[solved] Netgear WNA1100 not working
Posted: Mon Jul 29, 2013 8:39 pm
by framp
Tried to use Netgear WNA1100 on raspian. Found a lot of older threads talking about incorrect atheros FW. Acually the FW seems to be OK: I can call
iwlist scan | grep -i essid
and see all the WLANs available in my space including my own SSID.
But when I try to connect I get DHCP request send out - but at the end I get a no DHCP response message. When I plug in the USB stick in my Mint 13 system I get a WLAN connection OOTB. So it's possible to use this stick with Linux in general - but with raspbian it doesn't work.
Would be great if somebody can help me on this. See following outputs. If you need other outputs just let me know.
uname
Linux raspberrypi 3.6.11+ #474 PREEMPT Thu Jun 13 17:14:42 BST 2013 armv6l GNU/Linux
lsusb
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp.
Bus 001 Device 004: ID 0a81:0205 Chesen Electronics Corp. PS/2 Keyboard+Mouse Adapter
Bus 001 Device 005: ID 04b4:6560 Cypress Semiconductor Corp. CY7C65640 USB-2.0 "TetraHub"
Bus 001 Device 006: ID 0846:9030 NetGear, Inc. WNA1100 Wireless-N 150 [Atheros AR9271]
egrep "(usb|ath)" /var/log/messages
Jul 29 21:47:20 raspberrypi kernel: [    0.940920] usbcore: registered new interface driver usbfs
Jul 29 21:47:20 raspberrypi kernel: [    0.946505] usbcore: registered new interface driver hub
Jul 29 21:47:20 raspberrypi kernel: [    0.952101] usbcore: registered new device driver usb
Jul 29 21:47:20 raspberrypi kernel: [    1.358548] usbcore: registered new interface driver smsc95xx
Jul 29 21:47:20 raspberrypi kernel: [    1.819332] dwc_otg bcm2708_usb: DWC OTG Controller
Jul 29 21:47:20 raspberrypi kernel: [    1.824466] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
Jul 29 21:47:20 raspberrypi kernel: [    1.831951] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
Jul 29 21:47:20 raspberrypi kernel: [    1.845117] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Jul 29 21:47:20 raspberrypi kernel: [    1.852066] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jul 29 21:47:20 raspberrypi kernel: [    1.859560] usb usb1: Product: DWC OTG Controller
Jul 29 21:47:20 raspberrypi kernel: [    1.864418] usb usb1: Manufacturer: Linux 3.6.11+ dwc_otg_hcd
Jul 29 21:47:20 raspberrypi kernel: [    1.870298] usb usb1: SerialNumber: bcm2708_usb
Jul 29 21:47:20 raspberrypi kernel: [    1.910150] usbcore: registered new interface driver usb-storage
Jul 29 21:47:20 raspberrypi kernel: [    1.931263] usbcore: registered new interface driver libusual
Jul 29 21:47:20 raspberrypi kernel: [    2.137576] usbcore: registered new interface driver usbhid
Jul 29 21:47:20 raspberrypi kernel: [    2.172542] usbhid: USB HID core driver
Jul 29 21:47:20 raspberrypi kernel: [    2.384561] usb 1-1: new high-speed USB device number 2 using dwc_otg
Jul 29 21:47:20 raspberrypi kernel: [    2.622960] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
Jul 29 21:47:20 raspberrypi kernel: [    2.635281] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jul 29 21:47:20 raspberrypi kernel: [    2.942806] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
Jul 29 21:47:20 raspberrypi kernel: [    3.073318] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
Jul 29 21:47:20 raspberrypi kernel: [    3.096653] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jul 29 21:47:20 raspberrypi kernel: [    3.207785] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:b4:e8:74
Jul 29 21:47:20 raspberrypi kernel: [    3.322849] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
Jul 29 21:47:20 raspberrypi kernel: [    3.442189] usb 1-1.2: New USB device found, idVendor=0a81, idProduct=0205
Jul 29 21:47:20 raspberrypi kernel: [    3.470161] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Jul 29 21:47:20 raspberrypi kernel: [    3.499963] usb 1-1.2: Product: PS2 to USB Converter
Jul 29 21:47:20 raspberrypi kernel: [    3.514095] usb 1-1.2: Manufacturer: CHESEN
Jul 29 21:47:20 raspberrypi kernel: [    3.551535] input: CHESEN PS2 to USB Converter as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.0/input/input0
Jul 29 21:47:20 raspberrypi kernel: [    3.590638] hid-generic 0003:0A81:0205.0001: input,hidraw0: USB HID v1.10 Keyboard [CHESEN PS2 to USB Converter] on usb-bcm2708_usb-1.2/input0
Jul 29 21:47:20 raspberrypi kernel: [    3.639235] input: CHESEN PS2 to USB Converter as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.1/input/input1
Jul 29 21:47:20 raspberrypi kernel: [    3.679516] hid-generic 0003:0A81:0205.0002: input,hidraw1: USB HID v1.10 Mouse [CHESEN PS2 to USB Converter] on usb-bcm2708_usb-1.2/input1
Jul 29 21:47:20 raspberrypi kernel: [    3.812909] usb 1-1.3: new high-speed USB device number 5 using dwc_otg
Jul 29 21:47:20 raspberrypi kernel: [    3.953454] usb 1-1.3: New USB device found, idVendor=04b4, idProduct=6560
Jul 29 21:47:20 raspberrypi kernel: [    3.971083] usb 1-1.3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jul 29 21:47:20 raspberrypi kernel: [    4.302859] usb 1-1.3.4: new high-speed USB device number 6 using dwc_otg
Jul 29 21:47:20 raspberrypi kernel: [    4.454413] usb 1-1.3.4: New USB device found, idVendor=0846, idProduct=9030
Jul 29 21:47:20 raspberrypi kernel: [    4.492008] usb 1-1.3.4: New USB device strings: Mfr=16, Product=32, SerialNumber=48
Jul 29 21:47:20 raspberrypi kernel: [    4.531228] usb 1-1.3.4: Product: WNA1100
Jul 29 21:47:20 raspberrypi kernel: [    4.554941] usb 1-1.3.4: Manufacturer: NETGEAR WNA
Jul 29 21:47:20 raspberrypi kernel: [    4.569165] usb 1-1.3.4: SerialNumber: 12345
Jul 29 21:47:20 raspberrypi kernel: [    5.837638] usb 1-1.3.4: ath9k_htc: Firmware htc_9271.fw requested
Jul 29 21:47:20 raspberrypi kernel: [    6.138114] usbcore: registered new interface driver ath9k_htc
Jul 29 21:47:20 raspberrypi kernel: [    7.814669] usb 1-1.3.4: ath9k_htc: Transferred FW: htc_9271.fw, size: 51272
Jul 29 21:47:20 raspberrypi kernel: [    8.050831] ath9k_htc 1-1.3.4:1.0: ath9k_htc: HTC initialized with 33 credits
Jul 29 21:47:20 raspberrypi kernel: [    8.319146] ath9k_htc 1-1.3.4:1.0: ath9k_htc: FW Version: 1.3
Re: Netgear WNA1100 not working
Posted: Tue Jul 30, 2013 8:18 pm
by framp
Today I plugged the WLAN stick in another Pi running raspbian - and all of the sudden it worked :shock:
Put it back to the other Pi - works also perfekt :shock:
I don't have any clue what was the reason for the issue. I remember I deleted some mac/ip mappings in my router but don't think this fixed it :?
Anyhow: It's possible to use WNA1100 with Raspbian OOTB if you clean up your router cache (just kidding).
