oystercatcher
error installing git ?
Tue Jul 30, 2013 5:16 pm
I am trying to install git on my raspberry pi but keep getting these errors.
need to install ffmpeg from source
[email protected]:/etc/apt# aptitude install git
The following NEW packages will be installed:
git git-man{a} libcurl3-gnutls{a} liberror-perl{a} rsync{a}
0 packages upgraded, 5 newly installed, 0 to remove and 1 not upgraded.
Need to get 7,621 kB of archives. After unpacking 13.8 MB will be used.
Do you want to continue? [Y/n/?] y
Err http://mirrordirector.raspbian.org/raspbian/ wheezy/main libcurl3-gnutls armhf 7.26.0-1+wheezy2
404 Not Found
Get: 1 http://mirrordirector.raspbian.org/raspbian/ wheezy/main liberror-perl all 0.17-1 [23.6 kB]
Get: 2 http://mirrordirector.raspbian.org/raspbian/ wheezy/main git-man all 1:1.7.10.4-1+wheezy1+rpi2 [1,074 kB]
Get: 3 http://mirrordirector.raspbian.org/raspbian/ wheezy/main git armhf 1:1.7.10.4-1+wheezy1+rpi2 [5,861 kB]
Get: 4 http://mirrordirector.raspbian.org/raspbian/ wheezy/main rsync armhf 3.0.9-4 [356 kB]
Fetched 7,315 kB in 5s (1,411 kB/s)
Selecting previously unselected package git-man.
dpkg: warning: files list file for package 'libcurl3:armhf' missing; assuming package has no files currently installed
(Reading database ... 59904 files and directories currently installed.)
Unpacking git-man (from .../git-man_1%3a1.7.10.4-1+wheezy1+rpi2_all.deb) ...
Selecting previously unselected package liberror-perl.
Unpacking liberror-perl (from .../liberror-perl_0.17-1_all.deb) ...
Selecting previously unselected package rsync.
Unpacking rsync (from .../rsync_3.0.9-4_armhf.deb) ...
Processing triggers for man-db ...
Setting up git-man (1:1.7.10.4-1+wheezy1+rpi2) ...
Setting up liberror-perl (0.17-1) ...
Setting up rsync (3.0.9-4) ...
E: Failed to fetch http://mirrordirector.raspbian.org/rasp ... _armhf.deb: 404 Not Found
MrEngman
Re: error installing git ?
Tue Jul 30, 2013 5:54 pm
Did you run aptitude update first? Could be the package that isn't loaded is an old one. aptitude update will update the list of packages available.
MrEngman
oystercatcher
Tue Jul 30, 2013 6:31 pm
thank you that fixed the problem
Return to “Raspbian”
