf (3.2.46-1+rpi1) ...
pi@raspberrypi ~/applications/P*** $ sudo apt-get install alsa-utils
alsa-utils is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
AndrewS
Re: How to downgrade wheezy
Fri Aug 30, 2013 11:03 am
https://duckduckgo.com/?q=apt-get+downgrade+package suggests several ways.
But TBH I can't see any reason why the package updates you list would stop your FM transmitter (which is something I've not tried myself) from working :?
TheGreatGizmo
Sat Feb 22, 2014 3:04 am
The latest raspbian also kills the motion app for some reason. I can't stream with it...
Return to “Raspberry Pi OS”
